You might also wish to create your gradient in 16 bit instead of 8
bit. 16 bit has so many levels of gray that they tend to look much
smoother on print out.
FWIW, I find 2880 give me a better Dmax and smoother output. That is
what I use for all my QTR profiles. This is on a 2200 and a 4000.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "robert49brake"
<robert49brake@...> wrote:
> --- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "alistair_owens"
<owens@>
> wrote:
> > I use an Epson 2100 with Epson UC inks and have been
experimenting
> > with QTR to see if I can optimise the print quality. I have
ordered
> > some Piezography inks so while I am awaiting their arrival I want
to
> > establish a benchmark of what the Epson inks can achieve if
> > optimised.
> > I like the warm tones I get by just using the Mk and Lk inks but
like
> > the smoothness I get when I add a little LM and LC to cool the
print
> > a little. To see if I can improve smoothness in warm prints I
have
> > been trying printing at 2880 dpi. I built some linearised curves
> > using my newly acquired Printfix Pro 2 (I love that little toy)
for
> > 2880 printing (ink limit ended up at 37!). I used Epson Archival
> > Matte paper (called Enhanced Matt I believe in most countries)
for
> > the experiments discussed above together with Epson Mk and Lk.
> > After a lot of time, ink and paper expended I have to report that
I
> > cannot see any appreciable difference compared to the prints made
at
> > 1440 dpi.
> > Also, to validate the linearity of my linearisations, I printed a
> > radial gradient. Again I was a little disappointed to see some
> > distinct steps that make my radial gradient look a little like a
> > bullseye target.
> > My questions of the group are:
> > 1) Are my findings regarding 1440 vs 2880 printing consistent
with
> > the experience of others or should I persist?
> > 2) Can I reasonably expect a smooth radial gradient from just K
and
> > LK on an Epson 2100?
> > 3) If so how do I "tweak" the linearisation to achieve the smooth
> > radial gradient? Bear in mind I have already linearised using the
> > tool in QTR.
> Hello Alistair, I don't print with a 2100 so I can't comment on the
1440/2880 issue but I
> have a comment on the radial gradient and this has come up before
in other forums. What
> is the source of the radial gradient? I have made them in PS and
they will show banding
> on their own. I have also moved a radial gradient from one monitor
to another and
> watched the banding change. Everyone assumes the gradient is
perfectly smooth and any
> banding is the result of the printer but I am not convinced of
that. Many think the
> algorithm used by PS for gradients is the culprit. Others suggest
different blurring
> techniques when making the gradient.
> Somewhere inside QTR you can find a document: Ideal Densities for
Given dMax Values for
> a 21 step wedge. I think this is a more useful tool. You can also
add your own curves
> before linearization to smooth the gradient allowing the linearize
function to have to do
> only the fine tuning. Creating the Curves, I believe, differs
between Mac and QTR GUI. I
> have only a tenuous grasp of the concept myself for Macs creating
them in text mode, but
> the info is out there and perhaps others can give you a better
direction.
