About C86 refill
About C86 refill
2005-05-13 by Henrik Frejborg
I'm sorry to bother you with questions that perhaps should be adressed
to MIS but...
-One uses a syringe to draw ink from the bottles and injecting into the
cartridges. Now, does one just use the same syringe with all inks? Or
does one need a separate for each?
-When drilling the hole into the cartridge, one does not have to worry
about getting stuff from the hole into the cartridge itself? The sponge
acts as a filter? No?
-There's been recommendations to have extra carts. Which can be
practical of course to be able to continue printing with the least
dealy. But the carts are colour (or rather place) sensitive, are they
not? So in order to have extra carts one would have to get a full extra
set? Ie, the resetter does not reset the colour position just the ink
level sensor? I don't really understand how these chips work (and the
resetter) I must say.
-There seems to be a high capacity black cart. Would that be the
recommended cart to get?
That's all for now. I'm still hazy about how exactly the bottom fill
adapter/priming thing actually works. But I'll return to you on that
one later. Perhaps when I actually have the goods in my sweaty hands
and can see for my self things are a bit clearer. I wish!! ;-)
Thanks for your indulgence.
henrik
RE: [Digital BW] About C86 refill
2005-05-13 by Paul Roark
Henrik,
With the C86 EZ system, if there are all EZ-N inks in the color spots, you
can use the same syringe without rinsing it.
I notice MIS sells a 1280 UT2 kit with only one syringe.  I use different
ones for each different ink, but I suppose if you rinse the syringe there is
not enough water left in it to matter.  I find the needle needs the water
blown out of it.
You have an old one with no stopper in the top of the reservoir?  I received
some of these as early beta versions, but I thought all the easy-refill
carts that were sold had a stopper on the top of the spongeless reservoir.
It can be pushed in so far that it is flush with the top, but a small
jeweler's screw driver gets it out OK.
That is the theory.  If you have an easy refill cart with no stopper, then
you can drill into the reservoir top, apparently without concern.  The
sponge that is over the outlet and between the 2 sections of the cart will
catch any debris.
> not?
Yes, the carts are the same, but the chips are specific to each spot.
> set?
You can also just switch chips.  I use a small piece of tape at the top of
the chip to hold it in place.  I can easily pull the tape and chip off and
put it on another cart.
> level sensor?
That's right.  It just sets the chip back to the full position.
I wish I had one.  I'm not sure if MIS has re-fillable versions of this or
not.
> ... I'm still hazy about how exactly the bottom fill
> adapter/priming thing actually works. ...
When a cart is vacuum filled, there should be no air in that cart to cause
problems.  A good vacuum will result in the ink being right at the outlet,
so that no priming is necessary.
When there is a problem is if one fills an empty cart from the top.  An air
bubble tends to sit right at the outlet.  When the printer tries to pull in
new ink, all it gets is air.  So, a syringe with a bottom fill adapter is
used to pull that air out of the outlet before the cart in put into the
printer.
I think MIS might be selling special bottom fill adapters with little rubber
tubes on the end.  I took one that did not have a tube on it and cut the end
down to 7 mm.  I think it might work better than the tube.  The idea is to
be able to get the adapter to seal well enough that you're not just pulling
air in around the adapter.  With a snout on the adapter that is long enough
to open the poppet valve, but short enough to allow the flange on the
adapter to seal against the bottom of the cart seems to work fairly well.
Good luck with the system.  I still think it is the easiest and cheapest way
to get into high quality B&W printing.
Re: [Digital BW] About C86 refill
2005-05-13 by Peter De Smidt
I bought the pre-filled EZ inks for my C86, and the cartridges don't
have stoppers. Does this mean that these aren't the Easy Refill
Cartridges?  I'm starting to get low on ink, and I had planned on refilling.
On another note, I've been pretty happy with my two C86s so far, one for
color and one for bw.  With color, I really like the look of Epson's
Enhanced Matte. Is there a paper with a similar look that's archival?
With bw, I get pretty good prints. (At the moment I'm scanning 8x10
fiber based prints to get my file.) The prints look good until I place
it next to the silver gelatin print. Sharpness isn't the problem, but
rather the surface of the paper.  Kirkland is too glossy. I try some
premier art shield when it arrives, as I've heard that this lowers the
gloss. I also have some Epson premium semi-matte on the way. Does
spraying it with Premier Art Shield increase the gloss with this paper?
I"ve seen prints on Epson Premium Luster paper, and they were quite
good, very similar to semi-matte or pearl RC silver gelatin papers,
although it had too much texture for my liking. Does Epson professional
semi-gloss have less texture?
Peter
Peter,
> refilling.
If they are clear and have a spongeless reservoir, they should be able to be
re-filled easily.  Although it sounds like you will have to drill a hole.
(Be sure you're able to close the hole in an air-tight manner.)
If the carts are not clear with the spongeless reservoir, then bottom
filling in the old style will be needed.  With this approach foam will stop
you from getting as much ink in the cart as it originally had.  I'm not a
fan of bottom filling because it also makes the filter ineffective.
The usual papers like Hahnemuhle, Innova and PremierArt are archival.  I
think the PremierArt 205 is a good, durable paper for a fair price (MIS now
carries this -- see http://www.inksupply.com/paper.cfm#pahp, and see also
http://www.itsupplies.com/cgi-bin/itsupplies.storefront/4284d4160161816c273f
40018014063e/Catalog/1518).   The Innova offerings -- a whole set -- are
very nice, with a slightly better dmax.  The "Ultra Smooth FibaPrint" is a
particularly interesting, nicely-priced option.  (See
http://www.shadesofpaper.com/innova.htm near the bottom of the page.)   H.
PhotoRag has a slightly better dmax that some see as the standard.  Be
careful of its sensitive surface.
> ... I also have some Epson premium semi-matte on the way. Does
It does change it a bit, but the positives outweigh the negatives.  I dry
mount this paper.  It then takes on some of the texture of the underlying
matte board, which may actually help make it look more like the silver
prints I'm used to.
Premium Semigloss is another good option that does have less texture than
Luster, which I also don't like.
2005-05-13 by Douglas meeuwsen
yes, printshield does tone down the gloss of kirkland quite a bit, but
it does not really increase the gloss of semi-matte. Semi-matte has
only a little bit of texture. Semi-gloss has the same amount of texture
as luster if you ask me, it's just a little diferent kind of texture.
The semi-matte surface is pretty nice, and I think it is closer to
gloss than luster.   Printshield on kirkland gets it pretty close to
semimatte, and the image quality is maybe a tad better with kirkland.
The semimatte is kind of picky, and you may need to use 2880, or a
higher resolution than you need with kirkland....Keep in mind that I
use a 1280 for BW........ by the way, I also use the c86 for color, and
have found that with the mac driver, only two papers give me a
bulletproof colormatch. Those are EEM, and the cheap "glossy photo
paper" niether of which are archival, but that is ok for me because i
just print snaps in color, or if I do a 8x10 in color, I am fine with
reprinting it in the future. The c86 in color has a kind of nice vibe
on these papers, but I am sure the better printers are way better.
Surprisingly nice color with these two papers though. All the other
papers have a blue color cast with my mac/epson driver, even the
durabrite glossy paper made only for this inkset has the blue cast.
> paper?
> professional
2005-05-14 by scott_now_coming
Paul,
Have you (or anyone else???) tried drilling a hole into the top of an
original Epson c86 cart and re-filling it?
Is there any reason this wouldn't work?
Just a thought...
Scott
<paul.roark@v...> wrote:
> Peter,
don't
> > refilling.
able to be
hole.
bottom
will stop
not a
one for
Epson's
archival?
archival.  I
(MIS now
see also
 are
FibaPrint" is a
page.)   H.
Be
paper?
I dry
underlying
silver
> prints I'm used to.
texture than
> Paul
> www.PaulRoark.com
Re: About C86 refill
Yes,there is a high capacity blacl ink cart and MIS sells one also.
I highly recommend it. I but two of every cart when I place and
order. That way, IF I run into a problem I have a spare (I'd hate to
place an order just to order on cart!). So far, so good.
The part number is: ARC-T0431-FC
(Actually, they say it's for a C84, but the C86 uses the same carts.)
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Henrik Frejborg
adressed
> to MIS but...
Or
worry
sponge
they
extra
ink
fill
that
hands
> henrik
2005-05-14 by Paul Roark
Scott,
> Just a thought...
I have not done this, but you might want to check out Dan Staver's 2100 cart
re-filling post dated 5/23/04.
2005-05-14 by keith waltz
Definitely dont do it. dont drill hole into the top of the original cartridge, that will clog your print head anyway.
try the bulk ink system:
http://www.inkrepublic.com
they have very decent system for C86, 2200, R1800.
scott_now_coming <scott_now_coming@...> wrote:
Paul,
Just a thought...
Scott
> Peter,
don't
> > refilling.
able to be
hole.
bottom
will stop
not a
one for
Epson's
archival?
archival.  I
(MIS now
see also
are
FibaPrint" is a
page.)   H.
Be
paper?
I dry
underlying
silver
> prints I'm used to.
texture than
> Paul
> www.PaulRoark.com
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See �Group Topic, Rules and Guidelines� in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups Links
   To visit your group on the web, go to:
Yahoo! Mail Mobile
 Take Yahoo! Mail with you! Check email on your mobile phone.
C86 cannot use roll paper?
2005-08-14 by Pacific New Media
I would like to use C86 with 8.5"x33' roll paper and found it is not
supported. "User Defined" option can only define sheet paper not roll paper.
Without the correct roll paper definition it is hard to make the printer
feed the roll paper correctly.
Anyone tried and has a workaround for this issue?
- philip
