Epson 2200 & R1800
Epson 2200 & R1800
2007-01-12 by kurt
I am printing my B/W witht the Epson 2200 and the UT7 inks and would
like to know what papers the group would suggest for best results and
where to get them. I have been using my R1800 for my color prints with
the K3 inks and would like to hear your reconmendations on paper and
sources for that printer also.
Thank you in advance for your knowledge and wisdom.
Kurt
RE: [Digital BW] Epson 2200 & R1800
2007-01-12 by Paul Roark
The answer about what papers are best depends, in part, on whether you are
profiling these papers or you intend to use pre-made profiles.  I have some
notes about the papers at http://home1.gte.net/res09aij/UT-2200-Readme.htm .
However, these may not be what I'd use today if I wanted to go through the
process of making a new profile.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of kurt
Sent: Thursday, January 11, 2007 5:10 PM
Subject: [Digital BW] Epson 2200 & R1800
Kurt
Re: [Digital BW] Epson 2200 & R1800
2007-01-12 by Kurt Mahan
Thank you for the information! I have never made the profiles before. Is it easy to do?
Kurt
----- Original Message ----
Sent: Friday, January 12, 2007 1:44:32 AM
Subject: RE: [Digital BW] Epson 2200 & R1800
notes about the papers at http://home1. gte.net/res09aij /UT-2200- Readme.htm .
www.PaulRoark. com <http://www.paulroar k.com/>
_____
From: DigitalBlackandWhit eThePrint@ yahoogroups. com
[mailto:DigitalBlackandWhit eThePrint@ yahoogroups. com] On Behalf Of kurt
To: DigitalBlackandWhit eThePrint@ yahoogroups. com
Kurt
The full curves are difficult for most.  It depends, I think, on how much
you're used to using graphs and curves.  If they come easily to you and you
have a spectro, it's not so bad.
The easiest way to move to a new paper is to find the existing curve that
gives the best tone and is reasonably linear, then use Create ICC-RGB (part
of the QTR download) to do a final linearization and embed the curve in that
ICC.  It makes a very nice workflow.  See
http://home1.gte.net/res09aij/Embedding_Photoshop_Curves_in_ICCs.pdf
___________________
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Kurt
> Mahan
> Sent: Friday, January 12, 2007 10:05 AM
> Subject: Re: [Digital BW] Epson 2200 & R1800
> it easy to do?
> Kurt
> From: Paul Roark <paul.roark@...>
> Readme.htm .
> Paul
> _____
> like to know what papers the group would suggest for best results ...
