Clogging / Moving Nozzle Checks
2007-01-21 by Terry Ritz
A couple of weeks ago we had a cold snap. In Canada that means about -25 to
-30 F and very low humidity. I started having troubles with nozzle clogs on
my 2200 and wasted 1/3 of a set of inks trying to get a clean nozzle check.
I've been through the same weather a number times before over the last 3
years and have not had issues like this with OEM Epson inks. Both K7 and MIS
Pro inks were acting up.
I bought a room humidifier and things definitely improved. However, the
weather is back to -10F or so, and I'm still fighting with this. In
particular my K and K2 inks are still an issue.
The weird thing is that since this began, one nozzle check will show 2 or 3
plugged nozzles and then the next check will show different nozzles clogged.
The one which had been bad became fine by themselves.
I would appreciate any suggestions you may have!
Terry.
Re: [Digital BW] Clogging / Moving Nozzle Checks
2007-01-22 by Carolyn Frayn
> about -25 to
> clogs on
> nozzle check.
> last 3
> K7 and MIS
> the
> show 2 or 3
> clogged.
> Terry.
Hi Terry, you must be in the east, it's spring in the west... :)  I
haven't run quads for a long while, but when the OEM's are clogged as
you describe, where some nozzles will check fine, some not, then
switch around on another test.. I turn the machines off for a few
hours. Turning them off usually causes a clog, but when the clogs are
that frustrating and not making sense, leaving the printers off so
the heads park, seems to settle the inks a bit..
Hope you've already fixed it.
Carolyn
http://www.carolynfrayn.com
