Even a blind squirrel can find an acorn
2007-02-08 by Fred59
The R340 / MIS UT-R2N installation was a success--mostly.
While I'll write this up to put in the "Installation" thread, I thought
I would simply report that it worked as expected.
I started with the Eboni (K) cart in the black position--and the
printer choked--wouldn't get past the first error message on the LCD
printer screen.  I retried install after a hard reset--still stopped.
Then I hooked up, started the printer and the PC software / driver
installation--and this time I got to error messages on the cartridge--
PK was not being recognized. I switched to the PK cart, and this time
the installation sailed through.  Obviously, the Eboni cart
is 'defective.'
After some reading up, I download PR's 21-step test file--and, using
PSE 3.0 with default settings and NO ICC, printed it on 53lb RR Premium
Gloss.  The result was perfect, to my totally-untrained eye (rather,
trained 40 and 20 years ago, with fading visual recall)--perhaps a
bit "flat" but with flawless gradations.
I tried printing a B&W test photo InkjetFly sent me--and again, a print
that seems to me to be missing only a broad tone range.
I've ordered the MIS 4 oz bottle set, and will plan to install the
Inkjetfly CIS shortly.  FWIW, MIS is sending another Eboni cart and a
new chip n/c; I also ordered a resetter and some solvent.
Now, back to reading PR's and CJ's files and figuring out how to fine
tune the software / printer output end, and how to create a workflow
for current files from a D80.
Any tips or suggestions, offer away--and thanks to all who have
encouraged me so far.
Jim
Re: Even a blind squirrel can find an acorn - EBONI & paper selection
2007-02-17 by Fred59
Phase 2--I have the InkjetFly CIS installed on the R340, with the MIS
UT-R2N/Eboni inkset.  Once I got past the novice 'cartridge-refiller'
issues, it's running smoothly--no clogs, air bubbles, or any other
hardware-related problems.
Now I am sorting out paper selection, and for the moment, I am using
Red River Premium Matte - 50 lb C2S.  'Standardizing' on that paper is
eliminating one variable while I learn the editing and printing process.
Needless to say, I'm NOT keen to try to switch out to PK black with a
CIS.
QUESTION:  Are there any Lustre papers that Eboni will work well
with?    I have some RR UltraPro Satin and RR Polar Satin on hand.
Any and all tips will be much appreciated.  Thanks--
Jim H.
RE: [Digital BW] Re: Even a blind squirrel can find an acorn - EBONI & paper selection
2007-02-17 by Paul Roark
I have yet to see an acceptable Eboni black on a luster paper.
http://home1.gte.net/res0a2zt/photos.html
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Fred59
Sent: Saturday, February 17, 2007 9:31 AM
Subject: [Digital BW] Re: Even a blind squirrel can find an acorn - EBONI &
paper selection
CIS.
Jim H.
