Heavy muddy tones with QTR
2005-08-30 by ljakobson@aol.com
I am using QTR to tone and, whereas the tone used to be perfect, it is now
extremely
heavy and muddy.  I am using the same tone formula and same paper.  I've
tried experimenting with the ink limit and gamma adjustment sliders with no
success.
Is there a way to hold back the heaviness of the tone ? Or is this a
hopeless case ?
Thanks for any help anyone can offer !   Lisa
Re: [Digital BW] Heavy muddy tones with QTR
2005-08-31 by Leslie Otterbein
Hi Lisa:
You can help us help you by first telling the forum a few specifics,
like:
Operating system and printer model
Paper you are using and as many details as are relevant.
Just offhand, I would ask if you are printing on the right side of the
paper. If you are using a paper that's only coated on one side, which
is the usual case, printing on the wrong side would make your image
muddy. Coated paper is coated to control the dot gain. The ink will
spread considerably on uncoated stock.
Things to try while you're waiting for more response: Do a nozzle check
to make sure you're firing on all cylinders. Check all software
settings.
Leslie Otterbein
> now
>  extremely
> I've
> with no
>  success.
>  hopeless case ?
