Where to go for Profile-Epson 3800?
2006-12-27 by chuck nakell
I have never purchased a profile before but I think it is time to deal with the too black density issue I am gacing by getting one for my Epson 3800 using Hahnemuhle Photo Rag 308. Any suggestions of who does a good job of this? Thanks.
2006-12-27 by Tyler Boley
I'd say Chromix.com But initially, it may be a good idea to do some tests to see if results may be better by selecting a different media setting. A profile can only do so much if things are really blocked up. Even if you do have a custom profile made, these tests will be useful to determine what setting to use when you print a profiling chart. Tyler --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "chuck nakell" <chuck@...> wrote:
> > I have never purchased a profile before but I think it is time to deal > with the too black density issue I am gacing by getting one for my > Epson 3800 using Hahnemuhle Photo Rag 308. Any suggestions of who does > a good job of this? > > Thanks. >
2006-12-27 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" <tyler@...> wrote: > > But initially, it may be a good idea to do some tests to see if > results may be better by selecting a different media setting. A > profile can only do so much if things are really blocked up. Even if > you do have a custom profile made, these tests will be useful to > determine what setting to use when you print a profiling chart. > Tyler > The above advice is correct, you need to fix the over inking on paper before getting a profile made. I've made profiles for a lot of printers, and a lot of people. If the target is a mess because there is too much ink on the paper, the results are always lesser quality profiles.
2006-12-28 by Clayton Jones
Hello Greg, >The above advice is correct, you need to fix the over inking on paper >before getting a profile made. I've made profiles for a lot of >printers, and a lot of people. If the target is a mess because there >is too much ink on the paper, the results are always lesser quality >profiles. Try reducing the ink load setting. I keep mine at -5% all the time. Otherwise the blacks are too loaded and puddly looking. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
2006-12-28 by sagaface
...would you also recommend setting a 2200 to -5%? Sarah --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote:
> > Hello Greg, > > >The above advice is correct, you need to fix the over inking on paper > >before getting a profile made. I've made profiles for a lot of > >printers, and a lot of people. If the target is a mess because there > >is too much ink on the paper, the results are always lesser quality > >profiles. > > Try reducing the ink load setting. I keep mine at -5% all the time. > Otherwise the blacks are too loaded and puddly looking. > > > Regards, > Clayton > > > Info on black and white digital printing at > http://www.cjcom.net/digiprnarts.htm >
Hi Sarah, >...would you also recommend setting a 2200 to -5%? I can't remember if the 2200 has the ability to do this. If it does, then just run some small test prints to see which setting looks best. When I got my 2400 the initial prints, when contrast and density were otherwise ok, looked heavily overloaded in the blacks. By experimenting I found that reducing the ink load solved it, and -5% was the most I could reduce without the prints beginning to look weak. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
2006-12-28 by Terry Ritz
The 2200 has a Color Density adjustment. This will allow you to reduce the black density on the page, but it will also reduce the density of the color inks. I used to use this but find I get better color results when I build my profile by carefully selecting the media to use. For black and white work QTR of course allows full control over the black density. Terry.
> Clayton Jones wrote: > > >...would you also recommend setting a 2200 to -5%? > > I can't remember if the 2200 has the ability to do this. If it does, > then just run some small test prints to see which setting > looks best. > > When I got my 2400 the initial prints, when contrast and density were > otherwise ok, looked heavily overloaded in the blacks. By > experimenting I found that reducing the ink load solved it, and -5% > was the most I could reduce without the prints beginning to look weak.
2006-12-29 by sagaface
Since I mainly print BO -though I do use QTR when more appropriate for the image - I decided to go ahead and slightly reduce the Color Density setting, and did find that in some of the prints I had previously made that showed a bit of blockiness in the deep blacks, this alleviated that. Thanks for the suggestion. Sarah --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Terry Ritz" <t.ritz@...> wrote:
> > The 2200 has a Color Density adjustment. This will allow you to reduce the > black density on the page, but it will also reduce the density of the color > inks. I used to use this but find I get better color results when I build my > profile by carefully selecting the media to use. For black and white work > QTR of course allows full control over the black density. > > Terry. > > > Clayton Jones wrote: > > > > >...would you also recommend setting a 2200 to -5%? > > > > I can't remember if the 2200 has the ability to do this. If it does, > > then just run some small test prints to see which setting > > looks best. > > > > When I got my 2400 the initial prints, when contrast and density were > > otherwise ok, looked heavily overloaded in the blacks. By > > experimenting I found that reducing the ink load solved it, and -5% > > was the most I could reduce without the prints beginning to look weak. >
