Adobe Lightroom?
Adobe Lightroom?
2007-11-19 by nsams2002
How's Lightroom working out for black/white conversion for those using
it?  Thanks.
Norm
Re: [Digital BW] Adobe Lightroom?
2007-11-19 by Kip Babington
I used the LR beta version for several months and generally liked the
way I could get BW images, and I started to get used to the interface.
But I didn't go with the production version when it became available
because (1)  I already had a system in place for image management and
especially for "contact print" production (IMatch) that I didn't want to
give up for a new database system, (2) I often use some of the PS tools
(healing brush, paintbrush, clone tool, etc.) that weren't available in
LR and I didn't want to have to switch out to PS to use them, and (3) I
had used Convert B&W Pro (a third-party PS plug-in) from my (digital)
beginning to do B&W conversions and was just more comfortable with its
film/darkroom-like controls.
If I were starting from scratch I probably would have considered VERY
seriously going with LR and would have been happy with what I didn't
know, but with my history it just wasn't worth it.  To me.  YMMV.
Kip
> it? Thanks.
> Norm
2007-11-19 by Joost Horsten
I can compare Lightroom with Photoshop CS2. Lightroom has a much
better color mixer functionality than CS2" 6 or 8 channels versus
only 3. Plus Lightroom has a nice interactive color pick function.
On the downside: LR adjustments apply always on the entie image. So
no burning, dodging,local curves and all the neat tricks PS has to
offer. So in the end I always prefer PS.
From what I hear is that Photoshop CS3 has a similar color mixer as
Lightroom, so will combine the best of both worlds.
In the end, the two are very different tools, Lightroom a very good
photomanager package + raw convertor, with very decent image
adjustment functions. Photoshop remains the gold standard for image
manipulation. I'm happily combining the two in tandem: it's so easy
to launch PS from Lightroom..
Joost
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Kip Babington
interface.
available
and
want to
tools
available in
(3) I
(digital)
its
VERY
didn't
> Cheers,
> Kip
using
> > it? Thanks.
> > Norm
2007-11-20 by James Haney
My opinion of Lightroom:
I have totally changed my workflow with Lightroom at the center.
Importing:
	I use it to import my images from my DF cards.
	In one step:
		Copy as DNG to a main folder defined for the current year
			Lightroom automatically creates a folder here named however you
want, but I have it make a folder named YYYY-MM-DD
				(Lightroom automatically determines the correct entries for these
date values.)
		Renames in coming files using capture date and unique ID
			(you can define this a million different ways to suit your
purposes as user-defined presets)
		Make a backup copy to a server directory (or another drive etc.)
		Apply a basic set of values as a good baseline
			I include copyright, date, my name, address, phone, web address, etc.
		Batch apply and embed meta-data and keywords
			I quick-tag using the subject of the shoot or anything that
applies to the whole shoot
	At this point they are represented in the Lightroom database as a
Folder
Reviewing:
	I move through the shoot either promoting or demoting individual
images. (Flags)
		(Keyboard command to batch-delete demoted images)
	Multiple, powerful compare modes help select the best images
Rough edit, visualization
	At this point, I use one of the most powerful tools of the system, I
create VIrtual Copies of the images I want to convert to black and
white.
		A virtual copy is a set of meta-data that points to the original
image source data, but filters it through a separate set of values.
		This Virtual Copy I open in the Develop module where I convert it
to Black and White, apply sharpening, cropping, rotation, and a
million other options. - This Virtual copy is not a duplicate of the
source image, it is just a set of XML data that specifies how to
process the file. each virtual copy takes up about 32k of space and
there is no limit to how many you have.
	I put the Virtual Copies for the project into a Lightroom Collection.
		This is just a shopping basket of sorts that allows you to group a
set of images (or Virtual Copies) into a manageable and meaningful set.
Batch export for review
	Export rough edited images as jpegs (or any other format) if I need
to show them to clients or to post on the web. Lightroom has some
absolutely amazing Web export modules.
Production
	I use the tools in the Lightroom Develop module to do all of my
global color and tone control.
		High light and shadow point setting (Levels)
		Basic tone curves
		B&W conversion
		Capture sharpening
	This is done with a very critical eye. The tools in this module are
basically identical to those in Adobe Camera Raw, but I think work
better and are far more easily accomplished in the context of the
Lightroom interface.
Export to Photoshop
	Every tool has its purpose and its limits.
	Even though you can do cloning in Lightroom, it is only useful for
very basic edits.
	I do all local, regional or pixel based editing in Photoshop.
	I control-click on the image in LR and choose "Edit with Photoshop"
	This presents me with a dialog box where I choose "Edit a Copy with
Lightroom adjustments", "16 bit TIFF" and "Stack with Original"
		You end up with a TIFF image in the same folder as the source
image. You can specify how you want LR to name files that it creates.
I append "_v01" to the end of the name.
	The file opens as an RGB TIFF file in PS. (If your image was
converted to pure black and white in LR then Red, Green, and Blue
values are all identical. conversion to Greyscale will not change the
tone of the images) Discussion of LR split toning is another discussion)
	All of your LR adjustments have been applied to this image, so it
will look just like it did in LR.
	I created a Photoshop action that:
		Converts to Greyscale
		Creates some basic curve layers that I always use with the names I
want them to have
	Now I am off to the races!
	In PS I have way more control of the image, I can softproof (not
available in LR), etc.
When you save the file and go back to LR you will find a new image in
the folder, and collection you were in before. This is the TIFF file
you created.
You can re-open it from LR with  "Edit with Photoshop" and choose
instead "Edit Original." This will launch the TIFF version.
Interestingly, you can make additional edits using Lightroom Develop
tools on the B&W TIF file. This gets a little strange and complicated
to understand but basically, it just works!
In previous version of Lightroom I could not get QuadTone RIP to
print properly. However, suddenly, with version 1.3, I use the QTR-
RGB profile and I can use the truly outstanding Print module of
Lightroom to print individual files, groups of images, crop on the
fly without changing the image in Photoshop, without even opening the
file in Photoshop.
If I sound like a true believer, I am.
I spend so much more of my time editing and producing images and far,
far less time managing files, creating scripts, investigating various
tools and re-inventing my process every 2 months to incorporate an
change in technology.
In my portrait work, I used to spend 2 hours getting a batch of
images imported, renamed, in iView, tagged with meta-data, roughly
edited to make them presentable and exported to the software I use
for client presentation and editing. I used three Applescripts, a
shareware program and iView Media Pro. Now this is all done in about
15 minutes, with one program.
I have used all of the RGB-B&W conversion utilities out there and
there is nothing that is any better than the tools in LR in my
opinion. But that is just the tip of the iceberg.
Besides purchasing Photoshop, Lightroom is the best money I have ever
spent on software.
my 40¢
James Haney
2007-11-20 by Sam McCandless
> [big snip]
Thanks very much, James, both for your opinion and for the workflow
details which I snipped from this note but am saving.
I hope others on the list with B&W Lightroom workflows appreciably
different from yours will consider posting theirs too.
I expect O'Reilly's "Managing Your Photographic Workflow with
Photoshop Lightroom" by Uwe Steinmueller and Juergen Gulbins is
appropriately general, but I'd also be eager to hear any opinions
about it, because I want a workflow which starts by taking all images
in regardless of which stream(s) they later flow through.
Sam
Re: Adobe Lightroom?
2007-11-20 by the_des_bois
Just a quick question:
Does Lightroom allows cataloging of images located on removable drives
(DVD-R) ?
I use I-View for that now since I don't have network drives or large
external drives.
$$$ is scarce... :)
Many thanks
Denis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Sam McCandless
> > [big snip]
> Sam
RE: [Digital BW] Adobe Lightroom?
2007-11-20 by E Neilsen
While there are many nice things about LR, there are also some MAJOR
disappointments. It may have become more stable with 1.3, but 1.2 was an
unstable beast. It has limitations, and not to be over looked one, for
cataloging an archive. If you have many large files that you’d like to keep
track of it may leave you wanting. As a processing tool it is very nice. As
a data management/digital asset management tool I believe it has a long way
to go. I continue to use it, though not much for B&W conversion as I use
Real Grain to do much of that.
Eric Neilsen Photo
4101 Commerce Street, Suite 9
Dallas, TX 75226
214 827-8301
SKype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of James
Haney
Sent: Tuesday, November 20, 2007 11:38 AM
Subject: Re: [Digital BW] Adobe Lightroom?
Importing:
In one step:
date values.)
Folder
Reviewing:
images. (Flags)
white.
Production
Basic tone curves
B&W conversion
Capture sharpening
Export to Photoshop
very basic edits.
want them to have
you created.
file in Photoshop.
spent on software.
my 40¢
James Haney
Re: [Digital BW] Re: Adobe Lightroom?
I still think that for indexing off-line or read-only archives you
might be better off using something like iView.
I really haven't investigated it for what you are referring to.
I am planning on experimenting over the Christmas holiday with
migrating all of my 2007 work to archives.
I may just embed all of the metadata to my 2007 files, move them to
storage locations then index them in iView.
I have a feeling that it will be a better mechanism for that type of
content.
James
> (DVD-R) ?
> external drives.
> $$$ is scarce... :)
> Many thanks
> Denis
> > > [big snip]
> images
> > Sam
That is interesting, I found 1.2 to be very stable until I upgraded
to Leopard on the Mac. Then it was a real problem until 1.3 came out.
I know what you mean about pure digital asset management. There is a
lot of overhead in Lightroom when you have many thousands of images
in the catalog.
I am sure that with the newly released LR export software development
kit someone will quickly develop a module to transfer images from
Lightroom directly into iView or other DAM systems. I looked through
the SDK today. It would be pretty straightforward to do, but require
more programming knowledge and time than I currently have.
James
2007-11-20 by Paul Grant
Yes it does.......however the catalog/xmp data will have to reside on your
system.
> (DVD-R) ?
> external drives.
> $$$ is scarce... :)
> Many thanks
> Denis
> <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , Sam McCandless
>>> > > [big snip]
>> > Sam
Eric,
I believe from 1.1 on Cataloging is an option.  I use it all the time on
various portable drives.
> cataloging an archive. If you have many large files that you¹d like to keep
> Eric Neilsen Photo
> Dallas, TX 75226
> 214 827-8301
> SKype ejprinter
> _____
> <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> ] On Behalf Of James
> Haney
> Importing:
> In one step:
> date values.)
> Folder
> Reviewing:
> images. (Flags)
> white.
> Production
> Basic tone curves
> B&W conversion
> Capture sharpening
> Export to Photoshop
> very basic edits.
> want them to have
> you created.
> file in Photoshop.
> spent on software.
> my 40¢
> James Haney
2007-11-21 by Eric Neilsen
James, I killed a day last week by attending a PDN on the Road here in
Dallas. Michael Britt of Image Mechanics got an eye full from me, a his
recommendation was Extensis Portfolio. He is one of Adobe's field users and
he uses it for high volume processing and downloads the whole catalog to an
external HDF. Or more accurately, that where it always was. He does not use
it for long term archiving. This was one of the things I thought it was
meant to be when I bought the damn thing.  Oh Well, perhaps before I die
I'll get a handle on the 10s of thousands of images waiting to be seen. : (
Eric
Eric Neilsen Photography
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
Skype ejprinter
  _____
Haney
Sent: Tuesday, November 20, 2007 4:15 PM
in the catalog.
James
RE: Adobe Lightroom?
2007-11-21 by wri5p
For those interested in what was "under the hat" fixing Lightroom
developing
(and in memory of Bruce Fraser),
see this interesting last year "home discussion"
between Photoshop founder Thomas Knoll,
major present Adobe engineers Mark Hamburg and Zalman Stern
and "color guru" Bruce Fraser:
http://photoshopnews.com/2006/07/07/lightroom-podcast-episode-8-posted/
Rgds,
Marco Maero
Euresis Srl
2007-11-21 by Petr Chlumsky
Hi!
>How's Lightroom working out for black/white conversion for those using it?
Even I have no detailed idea how LR is good in BW conversion I try to add
another aspect to this discussion. I have made test for several RAW
converter this month and I have found absolute winner for me DXO. Excelent
raw coneversion, superb film emulation with BW films support like trix xp2
and others. No cataloging there.
At least try it I would recommend.
PCHe
Paul, I didn’t say that it can’t do it. What I said was that it does a
horrible job of doing it. Sure it works, on hundreds of images, even
thousands of images. But as the data base increases in size it fails. It
can’t handle moving files around very well, although it shows that it can
allow for that. Please don’t confuse what it says or allows with doing well.
It internally changed the file names of a bunch of my NEF files when I used
it to move them from point A to point B from within LR. No it didn’t erase
them, but I did need to go back remove the folders from LR and re import
them to fix the problem. This took hours and hours to fix. It also shook my
confidence in the programs ability to track files.
Suite 9
Dallas, TX 75226
Skype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Paul
Grant
Sent: Tuesday, November 20, 2007 4:37 PM
Eric,
On 11/20/07 2:04 PM, "E Neilsen" <e.neilsen2@worldnet
keep
As
way
> Eric Neilsen Photo
> Dallas, TX 75226
> 214 827-8301
> http://ericneilsenp <http://ericneilsenphotography.com> hotography.com
> SKype ejprinter
> _____
James
> Haney
> Importing:
> In one step:
> date values.)
> Folder
> Reviewing:
> images. (Flags)
> white.
> Production
> Basic tone curves
> B&W conversion
> Capture sharpening
> Export to Photoshop
> very basic edits.
> want them to have
> you created.
> file in Photoshop.
> spent on software.
> my 40¢
> James Haney
It did perform well in my processing as well. I had already plunked down my
bucks on LR however and just don't have the extra money for yet another
program. This is also why I have gone out and got Extensis Portfolio for
cataloging my archive.
Eric
Suite 9
Dallas, TX 75226
Skype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Petr
Chlumsky
Sent: Wednesday, November 21, 2007 3:44 AM
Hi!
PCHe
2007-11-21 by Paul Grant
Eric,
I think I understand what your saying.   I think what I have found is to use
More Catalogs and for me that made moving stuff around much easier.
I would agree that if you tried to put everything in one Lightroom Catalog
that would be very cumbersome.
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Eric
Neilsen
Sent: Wednesday, November 21, 2007 6:15 AM
Subject: RE: [Digital BW] Adobe Lightroom?
Suite 9
Dallas, TX 75226
http://e.neilsen. <http://e.neilsen.home.att.net> home.att.net
Skype ejprinter
_____
Grant
Eric,
keep
As
way
> Eric Neilsen Photo
> Dallas, TX 75226
> 214 827-8301
<http://ericneilsenphotography.com> hotography.com> hotography.com
> SKype ejprinter
> _____
eThePrint@yahoogrou <mailto:eThePrint%40yahoogroups.com> ps.com
James
> Haney
> Importing:
> In one step:
> date values.)
> Folder
> Reviewing:
> images. (Flags)
> white.
> Production
> Basic tone curves
> B&W conversion
> Capture sharpening
> Export to Photoshop
> very basic edits.
> want them to have
> you created.
> file in Photoshop.
> spent on software.
> my 40¢
> James Haney
