DPI, R1800, and what does it all mean.
2006-08-21 by skippy13312000
I'm new to digital printing and I'm curious as to the effect of the DPI
setting on print quality when I convert my RAW files for CS2.  I've
read here and there people setting 360 or 720 or whatever.  Is that the
optimal DPI and why?  I have a fair amount of book knowledge on the
subject but I'm still not quite catching the relationship between Epson
printers, 720/360 dpi, and print quality.
I think it's because the "native" (if that's what you call it) DPI for
epson printers is 720 and 360 is half of that so that kinda makes sense.
Thanks for any info.
Brian Skipper
Re: [Digital BW] DPI, R1800, and what does it all mean.
2006-08-21 by Bruce Watson
> Brian Skipper
First, we are sending the file to the driver in ppi, not dpi. We can't
specify a dot pattern, we can only specify down to the pixel level.
The native resolution for the Epson drivers appears to be 720 ppi for
the desktop printers and 360 ppi for the wide format printers. What this
means is that if you give the driver some other file resolution, the
driver will either up-size or down-size your file for you before it
creates the dither pattern that it sends to the printer. The Epson
driver actually does a pretty good job of this.
Note that we are talking about the Epson driver here. The printer itself
doesn't appear to know or care so long as whatever software is talking
to it sends it a dither pattern that it can print. A driver like the
StudioPrint RIP seems to make use of all the information you can send it
- it seems to create its dither pattern without up-sizing or down-sizing
to a specific ppi setting.
As to the relationship between the file's output resolution and print
quality, that's easy enough to see for yourself. Print one of your
images at a handful of different output resolutions. That is, for the
same physical dimensions of the final print, vary just the ppi. Then put
the resulting prints side by side and judge print quality for yourself.
For the desktop printers, I'd suggest 720ppi, 360ppi, 240ppi, and
160ppi. The results of such a test might surprise you.
Bruce Watson
2006-08-21 by Steve Gledhill
Brian,
Some while ago on this forum we discussed 300ppi vs 360ppi. You refer to
dpi and the thread (see next) is about ppi. Are you mixing the two -
it's easy to do. DPI is about ink (dots per inch) and is different to
PPI which is about pixels per inch. Apologies if you do know this and
aren't confused. Anyway the thread may shed some light. It's at
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/67841
If this link doesn't work the I started it at message 67841.
Steve Gledhill
http://www.virtuallygrey.co.uk/
> Brian Skipper
___________________________________________________________
To help you stay safe and secure online, we've developed the all new Yahoo! Security Centre. http://uk.security.yahoo.com
2006-08-22 by Bruce Watson
chriskjezp wrote:
> Steve,
> I did read the other thread you mentioned and found it very helpful.
> My question, as a newbie, is: is there any significant advantage to using 720, 480, etc. over
> 360ppi?
> Thanks,
> Chris
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/79201
Asked and answered already, in this thread.
Bruce Watson
2006-08-22 by Steve Gledhill
I think I'm the Steve you refer to ... !
None that I can see.  Once you're above about 300ppi (I now use 360ppi)
you're beyond what I believe the eye can discern as pixels.  So - no
advantage to be gained at higher ppi.
Any dissenters or alternative views?
Steve
chriskjezp wrote:
> Steve,
> 360ppi?
> Thanks,
> Chris
All new Yahoo! Mail "The new Interface is stunning in its simplicity and ease of use." - PC Magazine
http://uk.docs.yahoo.com/nowyoucan.html
