>... regarding ... Crane Silver Rag, Hahn. Pearl and
>Innova Fiber papers. I have not seen any comments regarding
>any outgassing, ...
I asked the Crane representative whether Silver Rag was a barrier paper
(which stops the glycols from reaching the cellulose that holds them) and
also directly whether there was an out-gassing problem. His answer:
"As far as your question about if Silver Rag is a barrier paper, the answer
is "sort of". It is not a barrier paper such as an RC paper with its layer
of polyethylene, however, we do apply a coating that keeps the ink receptive
coating from sinking into the base paper. ... It's probably best to let it
dry for some time before putting it behind glass to be safe."
I received the same sort of response from Permajet regarding it's version of
the Innova paper.
So, while I have not actually experienced the out-gassing problem, it sounds
like we're looking at a type of barrier paper that will need to be dried
thoroughly before putting it behind glass. Plain paper (cellulose) acts
like a sponge for these problematic glycols. So, having the print pressed
under plain paper over night is supposed to be a good way to be sure the
slow-to-evaporate glycols are removed and do not fog the glass.
