New large format approach -- 4K+
2006-10-02 by Paul Roark
I'm trying a new inkset in my 7500 as a way to simplify my life and,
hopefully, cure the tone shift problem I've experienced in large format
printers running dedicated "blended" B&W inksets.
While it's too soon to be sure, I think the arrangement below is at least
working in terms of ease of profiling and quality results. It'll take weeks
to know if the tone shift problem has been eliminated or at least
significantly lessened.
This approach will only work with a rip, with QTR and IJC being the logical
ones for most B&W printers.
Currently, this is what I have loaded in the 7500 (source of ink in
parentheses), and I think it will for fine for all 7000 and 7600 generation
printers:
- 4 k's: MK (MIS - Eboni),
PK (now MIS, may be Epson later),
LK (MIS),
LLK (MIS);
- Light Cyan -- 50% MIS Light Cyan, 50% clear base for 7500;
Standard LC recommended for the 7600;
- LM (Epson UC, may be Epson Archival later).
There are no blends of more than one type of pigment in any ink. As such,
the inkset should be relatively easy to profile and should have the least
amount of color drift between printing sessions.
All inks can be off-the-shelf and from multiple sources. For the 7500,
however, I do think the lighter 50% LC ("LLC"?) is worth the effort for
smoother highlights. It's an easy 1:1 mix of readily available and
compatible cyan pigment and clear base. MIS's cyan pigment appears to be
very good.
With both MK and PK loaded, I can print on either matte or glossy paper.
With a rip, this approach is similar to the older K2 - rip approaches.
However, here there are 4 carbon inks in the combination I'm trying (3 are
used for glossy printing).
It is also similar to the K3 ABW mode approach when yellow is replaced with
carbon. A rip, however, gives the combo much more flexibility in profiling,
at the expense of somewhat more complexity.
To see a sample set of initial profiling curves (with IJC) for Kirkland see:
http://home1.gte.net/res0a2zt/4K-7500-Kirkland.jpg (Try Full Screen view if
fuzzy.)
It looks like the hard part is to get the carbon core crossovers right
first. Once the combined carbon curve is straight, it looks like the color
curves can be mostly just straight lines. I start the color curves just a
bit back from where the LLK starts. The LLK makes very smooth highlights,
but the cyan pigments, even diluted, are still the most noticeable with a
loupe. So, I start them at 8 (of 256). From the start point to the deep
shadows where the color curves head back to where the dmax is optimized,
there are no other dots. The curves are straight lines. With the toners
added, I reduced the ink limits of the LK and LLK to bring the points that
were at the top of these curves to their correct density. The PK ink limit
also needed reducing to get the best dmax.
Hopefully once I've made basic matte and glossy carbon curves, this pattern
will continue with other papers.
While the highlights under a loupe were slightly smoother with my previous
UT-FSN+ approach, the overall smoothness of the 4K + LM and LLC approach is
better, and the curves are simpler.
So, time will tell if this solves the tone shift problem, it looks like this
might be a viable and flexible approach for the older large format hextone
printers.
