Epson 7000 mainboard replacement and firmware upgrade
2005-06-13 by john dean
After months of working on this thing replacing heads and all, I am going to
have to replace the mainboard on this 7000 to keep it alive.
Just found out that Compas Micro and Epson will still do a board exchange for
$150.00. I have a maintanace manual. Even if I sell this machine I should still
do this.
Can anyone tell me how difficult this all is? Everything else on this printer has
been restored. The guy at Compas told me I might need some "special
software". I'm going to study the manual tonight, but is this doable without me
spending even more money? I have to reinitialize everything and up date the
firmware. Does anyone know what I need for this and how complex it is? I
would like to use this machine for the new piezzotone inks that are about to
be released. Even with replacing the head fuse and transistor this pump
motor isn't working right now.
Any sources for reading about all this would be appreciated.
J
Re: Epson 7000 mainboard replacement and firmware upgrade
2005-06-13 by dfaprinting
going to
exchange for
should still
> do this.
this printer has
doable without me
date the
is? I
about to
pump
> Thanks,
> J
Are you sure it's not the motor?
From what I have read in the manual, extracting the firmware requires
1 of 3 methods. #1 is use some software to copy the firmware out of
the printer into a DOS (maybe windows) PC. The second is to use a
16MB SRAM memory card (PCMCIA type 1 or 2) To copy the firmware from
the printer to the card, then from the card to the new printer. There
may also be a number three of getting the firmware from Epson, and
copying it to the card, then use the card to copy to the new printer.
I've never had to do this yet. I also don't know if you can use any
PCMCIA memory card or if it has to be the SRAM type, those can be
expensive where regular NVRAM cards are cheap. The SRAM normally
needs a batery to keep the info alive. There might also be a fourth
method where you simply remove the chip from the old machine, and put
it in the new machine, this of course would be the easiest!
As far as checking the motor, I would have to look at the schematic
to see what type it is, and see what the logic is teling it to do.
Might be as simple as supplying the correct voltage to make it turn.
It could also be a stepper, and worst case a servo. If I have time,
I'll dig up my manual and check tonight. I mention this because it
could be possible that the motor is causing the driver chip to fail
(normally letting out smoke when they go).
Do you know if that motor is the exact same as is used in the
9000/9500? It would be easier since I have the 9500 manual printed.
Also, if you can get the firmware for the 7500, I think it is the
same chassis as the 7000. Not sure exactly what that would buy you,
but might be worth investigating.
If you would like, you can email me off list, and I'll try to help as
much as possible. A little more background into what went wrong might
be helpful too, I can't say that I've seen any other posts about this
from you before.
2005-06-13 by richard_h95050
Hi John,
I wondered what happened with your 7000 after working on the broken
CN24 -- I assume you got that restored OK, but still no output, eh?
My suggestion regarding replacement of the main board is just to be
sure it is really necessary before you jump in. Swapping the board is
sometimes easier and faster than component level repair, but since
your problem is currently with getting the pump motor working, I'd
want to make sure that the fault is actually on the main board and
not with the connectors, cables or pump motor itself.
The manual gives a pretty good description of what is required to
swap the main board, and as you will see from the procedures outlined
you're in for a bit of work. It's really not as bad as it sounds, but
I'd make sure you're comfortable with all the technical steps and
that the main board is actually the culprit before proceeding. Can
you get a scope on it to make sure?
I run Piezotones (WN) in my 7000 and they're great -- the new inks
sound even more nicer!
Ciao,
Richard
going to
exchange for
should still
> do this.
this printer has
doable without me
date the
is? I
about to
pump
> Thanks,
> J
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dfaprinting"
<dfaprinting@y...> wrote:
We're thinking along the same lines here regarding the pump motor and
trying to save John a lot of work in case it's not the main board ;>)
The motors in the 7000 and 9000 are the same spec-wise, but carry
diffent part numbers. They are both steppers (4 phase 200 cycle HB
types) with the same control voltages.
Ciao,
Richard
requires
from
There
printer.
put
turn.
as
might
this
> from you before.
Hi Richard,
I still have printouts of all your valueable information from the past. Quite a
folder here on head replacements etc.
I am pretty sure this is not the motor itself as it has always worked fine, but
rather the connection on the board that makes it buzz like that and finally give
the error message. It isn't easy reprogramming the board, you guys are right
about that. And, it requires a special program and a pc, which I do have
access to, though not Windows 95 like they mention in the manual.
I'm going to read over all this again tonight and post again tomorrow. If I can't
solve the problem of the connection of the pump motor onto the main board I
will have no choice but to replace the board. If it wasn't so cheap to buy one I
wouldn't even attempt that.
I'll get back to you.
thanks again,
John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "richard_h95050" <
richardh@j...> wrote:
> Hi John,
> Ciao,
> Richard
> going to
> exchange for
> should still
> > do this.
> this printer has
> doable without me
> date the
> is? I
> about to
> pump
> > Thanks,
> > J
and
board ;>)
> Ciao,
> Richard
That stepper isn't going to be much fun to trouble shoot. Too bad
they couldn't have just used some kind of simple DC motor with a gear
head for reduction. Do you know if there is any feedback from the
motor that the board needs to tell if it is running?
2005-06-14 by dfaprinting
> Hi Richard,
past. Quite a
worked fine, but
finally give
Is that it, a bad connection? Some days I fix those all day long.
Nothing a bit of wire and solder can't fix. I forget how many layers
these boards use, but there is always a component somewhere that you
can tack a wire too. May not look pretty, but how often do you show
off the inside of your printer? If it is the connector on the end of
the cable, that might be a little tricky, but you don't always have
to use the exact replacement connector, you can get any pair and just
hang one part on the board with wires, and then install the mate on
the cables to the motor.
You might be surprised how often really expensive equipment gets a QC
fix by running a wire on the board to fix a bad trace, and make a
modification/upgrade before they revise the actual board. I can't
tell you how often I get something that cost $15000 or more that
arrives with a small mod or fix to a PC board, broadcast TV cameras,
routing switchers, tape machines. It's actually rare to get something
that doesn't have some kind of repair or change, especially when you
get into 6+ layer boards.
2005-06-14 by richard_h95050
I agree regarding troubleshooting the stepper -- not much fun, but
from John's last post it does sound like there is some life in it.
The stepper motor is driven by an LB1845 (a pair in the 9000). This
is a PWM current control type device that has internal thermal
shutdown circuitry -- it's a pretty common and sturdy chip.
There isn't any direct feedback loop in that section of the circuit
(but the ASIC may well be sensing the state of the 42V supply line).
The the main board just outputs it's control to the stepper on a four
pin cable, CN24 -- that's the connector that was giving John grief
before, so it's definitely suspect...
Richard
> --- In
> > --- In
> and
> board ;>)
HB
> > Ciao,
> > Richard
gear
2005-06-14 by dlruckus
Yes. It's called retrofiting and is part of a technicians job in most
service organisations. It's also employed in rebuilds and repair of
exchanged parts under service contracts in most industries.
What? No one thought they just threw away valuable merchandise did
they? They get repaired, recertified and go back on the shelf for use.
Duane
Re: Epson 7000 mainboard replacement ...
Hi John,
After you read through your manual tonight and post tomorrow, can you
also answer a couple of questions?
>worked fine, but rather the connection on the board that makes it
>buzz like that and finally give the error message.
Does the stepper motor (pump) actually operate intermittently when
you initialize or does it just start "buzzing"? What error message is
it giving you -- a "0100" or ?
>...reprogramming the board...requires a special program and a pc,
>which I do have access to, though not Windows 95 like they mention
>in the manual...
It doesn't matter whether you have Win95 -- the program runs
under "DOS mode" anyway, so whatever OS is on the system you borrow
will be fine, I'm sure.
Replacing the main board may be a lot more grief for you than
repairing the CN24 connector, if that's where the problem is...
Cheers!
Richard
> Hi Richard,
<< Snipped>>
2005-06-14 by john dean
Hi Richard and dfa printing,
you  also answer a couple of questions?
Yes of Course -  I am going to try posting the jpeg of where we
soidered the wires and where they were originally on the board.
>  Q> I am pretty sure this is not the motor itself as it has always
  A -I suspect the four CN 24 connector wires because that is the
connection of  that motor to the board. Because the motor worked fine before I
had the head fuse replaced and before I broke that connector, my logic was
why would the motor decide to die now,and I think that would be rare in any
situation, since this is not a printer that has ever had heavy use.
Q- Does the stepper motor (pump) actually operate intermittently when
is
A -When the wires were soidered the machine didn't flash error
messages  immediately but the motor was actually engaged the print heads
moved out of  home position things began to work for about 5 seconds then
the motor begins buzzing and acting like it doesn't have enough power to turn
the gears  and drive the pump, which it didn't, then it stops dead and the error
message flashes  0001000C, which referes to the malfunction of the pump
motor. The manual  says check the connection, the motor, finally replace the
main board. But your  right if it is the connection I might be able to fix this if its
the mainboard replacement,  probably over my head, even if I had the
sofware to do the firmware upgrade  and reinitialize everything.
Q - It doesn't matter whether you have Win95 -- the program runs
 A -I'm sure XP would also work IF I had the program to do this with.
Q - Replacing the main board may be a lot more grief for you than
 A -You are definitely correct sir. Let me hope the board is not
ruined. I have been very, very careful with it, the guy who soidered the wires
was great and  very careful.But replacing the main board... probably more
than I am capable of doing. I was just surprised the board was only $150.00
and still available,  so momentarily it gave me hope. However even the guy
from Hong Kong, KT Chan didn't do it  for himself, he called Epson, that is a
bad sign indeed.
But, who knows. I'll keep tinkering with that CN connection for a
couple of more days before giving up on that element. I suppose I could order
a new  motor and the ribbon cable that comes connected to it. But the
connector that  goes to the board wouldn't be with it and that would be the
main thing I need.  If the motor is not bad, and I keep wondering why would
the motor all of a  sudden go bad?
I'll be in touch.
John
> Hi John,
> >in the manual...
> Cheers!
> Richard
> > Hi Richard,
> << Snipped>>
Re: Epson 7000 mainboard replacement ...jpeg
> I had to post the jpeg of the connection on the epson large format
list as this
> list makes it impossible to post pics, why?
> John
Can't get the pic, not a member there.
I did just do some price checking... the SRAM cards are... well to
put it mildly... expensive! I wonder if you could use a compact flash
card in a PCMCIA adapter to do the job, much cheaper and it
would "never" fade away. It's been about 2 years since I've read up
on the procedure for the firmware change and new main board
installation, so my memory is a little foggy. I kind of remember that
there are a lot more adjustments that need to be made after a board
change. I think all the A-D converters need to be calibrated to the
different mechanics.
If I had a 7000 I would suggest shipping the parts to me, but I
don't. I could make a go at it, but wouldn't really know if it was
fixed until sending it back.
One thing you might want to do is remove the capping station and
pump. That way the motor doesn't have a load, so it shouldn't need to
pull much current to spin. On the 9500 there is a motor check mode in
one of the service menus, that way you can avoid spraying ink all
over. I think that motor is one that can be turned on for checking.
I'll email a copy of the jpeg to you.
From John's description, it sounds like the motor is actually working
intermittently, so that would indicate the device driver is intact
and the problem is more likely with the connector fix that was
hardwired. Possibly a bad solder joint or a choice of connection
points that don't actually pass through to all board layers? (In the
jpeg, it looks like the fix/connection is being made to a solder pad
and not to the connector pin itself -- that would be preferable).
As you suggested earlier, I think it would be overkill to get into a
mainboard replacement just to resolve that problem...
Ciao,
Richard
format
> list as this
> > John
flash
that
to
in
Once again thanks for the valuable comments.......
Yea guys, the more I read about the board replacement the less I want to go
down that road. If I eventually had to do that it would probably make more
sense to order the board then let an Epson guy come and put it in and do the
programing. However, by the time he finished charging me and whining about
the Piezzo inks and me ordering my own board from Micro, I could have
bought one of the new 7800's or a slightly used 7600. I just hate to throw
things away when they could provide more years of service, know what I
mean?
I am going to try to make that connector thing work today but I have my
doubts. As you can see there is a grey wire among those four and there is no
way to see from the manual if it goes on top or bottom. I simply don't
remember and didn't have the sense to mark it. We soldered it to the top pin.
However I have held this wire in place while turning on the machine with it in
the opposite configuration and no go.
I am going to try to hold them temporarily and tape this to the original spot on
the board again today. Once before we soldered this thing I held the wires
very tightly on the original spot and it worked. I wish I had one of those
original white plastic connectors ( you can see it in my jpeg) because it held
the thing in the exact position and tightly. If I ordered a new motor it wouldn't
come with one.
Which one of you guys works on these things? If  you have an interest in
taking a stab at it I would be happy to pay you whatever it is worth for you to
try. I really don't have anything to loose do I? So I can pay for an attempt. A
perfectly great printer is going to be wasted if I don't so something. But
eventually you have to cut your losses and move on.
Thanks for the suggestions,
I will probably not order the new mainboard.
John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dfaprinting" <
> list as this
> > John
Hi John,
From the information you're providing in your post below, replacing
the main board is not really required so I'm glad you're not spending
the money on it.
You have verified that when the wires are correctly connected to CN24
that the pump motor works -- therefore, the main board device driver
(that powers the pump motor) is not defective.
You also verified that the problem is not in the pump motor or the
connecting cable between the pump motor and the main board -- rather
it is isolated to an unresolved problem with the CN24 connector.
The most practical way of solving this problem is to have someone
with good, basic electronic (not electrical ;>)) soldering skills to
visit your site and have them solder the CN24 cable pins directly to
the header. Although we both work on printers, disassembling your
7000 to ship the parts would be far more work than it's worth.
In terms of the Pin 1 orientation, I know we covered that on the EWF
group when we first discussed the CN24 problem. I wouldn't do a lot
of fooling around with the cable until you're ready to solder the
leads in place exactly where they belong -- otherwise, you may cause
unintentional damage to the system.
It would be a shame to retire your 7000 just because of this cable
problem, John -- stay with it! You just need to find someone local
who knows basic electronics and is good with a soldering iron!
All the best!
Richard
want to go
make more
and do the
whining about
have
to throw
what I
> mean?
have my
there is no
don't
the top pin.
with it in
original spot on
the wires
of those
because it held
motor it wouldn't
> come with one.
interest in
worth for you to
an attempt. A
something. But
> John
format
> > list as this
> > > John
to
flash
up
that
board
was
need to
mode in
checking.
Thanks Richard for the suggestions,
Those points on the board are so close together that it going to be a supra-
delicate job soldering to them without the points touching, but I will try to figure
something out. I don't have anything to loose at this point.
Thanks again for clairfying these options from your experience,
John
> Hi John,
> the money on it.
> All the best!
> Richard
> want to go
> make more
> and do the
> whining about
> have
> to throw
> what I
> > mean?
> have my
> there is no
> don't
> the top pin.
> with it in
> original spot on
> the wires
> of those
> because it held
> motor it wouldn't
> > come with one.
> interest in
> worth for you to
> an attempt. A
> something. But
> > John
> format
> > > list as this
> > > > John
> to
> flash
> up
> that
> board
> the
> was
> need to
> mode in
> checking.
I'll take a look at it if you want. You can email me at the following:
greg <AT> dfaprinting <DOT> com (Yahoo always hides the email address,
so you'll have to put it together). I'm up in central NY so at least in
the same country.
I might at least be able to copy the wires from my 9500 To figure out
which goes where. If you order the motor, I would expect it to come
with a new connector on the end of the wire. As far as the connector
for the board, that might be difficult to obtain from an Epson parts
place. It could be easy to salvage off of something like and old video
tape machine (which I have plenty of at my regular job). The big
question is what condition the board is in. That might be a little
harder to fix. Often with the multi layer boards, component leads are
used to help bridge connections from one layer to the next. If any of
those get broken, putting all the connections back together can be a
real pain (but not impossible).
I never did check to make sure I have a manual for the 7000, so I
prolly better do that.
Greg,
If you need a 7000 manual let me know -- if your email will take a
10mb PDF as an attachment, I can send one to you.
Richard
following:
address,
least in
> the same country.
out
connector
parts
video
are
of
a
Greg,
 Greg,
If I can't make this thing work by this weekend, I will take you up on your offer.
I actually have the entire manual printed out in book form as well as a pdf
which I can also send you on a cd if you like working off the screen. I should
also probably order the motor this week just in case it is needed.
I'm writing you to your email.
John
> the same country.
Just checked and I do have the manual for the 7000.
If you are going to order a motor, you might want to grab a few other
things while you're at it.
I always recommend having a few extra dampers on hand incase you get
one that is clogged. Also the capping station and ink pump assembly
can be nice to have.
Here are some other places to check for parts:
www.vancebaldwin.com
www.agson.com
www.nationalparts.com
I've used Vance Baldwin more often than the others.
