Refilling Epson OEM carts
2007-11-10 by Bob Marsolais
Has anyone had success refilling Epson's OEM carts? I've read about a one way valve in them, probably to prevent refilling. Is this the case? If we can get past the valve, we can use Epson's carts to bet them at their own game! Bob
2007-11-10 by Tom Maugham
I guess that it depends what printer you have. I used to refill the carts for my 1280. It's not all that difficult but can be messy if you're not careful and you can also cross contaminate too. Then there is the issue of resetting the chips. If you're refilling the carts with the sponge you have issues of air in the sponge and the sponge deteriorating over time. I have found a CIS with spongeless carts to be the best solution. Best, Tom _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Bob Marsolais Sent: Saturday, November 10, 2007 1:30 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Refilling Epson OEM carts Has anyone had success refilling Epson's OEM carts? I've read about a one way valve in them, probably to prevent refilling. Is this the case? If we can get past the valve, we can use Epson's carts to bet them at their own game! Bob [Non-text portions of this message have been removed]
2007-11-10 by Tony Wells
Another passing thought, one harking back to when most printers were just B&W for document printing. Then, I could buy refill kits that included a little drill bit with a moulded plastic gripper part and a rubber stopper / bung. The idea was that you drilled a hole in the top of the cartridge, refilled it with ink from the large bottle, and then sealed the hole with the stopper. The stopper could then be easily removed when the cart was empty and ready for refilling again. Even a small self tapping screw and plastic washer would suffice to hold when used on pressurised carts, surely? Tony Wells.
----- Original Message ----- From: "Bob Marsolais" <bob@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Saturday, November 10, 2007 6:29 PM Subject: [Digital BW] Refilling Epson OEM carts Has anyone had success refilling Epson's OEM carts? I've read about a one way valve in them, probably to prevent refilling. Is this the case? If we can get past the valve, we can use Epson's carts to bet them at their own game! Bob
2007-11-10 by CorrPro96@aol.com
In a message dated 11/10/2007 1:34:55 P.M. Eastern Standard Time, bob@... writes: Has anyone had success refilling Epson's OEM carts? I've read about a one way valve in them, probably to prevent refilling. Is this the case? If we can get past the valve, we can use Epson's carts to bet them at their own game! Bob That is exactly what I have been doing. MIS sells a syringe refilling kit for the 110ml/220ml cartridges , that introduces ink through the valve, back into the cartridges. You can then use whatever brand of OEM equivalent inks you choose. Richard Massie ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed]
2007-11-10 by Kip Babington
I use the MIS EZ inks in C84 and C88 printers - one with a CIS, one with (MIS refillable) carts. I have a few spares, and bought a spare CIS last week, just in case. But the Epson brand carts of this size have an incredibly convoluted series of chambers and pathways inside designed (at least in part) to prevent refilling. There is no direct path to the inner ink chamber from one of the edges. The only access would be through the sides, one of which is covered in foil that (I gather) cannot be resealed if punctured. So in essence, the Epson brand carts of this size (and design) are not refillable. Cheers Kip Tony Wells wrote: > > Another passing thought, one harking back to when most printers were just > B&W for document printing. Then, I could buy refill kits that included a > little drill bit with a moulded plastic gripper part and a rubber > stopper / > bung. The idea was that you drilled a hole in the top of the cartridge, > refilled it with ink from the large bottle, and then sealed the hole with > the stopper. The stopper could then be easily removed when the cart was > empty and ready for refilling again. Even a small self tapping screw and > plastic washer would suffice to hold when used on pressurised carts, > surely? > > Tony Wells. > > > > [Non-text portions of this message have been removed]
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, CorrPro96@... wrote: > > That is exactly what I have been doing. MIS sells a syringe refilling > kit for the 110ml/220ml cartridges , that introduces ink through the > valve, back into the cartridges. You can then use whatever brand of > OEM equivalent inks you choose. > > Richard Massie > I should have been a bit more specific. I have a 1280 and R220 and am considering an 1800. Note the the C82, C84, C86, 220, 240, R800, R1800, 2400 and others all use the same cartridge and sometimes different chips, depending on the printer. Refilling the OEM 1280 carts is no issue except for sponge becoming clogged with air bubbles over time. The spongeless carts are the best solution for that. That's what I do for my 1280. However, I am thinking about carts that can be used in the more recent printers such as the 1800, 2400, etc. The methods used to refill these could also probably be used to fill carts for the 1900 and the 2400's replacement when it is announced. I have tried refilling these carts and have had some limited success. You can't just inject ink backwards using MIS's bottom fill adaptors. Very little ink gets in. That is where the (assumed) one way valve comes in. When that didn't work, I took one apart and saw all the chambers and canals Epson put into them to confuse us. It's really kind of fun to figure it out. From this experience, I figured out where to drill a hole and what angle to insert the needle to inject ink. This worked pretty good, but didn't allow me to completely fill the cart. I used instant gasket to seal the hole between refills. While I was fooling around with this approach, I can across this group and MIS's refillable carts. Because of the ease of using MIS's carts, I stopped my experiments refilling OEM carts. However, it seems like it may be time to resurrect my past notes and photos of what I did and continue the pursuit. And so the question I should have asked is has nyone been able to successfully refill the 220/240/R1800/R2400 OEM carts? What have you learned along the way? Also, if anyone has some empty OEM carts of this variety that they about to throw out, send them to me. What I learn I'll post. Epson can't take me to court over that, can they? (Not that they wouldn't threaten me!)
2007-11-11 by Paul Roark
Hi Bob, >... am considering an 1800. Note the C82, C84, C86, 220, >240, R800, R1800, 2400 and others all use the same cartridge ... (Not the C82. It and the 2200 are use the same carts.) But the others are, on average, very good, easily refillable, clear carts. I think I have a stash of then that should last a number of years, even if I have to pull old ink out of some (might do that now and replace with distilled water, in fact). ... >And so the question I should have asked is has anyone been >able to successfully refill the 220/240/R1800/R2400 OEM carts? Daniel Staver on this list had a system to do this, I believe. If he's not reading this thread, you might want to search the archives of this forum with his name and other appropriate search terms. Paul www.PaulRoark.com
2007-11-11 by Bob Marsolais
Hi Paul, > (Not the C82. It and the 2200 are use the same carts.) > You are correct. Thank you! > But the others are, on average, very good, easily refillable, clear > carts. I think I have a stash of then that should last a number of > years.... So do I and I just ordered a few more to let all the dust settle. The intent of my question was to see if the OEM carts can be refilled easily in case the off shore supply of third party refillable carts dries up as well. I've heard that that U.S. Customs might be called on to stop shipments from known off shore suppliers of third party carts if Epson prevails. If that is the case, then Canada and Hong Kong might be hard for some to access. > Daniel Staver on this list had a system to do this, I believe... Thanks for the lead. I look him up. Bob
2007-11-11 by Tony Wells
Ah well, another bright idea down the tubes, hence CIS's no doubt! :-( Tony. ----- Original Message ----- From: "Kip Babington" <cbabing3@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Saturday, November 10, 2007 9:00 PM Subject: Re: [Digital BW] Refilling Epson OEM carts I use the MIS EZ inks in C84 and C88 printers - one with a CIS, one with (MIS refillable) carts. I have a few spares, and bought a spare CIS last week, just in case. But the Epson brand carts of this size have an incredibly convoluted series of chambers and pathways inside designed (at least in part) to prevent refilling. There is no direct path to the inner ink chamber from one of the edges. The only access would be through the sides, one of which is covered in foil that (I gather) cannot be resealed if punctured. So in essence, the Epson brand carts of this size (and design) are not refillable. Cheers Kip Tony Wells wrote:
2007-11-11 by Bob Frost
>So in essence, the Epson brand carts >of this size (and design) are not refillable. They are!! Have a look at this website which gives all the details for a 2200/2100 cart. I don't think the others are much different. http://www.anestoday.com/epson2200/anatomy.htm Bob Frost. ----- Original Message ----- From: "Tony Wells" <oaksfield@...> Ah well, another bright idea down the tubes, hence CIS's no doubt! :-(
Oops. The link for refilling them is http://www.anestoday.com/epson2200/replete1.htm, but all the pages are worth reading. Bob Frost.
----- Original Message ----- From: "Bob Frost" <bob@...> >So in essence, the Epson brand carts >of this size (and design) are not refillable. They are!! Have a look at this website which gives all the details for a 2200/2100 cart. I don't think the others are much different. http://www.anestoday.com/epson2200/anatomy.htm
2007-11-11 by Eric Neilsen
Still need to remove the comma from the link. It's best to just hit a enter/return after entering a link format to ensure no extra characters get into play. Eric Neilsen Photography 4101 Commerce Street Suite 9 Dallas, TX 75226 http://e.neilsen.home.att.net http://ericneilsenphotography.com Skype ejprinter _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Bob Frost Sent: Sunday, November 11, 2007 7:12 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: Re: [Digital BW] Refilling Epson OEM carts Oops. The link for refilling them is http://www.anestoda <http://www.anestoday.com/epson2200/replete1.htm,> y.com/epson2200/replete1.htm, but all the pages are worth reading. Bob Frost. ----- Original Message ----- From: "Bob Frost" <bob@... <mailto:bob%40frost.name> > >So in essence, the Epson brand carts >of this size (and design) are not refillable. They are!! Have a look at this website which gives all the details for a 2200/2100 cart. I don't think the others are much different. http://www.anestoda <http://www.anestoday.com/epson2200/anatomy.htm> y.com/epson2200/anatomy.htm [Non-text portions of this message have been removed]
2007-11-12 by john kelly
Very interesting. It might eventually lead to cost savings and reduction of garbage, but the upfront cost of large OEM purchases is daunting. And in the end, it's still Epson pigment...good, but not "better" than the standard carts. The main goal of refilling is cheapness. I wish there were new generations of MIS/Piezo B&W that made the effort worthwhile visually. I don't prioritize cheapness: I want clog-free inks that look like MIS/Piezo, but with Epson's clog-free performance. (somebody's going to say Epson pigs clog, but in years of previous 2200 posts here and elsewhere, the complaints were nearly 100% about 3rd party, not OEM). MANY would pay a PREMIUM for B&W inksets with Epson's far-superior reliability and Eboni/MIS looks. They ALREADY PAY A HUGE PREMIUM for superior paper. I hope MIS/Piezo use whatever money they've wisely put aside for research/redesign, NOT FOR LAWYERS or workaround-marketing to save the current products.
2007-11-13 by Roger
> MANY would pay a PREMIUM for B&W inksets with Epson's > far-superior reliability and Eboni/MIS looks. They > ALREADY PAY A HUGE PREMIUM for superior paper. > > I hope MIS/Piezo use whatever money they've wisely put > aside for research/redesign, NOT FOR LAWYERS or > workaround-marketing to save the current products. > I agree improved ink quality and consistency would be worth investing in. However without a mechanism to use those new inks in current printers it would be in vain, so I hope MIS and Piezo put money into legal cartridges as well.
