First try of MIS clear cartridges - a disaster
2005-04-09 by toniko74
Hello group,
Today I tried for the first time the clear cartridges and MIS UT2
inks from 4oz bottles on my Epson 1290. Nothings works, I'm afraid.
Now I have to find out what exactly went wrong. Once I put the filled
cartriges into the printer I could not get good nozzle check (almost
all nozzles blocked), and after the first printout on plain paper
(just to see whathappens) I noticed that the cart leaves drops of ink
at the left (farther form where the cart parks) border of A4 sheet I
was printing, the sponge where the cart parks was also full of ink
and when I removed the cartriges there was a small amount of ink
inside the cart near the valves. So my first try at self refilling
was a disaster. Now what could go wrong?
First of all, my cartridges didn't have rubber plugs in round holes
at top where I was inserting needle with ink. When I filled all
chambers and primed the cartridges I taped the holes so that no air
could come in (at least I thought so).
I injected about 14cc of ink into black cartridge and 12cc into each
color chamber. Was it too much ink so that it began to spill out as
the cart was moving? Please help if anybody knows what's going on.
Tomek
Re: First try of MIS clear cartridges - a disaster
2005-04-10 by Johnny Eades
When I ordered mine, they came with light translucent plugs in a
separate small bag. The hole you put ink in with the syringe/needle
must be plugged with those plugs or you will get ink dripping all
over the place sooner or later. After plugging the holes, you must
use a bottom adapter on another syringe and pull out just enough ink
from each chamber too see in the tip of the syringe. This removes any
air that is in the small chamber right at the outlet the printer
pulls the ink from. After all this is done, you will simply need to
perform a nozzle check and you should have perfect patterns if you
had them before filling the cartridge. These are the most trouble-
free cartridges I have ever used, and the problem of foam buildup is
eliminated.
Your friend in Photography,
Johnny
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "toniko74"
<t.zakrzewski@k...> wrote:
> Hello group,
filled
(almost
ink
I
each
> Regards
> Tomek
2005-04-10 by Bob Michaels
My experience is very positive, just like Johnny's. I think these are
the greatest thing since sliced bread.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Johnny Eades"
> eliminated.
> Johnny
> > Hello group,
> filled
> (almost
> ink
> I
> each
> > Regards
> > Tomek
Re: [Digital BW] Re: First try of MIS clear cartridges - a disaster
2005-04-10 by Steve Kale
In other words, did you follow the instructions for using them?
> From: Johnny Eades <jeades1@...>
> eliminated.
> Johnny
