HVLP sprayer help
HVLP sprayer help
2006-05-23 by jforney_54
Anybody out there using an HVLP sprayer?
I'm using a SATA MiniJet hooked up to nitrogen with ClearShield.  Problem is, I'm getting
these little "globs" that dont seem to level out upon drydown.  Any one know if this is caused
from overspraying, or too high of pressure, or too high volume of Clearshield, or something
else I'm overlooking?
Re: HVLP sprayer help
2006-05-23 by Nick H. Nugent
This may be caused by one or more of the following conditions:
Clearshield is not properly diluted for spraying, the liquid may not
be adequately atomized by your minijet, your adjustment of liquid/air
flow, and probably spraying technique. You may want to spend several
pressurized cans with a certain amount of ClearShield to develop a
method that works for you.
--nick
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jforney_54"
> ClearShield.  Problem is, I'm getting these little "globs"
> this is caused from overspraying, or too high of pressure,
> or too high volume of Clearshield, or something else I'm
> overlooking? >
Re: [Digital BW] HVLP sprayer help
2006-05-23 by Stephen Castello
On Tue, 23 May 2006 15:58:58 -0000, "jforney_54"
<jforney_54@...> had a flock of green cheek conures squawk out:
Did you filter the liquid before putting it in the sprayer?
Stephen
2006-05-23 by john forney
No.  I stir it for maybe 30 seconds, then pour it into
the cup and start spraying.
> conures squawk out:
> sprayer?
> Stephen
Do You Yahoo!?
http://mail.yahoo.com
RE: [Digital BW] HVLP sprayer help
2006-05-23 by John Moody
You should be able to get strainers at a local auto parts store that sells
paint supplies.  Straining is generally a mandatory process step with any
spraygun; exceptions are pre-strained products used without cutting.
Also, call up clearstar and find out the product shelf life, and how to
check it.  While you are at it, ask them about the globs and what mesh size
they recommend for a strainer.  Best luck to you.
Best regards,
John Moody
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of john
forney
Sent: Tuesday, May 23, 2006 3:43 PM
Subject: Re: [Digital BW] HVLP sprayer help
I'll try that, thanks.
> without cutting.
> Best regards,
> John Moody
> Behalf Of john
> forney
> into
> removed]
Do You Yahoo!?
