Hypothetical Cart-Less CIS?
2007-11-15 by brigsby707
Hello all,
It's been quite some time since I posted, but after learning about the
current situation with the ITC ruling, I had an idea I thought I might
posit to the forum.
This may be a naive idea but here goes. Since the patents in question
pertain to the structure of the cartridges, what if one were to remove
them altogether from the equation?
From what I understand, the purpose of the cartridges is to provide a
supply of ink that does not readily flow unless there is enough
suction to draw air into the cart to replace the used ink. And as a
means of holding the cartridge's chip in place so as to make contact
with the printhead so it is recognized by the printer.
So, what if a CIS were designed to be attached to the printhead
directly via tubes/clamps of some sort and the dampening effect, to
control the flow of ink, were reproduced by some structure external to
the printer? And as for the chip, surely some adjustable structure
could be utilized to bring the chips (not patented) in contact with
the printhead.
Aside from the obvious benefit of completely avoiding Epson's patents
this system would also have the benefit of being universal to all
printers with the same number of ink channels.
Anyway, it's just an idea but maybe some of the more technical types
out there could take this and run with it.
Eric Ashworth
Re:Hypothetical Cart-Less CIS?
2007-11-15 by Rick Colson
Eric Ashworth wrote:
"... the purpose of the cartridges is to provide a supply of ink that does
not readily flow unless there is enough suction to draw air into the cart to
replace the used ink. And as a means of holding the cartridge's chip in
place so as to make contact with the print head so it is recognized by the
printer."
Eric - First of all, I am NOT an expert but I did stay in a Holiday Inn
Express last night. I have been thinking about this myself but I have some
critical questions and observations mostly pertaining to small format like
the 2200/2400/1800 printers.
1) It seems that one obvious point is the need for a firm seal between the
tubes and the "nipples" in the head. A lot of complaints about CIS systems
now seem to result from the cart fitting loosely and not making a good
enough seal. Air getting into the cart from the head-end is not a good
thing. Venting is. With the right size tube and a small zip tie or clamp the
tubing could be secured but it would be a "bitch" getting it done in such a
confined space. I have had good luck inserting tubes over these "nipples" or
"needles" for the purpose of injecting cleaner through the heads (NOT
recommended except as a last resort). However, the tube will eventually come
loose if it's not more securely clamped.
2) There appears to be the need for some kind of "damper" such as the ones
used on the large format printers to suppress larger particulates. Perhaps
the large format dampers could be used in lieu of the carts?? What other
role does the damper play?
3) Some large format carts are pressurized, some not. Is it suction at work
or pressure? Which is it in the small format printers... Appears to be
suction. However, I can say that most CIS systems are HIGHLY sensitive to
gravity and placing the bottles even a little too high will result in a mess
of ink dripping through the head. Bottles too low will result in starvation
and may even draw ink back from the head causing air bubbles or air in the
lines. In fact, some people have reported that it's not enough to get the
bottles at the right height but that the level of the ink in the bottles
should be level with the head at al times. The bottles need to be raised as
the ink is used for best results (hearsay).
Part of what has kept me from moving forward has to do with unanswered
questions about the role of gravity vs. suction vs. pressure in these
printers and an inadequate understanding on my part of just how the ink is
regulated. Pumps pull ink through for cleaning but what causes the ink to
flow while printing? Are these things known or are we just taking a shot in
the dark.
It also seems obvious that building a good CIS is more complicated than it
seems. There are a lot of problems reported. Heck, there are people getting
clogs with OEM carts too. Why some and not others? Printer tolerances?
Climatic conditions? Humidity? Atmospheric pressure? Black magic? Carts that
aren't sitting tight enough? Who does know? Any engineers out there or ex
Epson folks who really understand this stuff?
Hmmm.. Lots of food for thought but too little time to digest...
Rick Colson
RE: [Digital BW] Re:Hypothetical Cart-Less CIS?
2007-11-16 by Paul Roark
> between the tubes and the "nipples" in the head...
> I have had good luck inserting tubes over these "nipples" ...
Yes, the standard tubing I use for the vacuum loading fits nicely over the
inlet posts.
>However, the tube will eventually come loose if it's not more
>securely clamped.
They might.  I'm sure this is easily solved.
>the ones used on the large format printers ...
Yes, and MIS carries some.  I've played with my 7500 dampers, and it appears
a different tubing size is needed, but I think the basic idea is sound.
>3) Some large format carts are pressurized, some not...
The fact that CISs work indicates suction is sufficient on the desktop
units.
>... most CIS systems are HIGHLY sensitive to
> result in a mess of ink dripping through the head. Bottles
> too low will result in starvation and may even draw ink back
> from the head causing air bubbles or air in the lines.
But lots of people use these devices regularly without much worry about ink
level.  It think some work here might make the units work better than they
do already, however.
I think there is a workable system here.
2007-11-16 by dlruckus
about ink
than >they do already, however.
> Paul
 That was the reason for suggesting IV bags. However, one can simply
use rinsed out 3000/7000/9000 carts reloaded with whatever ink you
choose. The tubing then has a damper on one end and a needle for the
cart on the other. Solves all of the air and ink height problems. Set
the carts beside the machine with tape or a big rubber band around
them and you're in business.
 Why work hard to invent something different when the system the wide
formats use works just fine and can be duplicated easily.
 Also, no one can sue you for using Epson parts you own in any way you
see fit privately. They can't patent tubing,needles and glue or go
after the sale of chip reset devices either.
 Another method could use the filters you talked about some time ago
inline with the tubing and add a 'T' stub to the tubing near the head
inlet to give an empty chamber for damping. That would do away with
expensive dampers as well.
Duane
The dampers have filters in them, so that issue is also taken care of.
I think we're close to a solution here.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of dlruckus
Sent: Thursday, November 15, 2007 9:00 PM
Subject: [Digital BW] Re:Hypothetical Cart-Less CIS?
about ink
> Paul
Duane
Re: [Digital BW] Re:Hypothetical Cart-Less CIS?
2007-11-16 by Kip Babington
I'm a lawyer, but not a patent lawyer and not an engineer, who for the
last 3 years or so has used a CIS from MIS on my C84/88 printers with EZ
inks.  So far it shows no sign of dying, but I am concerned about the
longer haul.
It seems to me that it should be possible to design and fabricate an
open frame that would have the outer dimensions of one of the Epson
cartridges including its locking tabs and place for a chip.  (Imagine
cutting the sides off an Epson cartridge but leaving the edges intact,
probably with some internal or corner bracing to insure rigidity.)  This
frame would snap into the same position as a cartridge, but would not
itself hold any ink.  It would just provide a
holder/valve/filter/connector/whatever between ink lines from outside
reservoirs and the ink input to the heads themselves.  Using the
existing cartridge dimensions and locking tab locations would insure
solid connections for the ink path and the chip.
It would take some factory to set up a new mold, and the big question
would be whether the Epson patents would cover this kind of device.  But
if it was outside the patent coverage, it would provide an "industrial
strength" alternative to home-made/duct-tape devices at probably very
little cost once the molds were amortized.  Somebody amortized the cost
of manufacturing the third-party Epson-size cartridges, so doing the
same thing with an Epson-size frame shouldn't be any tougher, once the
size/location of any "internal" filter or valve was established.
Just an idea from a shoulda-been engineer.
Kip
> inlet posts.
> >securely clamped.
> appears
> units.
> about ink
> Paul
> www.PaulRoark.com
> __,___
2007-11-20 by brigsby707
Hi Duane,
I didn't realize you had already suggested the idea of a Cart-Less CIS
and after reading your previous post, apparently all I did was
reinvent your wheel with a couple slight differences, (have the
dampers outside the printer and the adjustable structure to hold the
chips). I guess great minds think alike ;P
Anyway, I was wondering if you have any idea as to what size tubing
would be needed to pull this off. And, if different sizes are needed,
how would I go about splicing the tubes. I have an old bulk ink system
for the 1280 that I've never used and that I'd like to play with,
either with the 1280 or an R200 I have. But, I've never worked with
any of the large format dampers and don't have any experience with
using tubing on the printhead inlets. Any tips/suggestions/knowledge
would be greatly appreciated.
Best Regards,
Eric Ashworth
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dlruckus"
> about ink
> > Paul
> Regards
> Duane
2007-11-20 by Ernst Dinkla
brigsby707 wrote:
> Hi Duane,
> Best Regards,
> Eric Ashworth
>> about ink
>>> Paul
>> Regards
>> Duane
The dampers have 3 functions:
the sieve to filter any filth or pigment agglomeration from
the ink stream,
the membrane keeps the ink pressure at the air pressure,
as an ink buffer to reply on sudden demand.
The cart design functions in similar ways to keep a
corresponding ink pressure:
the bag has the same air pressure around it,
the vertical bag in the cart folds horizontally so the ink
level remains more or less the same and the seal is halfway
the bag content.
Replacing the dampers isn't a good idea given the
fundamentals of the unpressurised wide format ink supply
systems.
It is possible that some design aspects of the heads or
(desktop) carts have to do with the left right acceleration
of the head carriage and the influence of that on the ink
supply. If I recall it correctly the old Crystaljet wide
format (Calcomp, Summigraph ?) available more or less before
Epson entered the market with the 9000 got a patent claim
case against it on that head design aspect. Two buffers +
two ink channels, one left, one right to solve that dynamic
ink pressure issue. Wonder if there's something like that in
the head or in the desktop cart. In the last case it has to
be addressed too.
For any 3 MK 3 PK system a distribution system on the head
carriage to serve the 6 heads with only two dampers and two
ink lines from the big carts will make the load on the head
carriage lower.
Met vriendelijke groeten, Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
2007-11-21 by brigsby707
Hi Ernst,
Thank you for the information. However I'm a little confused. You said
there are 3 functions the dampers fulfill. But, from what you wrote I
only caught the bit about filtration and pressure regulation. What is
the third?
As I mentioned in the first post, I am interested in using an
adjustable device to hold the chips in place and use some sort of
dampening in the CIS lines external to the printer (specifically small
format). From Duane's post I gather that I might have some luck using
large format dampers but might have to deal with differing tube sizes.
But just to get the ball rolling I think I will be ordering some Epson
3000 dampers and have some fun tinkering.
Your comment regarding the load on the carriage has me wondering, if
the dampers aren't in the printer's carriage and just connected via
tubing whether the printhead would be too light. But I don't think it
would be a problem as the printer operates fine with carts whether
they are full or nearly empty. I guess there's no way to know other
than to try it out.
Any additional ideas would be appreciated.
Best Regards,
Eric Ashworth
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
> the ink stream,
> the bag content.
> systems.
> be addressed too.
> carriage lower.
> |             ( unvollendet )            |
2007-11-21 by Ernst Dinkla
brigsby707 wrote:
> Hi Ernst,
> the third?
The ink buffer to bridge sudden high ink demand that can not
be pulled through the ink tubes that fast. It could well be
that the membrane also dampens the effect of the ink
pressure fluctuations due to the head carriage movements.
> than to try it out.
There's a difference between loading the carriage with the
dead weight of the carts or having it pull tubing around.
That's an exaggeration but you have to be careful that the
tubes are unrolling correctly etc. I has worked for other
CIS systems so just check how it is done there.
|             ( unvollendet )            |
2007-11-21 by Steven Karafyllakis
Eric, allow me to put in a comment or two here-one function is to
provide an exit from the ink stream for air trapped in the lines. The
air floats to the top, ink exits out the bottom as in a cartrdge. But
it exits from the same orifice as a cartridge, and frankly I think
you're going to find it very difficult to mount the dampers
externally, and connect the exit port to the intake port on the head
without leaks. And you would still need enough tubing to allow the
carriage full movement, which might affect the pressure control
function.
Some of the recently available CIS units (Chinese, but what isn't
nowdays?) have half-size carts that are essentialy a damper with an
auto reset chip in a shape that clicks into place like a cartridge.
This is a much more practical solution, even if you cut the tubes and
put large bottles (the tanks hold 220ml) or IV bags or whatever on
the other end. And the price is reasonable- the entire unit costs
less than a set of auto-reste chips from MIS or Mediastreet. I've had
2 going for several months, no problems so far. Check this link-its
worth a look.
http://stores.ebay.com/SuperJetUSA-
Store_W0QQcolZ4QQdirZ1QQfsubZ0QQftidZ2QQpZ3QQtZkm
Steven Karafyllakis
 ---- In DigitalBlackandWhiteThePrint@yahoogroups.com, "brigsby707"
<brigsby707@...> wrote:
> Hi Ernst,
I
is
> the third?
small
using
sizes.
Epson
it
> than to try it out.
> Best Regards,
> Eric Ashworth
> > the ink stream,
> > the bag content.
> > systems.
> > be addressed too.
> > carriage lower.
> > |             ( unvollendet )            |
2007-11-21 by Greg
Ernst,
One thing about the left right pressure fluctuations. As I'm sure you
have seen, as the head in the large format machines moves left to
right, there is a fairly large change in volume that can be seen at the
bottle end of the tubes, especially when ink coverage in low. It can
actually pump the ink up into the vent area of my bottles if I'm not
carefull in making sure that the vent area is empty before starting.
I'm guessing but maybe around 1 cc volume change between park and
extreme left on my 9500.
