Re: [Digital BW] QTR Create ICC Profile Not Recognized
2006-07-11 by CDTobie@aol.com
In a message dated 7/10/06 10:45:30 PM, tom.husband@... writes:
> I created a grayscale profile using the QTR Create ICC program and put
> it in the spool\drivers\color folder but CS2 will not recognize it
> when I try to convert an image.  When I right click on the .icc file
> Windows says it's null and not a recognized profile.  Any suggestions?
Does it say .icc or .icm on the end? Without one or the other, Windows
doesn't know what it is.
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
2006-07-11 by Tom Husband
Yes, it has .icc.  I tried renaming it to .icm but it made no difference.
Tom
> C. David Tobie
> Datacolor Inc.
> CDTobie@...
> www.colorvision.com
2006-07-11 by Greg
Windows
It does have one or the other (I forget which), and Windows even shows
the correct icon, but it says there is an error when you try to install
it. I haven't looked to deeply into this, but I had a profile on my
machine that I made for one of the other members of this group and
decided to try installing it.
In a message dated 7/11/06 10:47:48 AM, tom.husband@... writes:
Thats right, it would make no difference as both Mac and Windows OSes
recognize both extensions. So its something else about the profile that Windows
doesn't like. Send me a copy offline to CDTobie@... and I'll see if there is
anything I can tell you about it.
C. David Tobie
Datacolor Inc.
CDTobie@colorvision.com
www.colorvision.com
Re: QTR Create ICC Profile Not Recognized
2006-07-13 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg" <dfaprinting@...>
wrote:
> Windows
It's just the Windows right-click installer that doesn't recognize the ICC profile.
I suspect its because its grayscale not color.   But anyway if you just put it in the
correct folder Photoshop will see it just fine.
For XP the folder for profiles is:
\windows\system32\spool\drivers\color\
Roy
Re: [Digital BW] Re: QTR Create ICC Profile Not Recognized
2006-07-13 by Tom Husband
Thanks, Roy.  I did that and Photoshop doesn't recognize it.  It doesn't
appear at all in any of the profile conversion pull downs.
Tom
> <dfaprinting@...>
> > Windows
> profile.
> put it in the
> Roy
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
> GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
> POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY
> TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR
> ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY
> THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
2006-07-14 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tom Husband"
> Tom
I just copied two profiles into system32->spool->drivers->color and
CS2 only sees the RGB type of profile. The gray type does not show up.
And this only works for some applications, others will require that
the profile is installed to be able to use it. I think Nikon Capture
is one of those that requires profiles to be installed.
2006-07-14 by Roy Harrington
> > Tom
I think there are a number of issues that are confusing the situation.
1) as mentioned before the right-click install doesn't work.  I'm pretty sure
just moving the .icc file to the correct folder is sufficient.
2) there are two names associated with an icc profile. There's the filename
and there's an internal name which is set when the profile is made.
PS always shows the internal name so changing the filename has no effect
on what you see in PS.   To get different names rename the original data file
with your desired name and then create the icc -- the internal name will
have that name prepended with "QTR_".
3) in the PS pulldowns the profiles are grouped by type.  Mostly they are going
to be RGB profiles, so you'll see them all alphabetically.  Gray profiles are all
shown way at the bottom so you have to scroll all the way down to see them.
Since the names all have "QTR" in front there'll be an RGB section of QTR .icc
profiles and a separate grayscale section of QTR .icc profiles
I'm not sure what Nikon Capture does but I'd guess something similar to PS.
If this still causes trouble let me know.  I can try and track this down.
Roy
