refilling cartridges for a R2400
2007-02-23 by pglombick
So far I have been purchasing individual K7 cartridges for my R2400. I
have noticed that there is a fair amount of ink remaining when the
printer utility says the cartridge is empty, apparently due to ink
capacity differences between Epson and Piezo cartridges. I have been
thinking of re-using cartridges and purchasing ink by the bottle. Can
anyone tell me how to refill cartridgres safely and if a chip re-setter
is required for the R2400? If so, where can I get one? Also, will
refilling for a long period of time end up in residue building up
within the cartridge?
I am also interested in this method for creating cleaning cartridges
for my R2400 which seems to clog if I don't use it every week. It is
very dry here, so perhaps a humidifier in my office might help. Any
information or links to sites with instructions or cleaning cartridges
compatible with Piezo K7 inks would be appreciated.
Thank you.
Re: [Digital BW] refilling cartridges for a R2400
2007-02-25 by Leslie Otterbein
Paul:
I don't have a 2400 but I own a 2200 and I use refilleable cartridges
from MIS (http://www.inksupply.com).
My cartridges have a hole in the top (and stopper). I use a syringe
to top up the cartridge. While I'm at it I refill any of the other
colours that are getting low. Yes you will need a chip resetter and
also a bottom fill adaptor. This last item is used to "prime" the
cartridge. There are two kinds of cartridges, one with a foam filter
and the other not. I have had good success with the former. The
plastic stoppers are hard to get out, and quite tiny (easy to lose).
You should get a syringe and needle for each colour. A long needle is
better.
MIS also sells cleaning cartridges and solution.
There are other vendors out there too, if you wish to google. I
cannot comment on the 2400 ink but I am happy with their MISPro version.
Leslie Otterbein
> setter
> Thank you.
> Paul
2007-02-25 by Reinald S. Nielsen
Paul:
Like Leslie, I have a 2200 and use MIS cartridges and inks (UT7) for B/W
prints exclusively.  As he notes, the supplied stoppers
are small and difficult to work with.  Past experience refilling Canon
cartridges inspired me to drill out the fill hole for a 6-32 Allen head
set screw turned in flush with the cartridge surface and sealed with a
bit of masking tape.
I have since abandoned the set screws and simply tape the hole closed
with electrician's plastic tape.  I am careful to wipe away any
vestige of ink near the hole.  In some instances I re-use the bit of
tape, but more often use a new piece.
As Leslie suggests, I also check all cartridges when refilling.  I
generally go after the cartridges based on the number of prints since
the last
refill.  The cartridges are attacked based on experience with the
machine, and printing, rather than a specific count of pages.  Counting may
be the road to experience.
Reinald
Leslie Otterbein wrote:
> Paul:
> better.
> Leslie Otterbein
>> setter
>> Thank you.
>> Paul
> - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
