Re: [Digital BW] Re: Eboni in the UK
2006-05-02 by Brian
Hi Brian
I'm based in the UK and order mine from MIS.  I have only used their
cheapest shipping option which typically takes 1-2 weeks.
(I've heard that the monochrome ink sold by Permajet is rebranded MIS
ink.  It works out cheaper to order it direct though.)
Thanks, Chris.
Brian
(off topic) photography rule changes at National Parks...
2006-05-03 by Altaf Bhimji
anyone here know anything about this?
Found this blog, which says that basically the NPS will start
charging photographers for
"commercial still photography".
http://wcinews.blogspot.com/2006/04/national-park-service-issues-new-
rules.html
Just an FYI, since it is possible that some members of these groups
could be affected.
If you have an opinion about this, contact the NPS chief (link in the
blog above), and also
your Congresscritter.
Ajay
Re: (off topic) photography rule changes at National Parks...
2006-05-03 by Rob Greer
I've received a reply from Lee Dickinson of the NPS who wrote:
BEGIN QUOTE
> Sometime you work with an issue for so long that the simplest
> statement becomes so obvious you don't make it. There are now
> location fees for still photography permits in the National
> Park Service, but the requirements for a permit have not
> changed. Most still photographers in national parks will not
> need to get a permit.
> Generally, a permit for still photography is needed only if
> the activity uses models, sets, props, or requests access
> into an area not open to the general public.
END QUOTE
It looks like we have nothing to worry about in this case.
Rob Greer
http://www.robgreer.com/
new-
> rules.html
groups
> could be affected.
2006-05-04 by koloshor
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Rob Greer"
> END QUOTE
Dang. Most of my photography (even in parks) involves models...
