Problems with UT FS for 2000P
2005-04-23 by dick_barbour
I got the new R1800 a couple of weeks ago (I like it so far) and
decided to convert my venerable 2000P to B/W with the MIS UT FS ink.
Installed the carts and the eboni came up OK, but the color
replacement showed "red light" and the message that the cartridge
wasn't acceptable. Sent a problem report to MIS tech support and they
sent me another chip; same result. I pried the chip out of an Epson
T016 and put it in the MIS and it now came up, but a nozzle check
showed everything clogged in both carts. Ran 7 or 8 cleaning cycles
with no improvement. Sent another problem report but no reply after
several days.
Question #1: Is my chip experience typical, or do most of them work
right off?
Question #2: Is the clogging typical, and in any case what can be done
other than continuing to waste ink with cleaning cycles?
Question #3: Is this project doomed or is anyone getting results with
this printer/ink combo?
Dick
RE: [Digital BW] Problems with UT FS for 2000P
2005-04-23 by Paul Roark
Dick,
> ... decided to convert my venerable 2000P to B/W with the MIS UT FS ink.
Chip problem frequency seems to be increasing.  I don't know why.  Of the
2000P chips I received from MIS, I think they were all good.  Telling one
chip type from another seems to be impossible without checking them in
either a printer or equivalent.  If someone along the supply chain has
mislabeled or mix chips, it's going to be a mess.  Keep and label accurately
those that work, and have a re-setter.
> but a nozzle check
> with no improvement. ...
I did not have that experience with the 2000P that was loaned to me.  It was
really a nice printer.  I used mostly pre-loaded UT-FS carts from MIS.  They
were the old style carts.  Are what you're receiving the old ones or the new
spongeless carts?
Overall, I thought the 2000P made an excellent matte paper printer with
UT-FS.  I don't know how old or used the one I tried was.  If a 2000P has
high mileage on it, the MIS inks might have trouble.
I'm trying a cleaning solution on a high mileage 7600 before I resort to
changing the dampers.  The lower viscosity cleaning fluid easily passed
through the screens that would not pass UT inks efficiently.  I speculate
that the screens slowly build up layers of pigs -- OEM or whatever -- and
some fluids can get through easier than others.  Viscosity is probably one
factor, and there are no doubt others.  I'm going to see if a few weeks of
exposure to the cleaning fluid will break enough off the screens to solve
the problem.
Re: [Digital BW] Problems with UT FS for 2000P
2005-04-24 by dick_barbour
<paul.roark@v...> wrote:
> Dick,
FS ink.
> > but a nozzle check
cycles
 It was
MIS.  They
the new
> spongeless carts?
They are spongeless; my poor old 2000P had only had "genuine Epson"
sponge types, so I guess it just rebelled.
with
2000P has
Mine is about 3 years old, medium use I would say, but never a
sustained clogging problem.
resort to
Will be interested in your experiment's result. Thanks for the
response.
> Paul
> www.PaulRoark.com
Dick
