Digital Negs problem on Epson 2200 printer
2005-07-26 by brucercohio
All
Help please
I am having problems when trying to make digital negatives on an Epson
2200 printer.  I am using the Pictorico 2200 film.  The little rollers
and pizza wheels on the Epson 2200 printer rub the ink right off the
negative.  What printer and paper settings should I be using? Is there
a way to specify the ink density?
Is there away to remove the printer rollers?
Bruce
Re: Digital Negs problem on Epson 2200 printer
2005-07-26 by john dean
Sounds like your ink isn't drying quickly enough. I didn't have any trouble with
that film and the 2200, even with matte black, but I have heard of others who
have. You may try  a Photo black if you are using Matte black. Secondly,
experiment with your media settings in the Epson driver. LIke, try the glossy
film setting or premium glossy setting to try to lay down less ink. Finally one of
my students had this exact same problem and I told him to back off on the
density of his file in Photoshop by making the deepest backs less dense in a
curves adj layer. In other words, if your deepest backs are set on say 5, try
placing that value on 10 or 15. That reduction of shadow density in the file did
the job for him, He was using the 2200 with PK and printing out of rgb color
space. With greyscale output I would assume a similar backing off the blacks
could also help.
John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "brucercohio" <
bruce.campbell@w...> wrote:
> All
> Help please
> Bruce
2005-07-27 by brucercohio
John
Thanks for the recommendations.  I may have solved the problem.  I
was trying to print out 4x5 size pieces of Pictorico versus 8 X 10
sizes,  The inks were not drying fast enough and thus the rollers
were rubbing the ink off.
Bruce
any trouble with
others who
Secondly,
the glossy
ink. Finally one of
on the
dense in a
say 5, try
in the file did
rgb color
the blacks
> could also help.
> John
> > All
> > Help please
Epson
rollers
there
> > Bruce
2005-08-01 by John
<bruce.campbell@w...> wrote:
> All
> Help please
Epson
rollers
there
> Bruce
Bruce,
The individual 2200 printer rollers are held in place with a short
coiled spring that keeps the wheel in contact with the paper as it
exits the printer.  If you lift the cover and look down into the
printer, you will see the top of the wheels and to the left and right
side of each wheel the ends of the coil spring.  Use a small nail or
any pointed object, compress one end of the spring until you get it to
comes out.  Don't remove it, just let it lay there in the event in the
future you want return the printer to its original condition.  The
wheel should now come off the paper or film.  Release as many springs
as you need for the width of the paper/film you are printing on.
Hope this helps,
John
