Preventing Cleaning Cycle in Epsons
2006-08-09 by robert49brake
Was there a post a few months ago about preventing the cleaning cycle from starting either when changing a single cart e.g. Photo black to Eboni, or when turning the printer on? Going through the archives I just can't seem to plug in the right search terms. Thanks.
2006-08-09 by Clayton Jones
Hello Robert, >Was there a post a few months ago about preventing the cleaning cycle >from starting either when changing a single cart e.g. Photo black to >Eboni, or when turning the printer on? Going through the archives I >just can't seem to plug in the right search terms. Thanks. This could be done with the 2200. After swapping carts, instead of pressing the ink button, turning the printer off and then back on would avoid the cleaning cycle. However it doesn't work with the 2400. I don't know about other models. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
2006-08-09 by colingruk
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote: > > Hello Robert, > > >Was there a post a few months ago about preventing the cleaning cycle > >from starting either when changing a single cart e.g. Photo black to > >Eboni, or when turning the printer on? Going through the archives I > >just can't seem to plug in the right search terms. Thanks. > > This could be done with the 2200. After swapping carts, instead of > pressing the ink button, turning the printer off and then back on > would avoid the cleaning cycle. However it doesn't work with the > 2400. I don't know about other models. > > Regards, > Clayton > > > Info on black and white digital printing at > http://www.cjcom.net/digiprnarts.htm > Hi, Clayton, For some reason, after printing satisfactorily, my Epson 2100 (European version of the 2200) fails to print. I wait until the file has spooled and then switch off the 2100. On switching on again, it goes through a lengthy song and dance routine, but without the song. During this, I presumed it was cleaning the heads (for the greater maximization of Epson's profits) even though the red lights do not flash. Wasn't it? Colin www.colinconwayphotography.com
2006-08-10 by Doug Fisher
>>Was there a post a few months ago about preventing the cleaning cycle from starting either when changing a single cart e.g. Photo black to Eboni, or when turning the printer on?<< This isn't the same as actually changing to a different cart, but may still be worth mentioning. On my 2400, I have had a crabby magenta cart and wanted to take it out for examination and then reseat it without going through a recharging cycle. I started a nozzle check and then stopped power via the power cord (not the button!) just as the head was on a stroke to move back to the home position. The head moved back to the point where I could access the carts. I was able to take out the cart, reinsert it and then repower the printer without enduring a recharging or cleaning cycle. This may not work if you were to actually change to another cart since the printer would probably notice the different cart chips. Doug --- BetterScanning.com - Innovative Accessories for Better Film Scanning http://www.BetterScanning.com/ .
