color profiler
2008-08-19 by Stephen Kobrin
Can someone recommend a reasonably priced color profiling system? I do not need a high end model, just one that will give me a reasonable equivalence between the screen and the print? Also, a question: can I profile two different screens run from a single computer? Thanks for any suggestions. Steve
2008-08-19 by Paul Grant
Steve, I have been very impressed witih the results I have gotten with the ColorMunki I have used it on my Monitors, and the 2200 and the 3800. I was never happy with the colors from the canned profiles on the 2200. When I got the 3800 I was very impressed. After profiling the 2200 and the 3800 the prints were very similar. I am a true believer. I am just now trying to figure out how to use it with QTR which is all new to me.......and I am a bit lost but I will get there. Regards, Paul
-----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Stephen Kobrin Sent: Tuesday, August 19, 2008 2:14 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] color profiler Can someone recommend a reasonably priced color profiling system? I do not need a high end model, just one that will give me a reasonable equivalence between the screen and the print? Also, a question: can I profile two different screens run from a single computer? Thanks for any suggestions. Steve [Non-text portions of this message have been removed]
2008-08-19 by Richard Smallfield
Hi, I don't know which systems can profile dual monitors, but if you only need one calibrated monitor at a time, you can download the "Monitor Profile" icc loader program from X-Rite that lets you select the profile you want to use for your monitor. And then just switch between profiles as needed. A free work-around, at any rate. Good luck, Richard At 09:13 a.m. Wednesday 20/08/2008, you wrote: >Can someone recommend a reasonably priced color profiling system? I do not need a high >end model, just one that will give me a reasonable equivalence between the screen and the >print? > >Also, a question: can I profile two different screens run from a single computer? > >Thanks for any suggestions. > >Steve > > Richard Smallfield Photography http://smallfield.vze.com "A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty. " --Sir Winston Churchill (1874-1965) [Non-text portions of this message have been removed]
2008-08-20 by Stephen Kobrin
Thanks Richard and Paul. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard Smallfield <r.smallfield@...> wrote: > > Hi, > I don't know which systems can profile dual monitors, but if you only need one calibrated monitor at a time, you can download the "Monitor Profile" icc loader program from X-Rite that lets you select the profile you want to use for your monitor. And then just switch between profiles as needed. > > A free work-around, at any rate. > > Good luck, > Richard > > At 09:13 a.m. Wednesday 20/08/2008, you wrote: > > >Can someone recommend a reasonably priced color profiling system? I do not need a high > >end model, just one that will give me a reasonable equivalence between the screen and the > >print? > > > >Also, a question: can I profile two different screens run from a single computer?
> > > >Thanks for any suggestions. > > > >Steve > > > > > > Richard Smallfield Photography > http://smallfield.vze.com > > "A pessimist sees the difficulty in every opportunity; > an optimist sees the opportunity in every difficulty. " > --Sir Winston Churchill (1874-1965) > > > [Non-text portions of this message have been removed] >
2008-08-20 by John Vitollo
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen Kobrin" <kobrins@...> wrote: > > Can someone recommend a reasonably priced color profiling system? I do not need a high > end model, just one that will give me a reasonable equivalence between the screen and the > print? DataColor's Spyder3Studio produces better paper profiles than the ColorMunki...about the same price point. > Also, a question: can I profile two different screens run from a single computer? If you are on a Mac multi monitor support is built-in. On Windows depends on graphic card installed and OS.
2008-08-20 by CDTobie@aol.com
In a message dated 8/20/08 9:57:21 AM, jvlist@... writes:
> computer?
> graphic card
> installed and OS.
There is seldom a problem under Windows if you use two (or more) separate
videocards; its when you try to profile two displays on the same card that the
answer is "maybe"... based mostly on which card.
C. David Tobie
WW Product Technology Manager
Digital Imaging & Home Theater
Datacolor
CDTobie@...
www.datacolor.com/Spyder3
It's only a deal if it's where you
want to go. Find your travel deal here.
(http://information.travel.aol.com/deals?ncid=aoltrv00050000000047)
[Non-text portions of this message have been removed]2008-08-20 by davelasker
I own a PrintFix Pro (same printer profiler hardware as in Spyder3Studio) and have upgraded it to Datacolor's latest software. I have found its profiles to be "OK", but for the papers I have tried to profile, I have perferred the profiles generated by others (usually made using Xrite/GretagMacbeth i1Photo). Discliamer: my results were in color and this is a B/W group. I had considered trying ColorMunki, so I am curious as to the source of your belief that Spyder3Studio gives better results than ColorMunki. Is this based on personal experience, or reviews read elsewhere? Thanks for the help! Dave --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Vitollo" < > DataColor's Spyder3Studio produces better paper profiles than the ColorMunki...about the same price point.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "davelasker" <dave@...> wrote: > > I had considered trying ColorMunki, so I am curious as to the source of > your belief that Spyder3Studio gives better results than ColorMunki. Is > this based on personal experience, or reviews read elsewhere? I only own the PrintFixPro 2 but very happy with the paper profiles it produces. Before PFP I used Bill Atkinson's profiles....but find PFP profiles "more better". I've never used the ColorMunki, but have read the reviews of the ColorMunki profiles and they are a notch below PFP.
In a message dated 8/20/08 1:07:26 PM, jvlist@... writes:
> profiles and
As you note, comparison articles have drawn that conclusion. I can agree,
from my own testing.
Its also worth noting that ColorMunki software is intentionally limited;
there are no settings possible for display profiling or printer profiling, so even
if the default results aren't bad, over time a user is likely to want more
adjustability, more advanced options etc; which would be available from Spyder3
products, but with the ColorMunki, you have no options available, and no
upgrade capabilities, you have to move up to a different product line. The
Spyder3Studio feature set is much more like that of the much more expensive EyeOne
product line, while the price is much closer to the ColorMunki, so for those
interested in features and controls at an affordable price, its quite compelling.
C. David Tobie
Datacolor
CDTobie@...
[Non-text portions of this message have been removed]2008-08-20 by CDTobie@aol.com
In a message dated 8/20/08 12:46:40 PM, dave@... writes:
ColorMunki works with a limited number of color patches. So its results are
more similar to Spyder3Print at 150 patches (I'm being generous, the ColorMunki
uses 50 or 100 patches), than what Spyder3Print offers at 225, 729 or other
advanced target choices. The ColorMunki results are also limited to working
with the Perceptual intent, unless you are in an Adobe application that offers
Black Point Compensation. A print made from Relative Colorimetric without
Adobe's BPC function is severely clogged in the shadows. Actually, ColorMunki
shadows are a bit too clogged for my taste at ANY setting. The real problem is that
there are no controls for this; if I want more open shadows in a Spyder3Print
or PrintFIX PRO profile (or make any number of other adjustments), I move a
slider, and rebuild the profile in four seconds. There are not adjustment
options with ColorMunki.
C. David Tobie
Datacolor
CDTobie@...
[Non-text portions of this message have been removed]2008-08-22 by donbga
John, > I've never used the ColorMunki, but have read the reviews of the ColorMunki profiles and > they are a notch below PFP. > Do you recall where you read about that comparison? Andrew Rodney thought the profiles created by Colormunki are pretty good. Thanks, Don Bryant
2008-08-22 by Paul Grant
I have not used the Color Munki for b/w. I can tell you that for color it made a ³Substantial² improvement for me on the 2200 with standard ink. On the 3800 there was a ³Noticeable² improvement. Next I will see how it works on b/w. Paul On 8/21/08 8:30 PM, "donbga" <dsbryant@bellsouth.net> wrote: > > > > John, > >> > I've never used the ColorMunki, but have read the reviews of the > ColorMunki profiles and >> > they are a notch below PFP. >> > > > Do you recall where you read about that comparison? > > Andrew Rodney thought the profiles created by Colormunki are pretty > good. > > Thanks, > > Don Bryant > > > [Non-text portions of this message have been removed]
2008-08-22 by John Vitollo
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "donbga" <dsbryant@...> wrote: > > John, > > > I've never used the ColorMunki, but have read the reviews of the > ColorMunki profiles and > > they are a notch below PFP. > > > > Do you recall where you read about that comparison? > > Andrew Rodney thought the profiles created by Colormunki are pretty > good. Hi Don, Here's one... Keith's: http://www.northlight-images.co.uk/reviews/profiling/colormunki.html Keith wrote "The printer profiling produced very usable results on my standard 'awkward' test printer - an HP K80 with third party inks, 3rd party photo paper and using open source drivers on an Apple Mac. Not exhibition quality stuff, but if it can get a reasonable profile from that lot then it shows promise." There was another via Apple's colorsync group done by a color guru...can't find it at this time and rated PFP paper provfiles better than the ColorMunki. > Andrew Rodney thought the profiles created by Colormunki are pretty good. Well he's a consultant with them... Of course David Tobe works for DataVision. I work for only myself! 8-}
