Question on idea for speeding up refill procedure for MIS carts
2005-12-05 by mark_roth_505
I would like to drill a hole in the top of the 4oz. plastic MIS ink
bottles, and glue/epoxy the tip of a refill syringe from the inside,
to make refilling carts as easy as possible...simply invert the
bottle, insert the tip of the syringe into the ez-fill cart, and be
done. However, I have no experience with plastics, and if anyone can
suggest an epoxy that would likely accomplish a leak-proof seal, it
would save me a ton of time/money/materials. I'll then go ahead with
the experiment and post the results if successful. (Or maybe somone
has already done this?) Thanks, Mark
Re: Question on idea for speeding up refill procedure for MIS carts
2005-12-05 by scott_now_coming
Mark,
You would still have to remove the carts so you can re-set the chip.
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mark_roth_505"
inside,
can
with
2005-12-05 by Clayton Jones
Hello Mark,
What a great idea!  After several uses the rubber plunger thingie
loses its smoothness and I've not found a way to restore it (tried
applying silicon), so I end up buying new ones now and then.  Seems
like a terrible waste of material and money.  Your idea would
eliminate the problem.  Please let us know if you find a way.  Perhaps
silicone seal...
Clayton
2005-12-05 by Bob Michaels
Clayton: I noticed disposable syringes from a mail order vet supply
are a small fraction of the MIS price. And they have 20cc ones that I
think should be ideal.
Refilling a cart from a 4 oz. squeeze bottle reminds me of the phrase
"drinking from a firehose".
Bob Michaels
<cj@c...> wrote:
so I end up buying new ones now and then.  Seems like a terrible waste
2005-12-05 by dlruckus
In the US you can get them inexpensively from farm supply stores such
as TSC in all sizes. The last time I looked, for less than a $.
Duane
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Michaels"
> Bob Michaels
2005-12-05 by Greg
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "scott_now_coming"
<scott_now_coming@y...> wrote:
> Mark,
> Scott
Depends on the printer. Some of them can be reset or frozen with the
Russian service utility that is around.
2005-12-05 by Greg
Think about something like one of these:
http://www.usplastic.com/catalog/product.asp?catalog%
5Fname=USPlastic&category%5Fname=6252&product%5Fid=14767
5Fname=USPlastic&category%5Fname=14951&product%5Fid=14884
5Fname=USPlastic&category%5Fname=8&product%5Fid=15170
5Fname=USPlastic&category%5Fname=21319&product%5Fid=288
5Fname=USPlastic&category%5Fname=21319&product%5Fid=207
2005-12-07 by Steven Karafyllakis
Hi Mark;
This sounded like an idea worth trying, so today when I ran across
some epoxy formulated for plastics (a new one on me!) I bought it
and just finished testing it. I glued the front end of a syringe to
the outside of the cap, so if it doesnt hold well I will know rather
quickly. However, the glue joint gives no sign of weakness. I used a
short blunt needle, and refilled a couple carts by rinsing and
trabsferring the needle cap. I suppose long-term it might be better
to do a needle cap for each bottle/color, but I probably won't
bother, I have too many of them between 3 printers.
At any rate, kudos for coming up with a good one, this works quite
nicely.
The glue I used is Permatex 'PermaPoxy 5min. Plastic Weld' part
no.84115. I found it in an Advance Auto Parts store, where (or if)
our overseas friends might find it or something similar, I don't
know.
Steve Karafyllakis
http://www.stevekphoto.com
ink
inside,
be
can
it
with
somone
