MIS 1400 auto reset carts
2008-06-19 by Tyler Boley
anyone have any luck with these puppies? So far all I get is empty
cart alert so can't print.
No instructions I can find on the MIS sight. They said on the phone
you just turn the printer off, then back on?
Tyler
Re: MIS 1400 auto reset carts
2008-06-20 by Andre Moreau
Hi Tyler,
My 1400 refill carts work ok. But they cannot be mixed with original
Epson carts.
Did you get your carts from MIS?
Andre
2008-06-20 by Tyler Boley
Yes, they are MIS. At first they were mixed in with some other Cone carts, but after that
didn't work I put the entire MIS set in. Still not working.
How did you reset?
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Andre Moreau"
<andre1moreau@...> wrote:
> Hi Tyler,
> Epson carts.
> Andre
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley"
<tyler@...> wrote:
> How did you reset?
Hello Tyler,
The 1400 carts are auto-reset, so I didn't have to do anything. I
don't think there's a resetter available for the 1400 carts.
I did have a problem with the R260 when I mixed Epson and MIS
autoreset carts. Nothing worked until I pulled all the carts and
replaced them with Epson's and ascertained that everything was ok.
Then put back the refilled carts and that worked.
But in your case, if I understand correctly, the MIS carts did work
when mixed with Cone carts but not when all six MIS carts are put in
the printer.
Could some MIS carts be defectives?
Andre
2008-06-20 by Jenny Ellerbe
Tyler, my original Epson carts did the same thing.  I couldn't even get
the printer to work originally.  They sent me a new set of carts, I
changed out the one that was blinking empty, and it worked after that.
I haven't gotten an empty or low cart alert since then. What do you
think the odds are that you got a printer with a bad feed mechanism and
a bad cart? :)
Jenny
RE: [Digital BW] Re: MIS 1400 auto reset carts
2008-06-20 by E Neilsen
Tyler, I have auto resets for both my 2200 and a R200 however neither are
MIS. I did need to wiggle them a little to get them to read on a few of
them. You might just try that. Also might need to wipe the chip with
something to clean it. Could be that it is just not making good contact.
If MIS carts continue to be a problem, let me know.
Eric
Eric Neilsen Photo
4101 Commerce Street, Suite 9
Dallas, TX 75226
214 827-8301
SKype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Tyler
Boley
Sent: Thursday, June 19, 2008 10:44 PM
Subject: [Digital BW] Re: MIS 1400 auto reset carts
but after that
How did you reset?
Tyler
> Hi Tyler,
> Epson carts.
> Andre
well, I'd say the odds are pretty stinkin' good eh???
After reading all of this, I pulled out the carts and put in Epson
carts, all starts up fine.
So, I'll put the MIS carts back in and see what happens. I sure would
like some fill info for them though, a confusing array of plugs came
with. Nothing on the site, nothing included with the carts, no return
service call.
Andre, I know there is no restter, apparently Epson has come up with
the first non-hackable chip. But the "auto" restting is supposed to
occur by shutting down and restarting the printer, if I recall. It
doesn't just happen all by itself...
Thanks Eric, been wiggling and wiping the whole time.
Has anyone here used these things?
T
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jenny Ellerbe"
> a bad cart? :)
> Jenny
2008-06-20 by Michael T. Murphy
> I sure would like some fill info for them though
> a confusing array of plugs came with.
Tyler,
I just refilled some carts for the CX4800, which I use for document
printing.
IF the fill process is the same, it involves two 10cc syringes. One
is filled with ink to inject into the cart at the fill port, one is
used to withdraw air and foam from the regular cart output.
With the original Epson carts, a small ball - like a ball bearing -
is used to seal the fill port.  I imagine they have a somewhat better
solution - one of the plugs? - for the refillable carts.
Looking at the directions for refilling the original Epson carts
should give you enough info to figure out how to refill yours:
http://www.inksupply.com/html/pdf/epson_oem_refill_kit_instructions.pd
f
http://www.inksupply.com/epson_oem_refill_kit.cfm
I like MIS quite a bit. Unfortunately they seem to have quality
problems with their suppliers at times. As you mentioned, there often
is not enough info available either.
Best,
Michael
Re: [Digital BW] Re: MIS 1400 auto reset carts
2008-06-20 by wkm@kauaiphotos.biz
Concerning the MIS refill system. A word to the wise. I have to exert a lot of pressure to refill 2400 carts with this method. I've had the cart slip and ink goes all over the place. A cart holder of some type would be a nice addition. Also be carefull pulling out the syringe from the port that delivers ink in the printer. It's very easy to damage the seal. A poorly designed setup imho, but, it does work.
Best, Walt
>-----Original Message-----
>From: Michael T. Murphy [mailto:uriel_bear@...]
>Sent: Friday, June 20, 2008 09:20 AM
>Tyler,
>printing.
>f
>Best,
>Michael
>Please visit the Group Homepage to check the Files, and other resources as they are often being updated.
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
>Please follow these basic guidelines:
>- As threads develop, trim off excess portions of earlier messages to keep them short.
>- Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice.
>- Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership.
>- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
>BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
>Yahoo! Groups Links
Hi Walt, thanks for the note. Basically I'm just trying to finish out
the ink from the workshop on some more tests and seemed to have
slipped into that twilight zone of meltdown we all know so well.
Seems to be working now, and to anyone else, the 1400 carts are the
same as the r260 and some others, instructions here-
http://www.inksupply.com/instructions/r260_slc_refill.cfm
Thanks all.
Tyler
> Best, Walt
> >Tyler,
> >printing.
> >f
> >Best,
> >Michael
to keep them short.
Owner and Moderators. See "Group Topic, Rules and Guidelines" in the
Files section:
PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> >Yahoo! Groups Links
> service call.
Hello Tyler,
This is the instruction set for refilling the carts I bought and was
supposed to follow.
http://tinyurl.com/4my3vf
But I removed all the plugs, filled the cart with a MIS syringe,
punctured the exit hole and used a bottom fill adapter to draw some
ink out. Put the filling plug back on and discarded the plug with the tab.
Good luck,
Andre
2008-06-20 by pr_roark
Once the cart is primed, the bottom-fill adapter is not used -- as long
as the cart has not run dry.  Usually, I just remove the cart if it is
getting very low, pull the plug over the reservoir, and squirt in some
ink.
The only problem I've had with the auto reset chips is that they do not
accurately tell me the ink level.  As such, I find myself ignoring the
indications that the ink is low.  If I do run a cart dry, then I need
to re-prime it.  But it's not a big deal.  I do highly recommend my
bottom fill adapter modification, however.
See http://www.paulroark.com/BW-Info/Mod_Bot_Fill.jpg
They can simply be cut with a sharp scissors to get them to the right
size.  These same modified bottom fill adapters are what I use to pull
ink from Epson OEM 7600 carts, which I use as my sources for Epson UC
inks.
I have not mixed cart or chip types, so I have not seen those problems.
2008-06-21 by Bob Marsolais
To All,
I have been experimenting with self-resetting carts an found there is a
learning curve to using them.
I have been using a supplier, www.inkjetcarts.us, who leans over backwards
to provide support.  Their Epson-compatible (Image Specialists) inks are $12
/ 4 oz, not $18 / 4 oz.  They claim their matte black for the R800/1800 is
the same as MIS's ebony black.  With every order they ship syringes and
needles at no charge.  They also give you a CD  with the best selection of
files including the SCC service utility, a collection of pdf files
explaining how to use self-resetting carts, and pdf's containing a ton of
information every chip refiller should know.  These last two items are the
best single collection of useful cart refilling information I've found
anywhere and have been the key to my solving my air-in-the-head- problems.
Unfortunately, you cannot download these files from their website.   I
called them and they gave me permission to upload them to our group's file
section.  If someone call tell me how to or who can upload these files, I'll
get them up there.  While some spots may be a bit rough, they are worth the
time spent, particularly if you are using self resetting chips.
One point to note about self resetting carts is that they eliminate the need
to remove carts from the printer for refilling.  Just pull the plug and
squirt in more ink and your set to go.  This eliminates the possibility of
air getting in the head and is the biggest reason I am trying them out.  If
you are changing position colors, then obviously this won't work, but then
you are only back to what you are doing now.
They sell a set of self-resetting carts for the R1800 is $26, with chips.
Evidently, because they are self-resetting, they can still sell them.
Bob
bob@...
