Fibaprint / EZ inks
Fibaprint / EZ inks
2007-08-08 by Ted Chambers
I tried a sample package of Innova Fibaprint Ultrasmooth Glossy on my
C86 with the MIS EZ-warm inkset (and photo black).
The result was as bad as anything I've seen. The print was solarized,
if that's the right term. There is coarse detail and tones, but little
or no fine detail. Highlights are blown - paper white. Gloss
differential is pretty bad, although I suppose it could be fixed with
overspray.
Normally I print Silver Rag with this setup and the results are
beautiful - great prints without having to tweak the controls at all.
So I don't think there is anything wrong with the printer or inkset.
I only have three sheets left and don't even know where to start to
fix this. I really like the finish of the Innova paper and had high
hopes for it. Can it be salvaged? Has anyone used this combination
successfully?
Re: Fibaprint / EZ inks
2007-08-08 by Roger
I've tested this paper (and other similar Innovas) with the R220 and
MIS EZ-Warm/neutral hybrid set.  I got similar results to Silver Rag
and similar papers although I prefer the Innova paper texture.
It sounds silly, but are you sure you're printing on the right side
of the paper?
There really shouldn't be much of any gloss differential on
the "glossy" side.
I use the same settings (including ICC) as for Ultra Premium Glossy
Photo Paper and it works fine.
Roger
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ted Chambers"
my
solarized,
little
with
> overspray.
all.
inkset.
> successfully?
2007-08-09 by Ted Chambers
Thanks, Roger. It turned out to be a flaky MIS cartridge. I guess I
should have suspected. The Innova paper turned out fine in the end.
It's smoother, whiter, and noticably sharper than the Silver Rag. I'm
not sure which I like better - they both look very good.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roger"
and
Rag
> of the paper?
> the "glossy" side.
> Roger
on
> my
> solarized,
> little
> with
> > overspray.
> all.
> inkset.
to
high
> > successfully?
