problems printing on transparency film on my Epson R2400
2008-01-23 by David
I'm trying to print transparencies, but they always end up
inconsistent, often with lines or bands in them. I print the same
images on paper and don't have this problem.
I'm guessing it may be how the printer "grabs" the sheets, and maybe
with the transparency film there is some wiggle, so printing is
inconsistent. ???
I've seen some transparency films that come with a white paper strip
down the side. I wonder if this is to help the printer grab onto the
film?
Any suggestions for how to deal with this? And how do people make
digital transparencies with this problem?
Best, David.
RE: [Digital BW] problems printing on transparency film on my Epson R2400
2008-01-23 by Eric Neilsen
David, Some of the Epson printers will use the white strip to "see" the edge
of the transparency. Most problems that I have seen with it have been in NOT
using 2880, or RPM, or what ever setting gives you the highest quality
output. Drying time will also need to be looked at as possible fixes for
banding issues with that material. It always help to say what printer and
setting you are using when looking for help with those issues.
EJ
Eric Neilsen Photography
4101 Commerce Street
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
Skype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of David
Sent: Wednesday, January 23, 2008 4:15 PM
Subject: [Digital BW] problems printing on transparency film on my Epson
R2400
inconsistent. ???
film?
Best, David.
Re: [Digital BW] problems printing on transparency film on my Epson R2400
2008-01-23 by Ender100@aol.com
David,
1.   What printer settings are you using?
2.   What film are you printing on?
3.   Are you using photo black and original Epson inks?
4.   Have you run a test to confirm that all the jets are firing?
5.   Have you run the auto-allignment for the head on the transparency film?
6.   Are you printing at the highest resolution with hi-speed or
bi-directional turned off?
Sorry for all the questions.
Best Wishes,
Mark Nelson
Precision Digital Negatives - The System
PDNPrint Forum at Yahoo Groups
www.MarkINelsonPhoto.com
In a message dated 1/23/08 4:15:37 PM, dkfreed@... writes:
> inconsistent. ???
> film?
> Best, David.
Start the year off right.  Easy ways to stay in shape.
http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489
2008-01-23 by David
In response to your questions:
1. I'm trying to create digital positive transparencies for exposing
photopolymer etching plates. To do this, I need the
random "grain"/pattern similar to an aquatint screen or bitmap image.
To get this I've been printing grayscale images using Quadtone RIP,
with matte black only ink, printing at 720 DPI, uni-directional.
I've also tried printing using the R2400 Advanced B/W mode, which
doesn' not give me options for resolution or ink cartridges, but I've
been having the same banding issues in this mode as well.
2. I'm printing on InkPress and Grafix transparency film for inkjets.
(neither has white strip down the side)
3. I'm using the matte black ink. I thought photo black would be
darker or more opaque, but I've found that not to be true. I'm
satisfied with opacity aspect of my prints.
4-5. I've cleaned and aligned the heads a number of times, though I'm
usually using matte paper to do this, not the transparency film.
6. As I noted above, when using Quadtone RIP, I'm printing at 720 DPI
output with uni-directional printing, so I can get the dot-grain
pattern I need. I might try at a higher resolution (1440 DPI), but as
I said, I'm seeing the same problems even in advanced B/W printing,
which is at high resolution output.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ender100@...
wrote:
> David,
transparency film?
> Best Wishes, Mark Nelson
> PDNPrint Forum at Yahoo Groups, www.MarkINelsonPhoto.com
maybe with the transparency film there is some wiggle, so printing is
inconsistent. ???
strip down the side. I wonder if this is to help the printer grab
onto the film?
2008-01-24 by Ender100@aol.com
David,
I have worked with a couple of people with photopolymer plates for
photogravure—a lot of fun.   I am beginning right now to calibrate the KM-73 plate from
Boxcar Press.   I'm using the Dan Weldon aquatint screen first—then another
one later that is finer.   (Double Exposure Method)   Amazingly long exposure
scale in my firsts tests with these plates.
If I am understanding you correctly, you are making your own aquatint screen.
  You will probably want to go pretty high resolution in bitmap mode. Or
perhaps you are doing bitmapped positives and doing single exposure?
With many films, the matte black does not fare too well, but it sounds like
you have a combination that works.
Have you tried the Epson driver?   Do you get banding with it also?
Have you been getting banding on other papers like luster and
Have you tried Pictorico OHP film?
You may get better results with a head alignment on the film rather than the
matte papers.
Sorry, just more questions and not too many answers.
Best Wishes,
Mark Nelson
In a message dated 1/23/08 5:46:18 PM, dkfreed@... writes:
2008-01-24 by Steven Karafyllakis
David;
>> I need the
image.
Banding on transp. film is very common, more the rule than the
exception. I think it has to do with decreased dot-gain. If you
need 'grain', introduce it in the image with a grain filter, or
PS's 'add noise' function, but print the neg at the highest res the
printer will allow, (2880 and 'finest detail)and as many ink channels
as you can muster.
I've
In the long run I think you'll do better with PK, if only because it
will stay on the film long enough to do the job? If you need more
density, try the 'spectral density' approach, that is use the plate's
lack of sensetivity to red to build the density to the level you
need. I'm thinking QTR with two blended curves might give the best
combination of number of channels firing, and density. One curve
would be only the blacks: PK, LK, and LLK. The second curve would be
M and LM, with perhaps yellow as a toner to produce red,if you really
need heavy density, as for platinum printing. The two could be
blended to suit. This would give you 5 or 6 channels firing, and
might just do the trick
Hope some of this helps
Steve Karafyllakis
Re: [Digital BW] SUCCESS printing on transparency film on my Epson R2400
2008-01-24 by David
After fooling with this to the point of madness, I finally tried a
sheet of film with a white strip on the end (from a friend, Highland
or 3M brand I think). The image printed fine, which leads me to the
conclusion that my problem has been how the printer handles this film
(and not problems with the printer nozzles or head alignment).
I'm assuming that the strip which goes in first allows the printer to
better grab the film, and allows it to print without banding.
Too bad that I've bought a package each of 8.5x11 and 11x17
transparency film without the strip, but maybe I can try gluing one on
to each sheet.
David.
--- In DigitalBla
ckandWhiteThePrint@yahoogroups.com, "Steven Karafyllakis"
<stevekphoto@...> wrote:
> David;
> >> I need the
> image.
> as you can muster.
> I've
> Steve Karafyllakis
2008-01-24 by David
Thanks Mark. See my SUCCESS message. The problem was how the film was
being handled by the printer. When I used a film with a white strip on
the end, it printed fine.
I'm using the single exposure method by the way, trying to include the
"aquatint" right in with the image, as I learned from Keith Howard.
I'm  using about a 38 second exposure, followed by 9 minute
development. This is with ImagOn film on P.E.T.G. plastic plates.
I have an aquatint screen so I might try the two exposure method at
some point. What times are you using for two exposure method? In
Keith's workshop we did about 40 seconds each, but in the studio where
I work, people are doing really long exposures with the aquatint
screen, like two or three minutes I think, but they're also using a
different developer strength and time.
Best, David.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ender100@... wrote:
> David,
> photogravureâ€"a lot of fun.   I am beginning right now to calibrate
firstâ€"then another
exposure
aquatint screen.
mode. Or
sounds like
than the
> matte papers.
> Best Wishes,
> Mark Nelson
2008-01-24 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "David"
I'm pretty sure the white strip at the end is so that the
electronic "eye" in the printer's head can see that you really have
loaded some medium falls under the category of RTM. I know this is
specifically listed in in the user manual for printers like the 9000,
9500, 7600, 9600, etc.
2008-01-24 by David
Greg, I believe you are correct. My Epson R2400 was recognized the
transparency film even without the strip, but the print with the strip
came out much better, without banding. My educated guess is that--at
least on this printer--the strip lets the printer get a better grip on
the film and there's no "wiggle room" that was causing the banding.
Best, David
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg"
2008-01-24 by Greg
My 9500 refuses to accept transparent media without a backing sheet, or
turning the sensors off. When the backing running out, the light stops
shining back to the sensor and it thinks the paper is out. Same happens
when the back side is printed dark (which happens when you are doing
things like really rough proffs or ink purges, etc.). The reason for
the banding is that the printer may do some sort of media feed check
when it loads a sheet. If you watch it, it will pull the sheet past the
head, then back it up a little to find the edge, then start printing.
It's possible (though kind of unlikely) that they count the rotations
of the paper feed motor to determin how fast the paper travels. Also
doesn't the 2400 check the head height for every different paper? If it
does than it would need to see the paper to do this adjustment.
