QTR profile for 2200, 4K+ inkset, and Matte BW paper
2006-12-18 by Paul Roark
This is where I'm at with this approach, for what it's worth.  It's a work
in progress, but the results so far are very encouraging.
http://home1.gte.net/res09aij/QTR_2200_4K+C+cm_MBW-N.pdf
Re: [Digital BW] QTR profile for 2200, 4K+ inkset, and Matte BW paper
2006-12-19 by george craig
I don't know how this is happening, but I am getting EVERY email that goes thru
DigitalBlackandWhiteThePrint@yahoogroups.com...sometimes up to a hundred or so daily...can you help me out and see what the problem is??
Paul Roark <paul.roark@...> wrote:                                  This is where I'm at with this approach, for what it's worth.  It's a work
Do You Yahoo!?
http://mail.yahoo.com
Re: QTR profile for 2200, 4K+ inkset, and Matte BW paper
2006-12-19 by Jamie Creed
your work is always worth a great deal, work in progress or finished
result. I'd just like to clarify your ink choice and positions,
correct me if I'm wrong:
Position:    Ink:
K            Eboni
C            PK
M            LLK
Y            C - dark cyan
LC           LLC
LM           LM
LK           LK
would it be possible to get hold of your Qtr curve file as is?
regards, Jamie
It's
a work in progress, but the results so far are very encouraging.
> Paul
RE: [Digital BW] Re: QTR profile for 2200, 4K+ inkset, and Matte BW paper
2006-12-19 by Paul Roark
Jamie,
You have my current ink positions correct.  However, they may change.  If I
decide the dark cyan is definitely part of what should be in the "default"
setup for this approach, I'll probably switch it to the C position.  But,
right now I'm just now sure where it's going to end up.
I'll send the profile off list.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Jamie
Creed
Sent: Monday, December 18, 2006 5:30 PM
Subject: [Digital BW] Re: QTR profile for 2200, 4K+ inkset, and Matte BW
paper
Position: Ink:
K Eboni
C PK
M LLK
Y C - dark cyan
LC LLC
LM LM
LK LK
regards, Jamie
It's
> http://home1. <http://home1.gte.net/res09aij/QTR_2200_4K+C+cm_MBW-N.pdf>
> Paul
> www.PaulRoark.com <http://www.paulroar <http://www.paulroark.com/> k.com/>
2006-12-19 by Howard Shaw
Thanks for that. Would it also be possible to see a screen grab of the
Curve Graph of all the inks. It's easier to picture what is going on
than with the numbers alone.
regards
Howard
RE: [Digital BW] QTR profile for 2200, 4K+ inkset, and Matte BW paper
The full curves set screen grab has been added.  Let me know if you have
other questions.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Howard
Shaw
Sent: Tuesday, December 19, 2006 12:00 AM
Subject: Re: [Digital BW] QTR profile for 2200, 4K+ inkset, and Matte BW
paper
regards
Howard
> other questions.
Thanks Paul. Am I right in thinking the Cyan ink is in the Yellow position?
Perhaps using the Photo Black as one of the gray inks has made things
more complicated than they would be by going straight to the LK. Does
the extra ink in this position make a significant difference in the
shadow area? It could be that the PK has caused the tonal variation you
have had to fix with the Cyan ink.
regards
Howard
2006-12-20 by Paul Roark
Howard,
Yes.
>made things more complicated than they would be by going
> straight to the LK.
With IJC I'd agree.  However, with QTR's rather automatic method of doing
the carbon core cross-overs, it's working fine.  One of the main reasons the
PK is there is to be able to print on glossy paper without changing any
inks.  While in a 2200 it's not big deal, this is a test bed for the 7600 -
9600 also.  There is it a big deal.
> Does the extra ink in this position make a significant difference
> in the shadow area?
It adds just a bit more smoothness -- barely noticeable.  Frankly, once one
has a 3k system, the quality differences above that are more academic than
real.  In the 220 and 1280 I'll probably have just 3k's (to facilitate the
Epson driver approaches), and I expect them to make prints that can hang
next to the best.
No, the slight warming is the Eboni coming in.  It's so dense it can
overwhelm any of the colors.  Even full cyan can only offset Eboni up to
about density 1.5.  After that there will be a slight rise in warmth until
the Eboni starts to get cooler as it approaches its dmax.
I could have put more of the light colors in the mix, but I wanted to roll
that curve off gently to avoid the smoothing algorithm from going berserk
and sticking artifacts elsewhere in the curve.  (The QTR curve preview is
not, from what I can tell, an accurate view of what is actually happening.
It seems to lack the smoothing algorithms that are, no doubt, in the actual
ink distribution algorithms.  It's also got a bug in it that allows it to
work only on the first of these table-derived curves.)  At any rate, since I
had the cyan in the printer, I used it rather than lots of LLC and LM.  The
image is so dark down there that the rather minor tone variations are not
really very significant.
Actually, the PK is more neutral than the lighter grays.  As such, it
required less color, thus increasing the lightfastness in that area.  This
is consistent with what I found with the LLLK also.  The lighter the carbon,
the more color inks are needed.  The most lightfast inkset is the BO
version, but I like smoothness and tone control.
2006-12-20 by Howard Shaw
Paul, thanks for your reply.
I understand why you would want to have PK in the printer but not so
much why you would want to use it in curves for matt paper when it's
density is so close to the LK. I can see though that it does have
benefits in a more neutral curve and I understand your arguments against
using a LLLK. I presume you would not have any concerns about any
interaction between Eboni & PK in the same print.
>  ... (The QTR curve preview is
Yes, I hadn't noticed that before as I more often use .acv curves. The
second preview point curve seems to show points from the first and
second curves.
Howard
Paul Roark wrote:
>> ... One of the main reasons the
>>7600 - 9600 also. There it is a big deal.
Actually, standard PK has 3 times the carbon of LK.  That's the standard
dark to light ratio.  The K4 PK, however is a bit less dense.  The Eboni has
more carbon than the PK, of course, but I'm not real sure how much more.
It's closer to the PK than LK, I believe.
The PK in the mix does lead to a smoother transition to the Eboni.  If the
PK was not easily available or not easily inserted via the QTR routine, I
would not worry about it.  But, since it's there anyway, I figure I might as
well use it.
> ... I presume you would not have any concerns about any
No, the base of the PK and LK are the same.
>>is actually happening. It seems to lack the smoothing
>>that allows it to work only on the first of these
I started by using acv curves, but was finding that having the curves
external to the QTR profile was going to cause confusion.  For both me and
others that might use my profiles, having all the information easily
accessible from the QTR file seems rather important.  So, while I prefer a
graphical interface, I hope that I have found a rather limited number of
points in the table that gives a smooth tone ramp -- for more than just this
one profile if I'm lucky.  If that is the case, it might make it a whole lot
easier for me and others to modify the QTR profile by just altering a few
numbers in a table and without having to search for the curve that was
embedded.
Or am I missing something?  Is there an easy way to use an acv curve and
later extract it from the QTR profile?  If that could be done, I'd probably
go back to the curves.
> The second preview point curve seems to show points from the
> first and second curves.
Yes, something like that is going on.  I have not found any way to clear the
"memory" in that subroutine aside from shutting QTR down and re-opening it.
