Any usable mounting sprays?
2007-10-22 by Tyler Boley
I've just been asked about this, and since I never used adhesives on the coated art papers I thought I'd pass the question on. Any luck with any of them? No chemical yellowing? They have been using 3M Photo Mount so far. I've seen a lot of horrible yellowing from many things that outgass, including many adhesives. Tyler
2007-10-22 by john dean
I've used the 3M Spray Ment cans and they seem to hold well, but like you I certainly wouldn't trust them for long term storage on valuable prints. There is no telling what is in that stuff. I'd like to know the answer to this also. I just bought a small used dry mount press and I would imagine many dry mount tissues are far more reliable than any of these sprays. Probably the most permanent and toxic free adhesive would be PVA book binding glue, but I've never seen that chemical in a spray form that would go on smoothly and not cause buckling of the surface with photo papers. john --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" <tyler@...> wrote:
> > I've just been asked about this, and since I never used adhesives on > the coated art papers I thought I'd pass the question on. > Any luck with any of them? No chemical yellowing? They have been using > 3M Photo Mount so far. > I've seen a lot of horrible yellowing from many things that outgass, > including many adhesives. > > Tyler >
2007-10-22 by E Neilsen
Tyler, In my earlier days as an assistant in a frame shop, we used a roll on adhesive that was great for use with damaged posters, prints, etc. We slightly dampened the prints to allow them to lay flat an dplace on the coated mount board; foam core, gator foam, etc. Then carefully place the art on the board and vacuum mount the work and let cure under weight. You might check with local frame shops to see how archival it is. I think quite archival, but it has been some years so you know how the mind might not recall ALL the particulars. Eric Eric Neilsen Photo 4101 Commerce Street, Suite 9 Dallas, TX 75226 214 827-8301 http://ericneilsenphotography.com SKype ejprinter _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of john dean Sent: Monday, October 22, 2007 3:53 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Re: Any usable mounting sprays? I've used the 3M Spray Ment cans and they seem to hold well, but like you I certainly wouldn't trust them for long term storage on valuable prints. There is no telling what is in that stuff. I'd like to know the answer to this also. I just bought a small used dry mount press and I would imagine many dry mount tissues are far more reliable than any of these sprays. Probably the most permanent and toxic free adhesive would be PVA book binding glue, but I've never seen that chemical in a spray form that would go on smoothly and not cause buckling of the surface with photo papers. john --- In DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com, "Tyler Boley" <tyler@...> wrote: > > I've just been asked about this, and since I never used adhesives on > the coated art papers I thought I'd pass the question on. > Any luck with any of them? No chemical yellowing? They have been using > 3M Photo Mount so far. > I've seen a lot of horrible yellowing from many things that outgass, > including many adhesives. > > Tyler > [Non-text portions of this message have been removed]
2007-10-23 by scott_now_coming
Not a spray, but I've used this before with the supplied squeege: http://www.artsuppliesonline.com/catalog.cfm?cata_id=6730 Scott --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" <tyler@...> wrote:
2007-10-25 by art4u2see2
I've been using 3m Vac-U-Mount Adhesive for years. Here is what 3m says about it: "Formulated for use with a vacuum frame system for mounting lithographs, photographs, screen prints, maps, certificates, fabrics, and more. Bonds permanently without discoloration, cracking, or bleed through. Requires no heat. Ideal for mounting black and white and color photos quickly, easily, and permanently. Also ideal for bonding common art materials such as Cibachrome prints, resin coated (RC) photo papers, clay-coated papers, newsprint and fabric. Extended open time (up to 10 minutes) allows you to spray and bond even the largest materials." You do need a vacuum table to bond it. Never have seen anyone claim to have seen discoloration from it. Chris --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" <tyler@...> wrote: > > I've just been asked about this, and since I never used adhesives on > the coated art papers I thought I'd pass the question on. > Any luck with any of them? No chemical yellowing? They have been using
2007-10-25 by Steven Karafyllakis
Chris; Any chance it might work with a cold dry-mount press? What is the practical difference in pressure application between the two? I've never seen a vacuum press in action. Steven Karafyllakis --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "art4u2see2" <art4u2see2@...> wrote:
> > You do need a vacuum table to bond it. Never have seen anyone claim > to have seen discoloration from it. > > Chris >
