2400 microbanding
2400 microbanding
2008-04-11 by danielstaver
I was just very lucky to aquire a free 2400. It appears to work
prefectly except one very annoying issue. It has very slight
microbanding on all resolutions and papers I have tried so far.
A quick search on google reveals that this is a fairly common
complaint among 2400 users, and I haven't found any solutions so far.
Suggestions I've tried include:
- Clean print head
I've tried automatic and manual cleaning
Nozzle checks are perfect
- Align print head
I've tried automatic and manual alignment several times. However, it
seems that the alignment is only for vertical banding. The horizontal
alignment procedure from the 2100 driver is gone. I have to wonder why
they removed it, it seems this printer really needs it.
- Try a higher resolution (Photo RPM instead of Best photo)
No improvement
- Uncheck 'High speed'
No improvement
- Try a different paper type
Selecting thicker or thinner paper types definitely affect the
banding, but "very slight" instead of "obviously visible" is the best
I can do.
- Try QTR
QTR has much worse banding in 1440x1440 super. I haven't yet tried
2880. I'd rather use ABW if possible.
I'm running out of things to try now. Any suggestions? I really love
the fast print speed and the convenient control with ABW, but I need
to be able to make gallery quality prints or the printer is worthless
to me.
Another thing, the paper feed on the 2400 is a definite step down from
the 2100. It refuses to feed papers much more frequently than the 2100
did and seem to require frequent cleaning of the paper feed mechanism.
I can live with this however, as long as I can find a solution to the
microbanding.
Re: 2400 microbanding
2008-04-11 by Mark McCarvill
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "danielstaver"
> I can do.
Hi Daniel,
If paper thickness seems to be a variable, maybe try the paper
thickness lever. You might find one setting works better than the
others for banding.
Mark
2008-04-11 by hflockwood
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "danielstaver" <daniel@...> wrote:
The only time I've seen microbanding on my 2400 has been after changing cartridges/ink
types, and then only briefly.
There are purge pages available on the MIS (inksupply.com) site.  Printing these out may
provide more information that a simple nozzle check.  Good luck.
Harry
2008-04-12 by danielstaver
I printed the calibration chart in QTR to see the individual channels.
K and LK have the most banding, LLK a little bit and the color
channels none. I have a CIS arriving and several cartridges are
starting to run low so I'm not going to test this any further before
the CIS is installed.
2008-04-12 by hflockwood
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mark McCarvill"
> > I can do.
> Hi Daniel,
> others for banding.
> Mark
Where is this paper thickness lever on the 2400?  I see no reference to it in the manual.
Harry
I don't see one either. I have the impression this is entirely
controlled through the paper type settings in the driver and the
optional 'Thick paper' setting.
2008-04-12 by Mark McCarvill
My bad; no paper thickness lever on the 2400. My 1280 has one so I
assumed they were standard on the smaller Epson printers.
That said, the 2400 manual shows different ways of feeding papers of
varying thicknesses; thick papers feed from the front and standard
papers from the rear. This might be something worth testing.
