a new 1280 w/UT2 or use 2200 w/QTR
2005-09-07 by avellan67
Hello everyone, Hoping someone who has used both printers can help me make a decision. I have been using a 1280 w/UT2 and the Quadtone rip for my BW and I have loved the prints out of it. I also have a 2200 w/ OEM inks that I of course have used for my color prints. My 1280 went down 2 wks ago and it turn out that it was the waste pad ink problem and I got hold of the reset procedure. That took care of that problem but even before the waste ink problem I was having problems with getting a good nozzle check. I put the OEM inks back in and purged and cleaned, but I still can't get a good confirm. I think the printheads are bad and that has me thinking about buying a new one or using the 2200. Why? Because if I take it to a repair center I am worried that the bill may be up to $200 with fixing or replacing the printhead and general maintenance of the printer since the waste ink issue came up. I also think that the printheads are bad because I think I read somewhere that it is possible to burn it out from too many head cleanings. I had used CIS initially but did not use it enough and had too many clogs. I since switched to prefilled cartridges since I no longer wanted to be bothered with the refilling and all that. So the question is. I have used exclusively for me the 80-15 blend in Quadtone since I love the color of that BW with the 1280. Will I get the same results with the 2200 using the Quadtone rip? I know I can print it myself and find the answer for myself. But I guess what I need to know and I can't do myself is the testing of the longevity and the fading of the prints. Has anyone done this? I have it in my head that it is impossible to match the color of the UT2 inks with a set of color inks, but I just can't afford to buy another printer right now. Even though there is a $100 rebate in the 1280. I would rather hold off till I can get the 2400, but I do not want to start printing on the 2200 if the prints are going to fade or shift colors. And also tweak the profiles to get it to match the 1280. Sorry this is so long. Just airing out my thought process. Hope someone can see what I am asking for in this convoluted long question. :) Thank you Ivan
