Can one make a decent print on Photo Rag with the 3800?
2008-09-05 by Igor Wesdorp
Hello everyone.
I just bought me a 3800 and printed some step wedges on Photo Rag with
ABW. Then I measured them with a densitometer. But the results were
not good. See the graph at http://www.xs4all.nl/~hc6/3800/3800.htm
Although the largest part of the curve is smooth, the darkest parts
are bad, with no differentation between the 2 darkest steps.
My settings were:
PS CS:
- Print space/Profile/ Printer color management.
- Working space: gray Gamma 2.2.
Epson:
- Media type: Velvet Fine Art Paper
Epson ABW:
- Tone: Dark.
- No further adjustments.
I also did a print on Velvet Fine Art Paper, which looked good, but I
want to use Photo Rag.
Could anyone, please, give me the right settings for printing B&W on
Photo Rag with the 3800? (if it is possible to make a good print on
this paper with the 3800)
Thank you,
Igor
Re: [Digital BW] Can one make a decent print on Photo Rag with the 3800?
2008-09-05 by Michael King
Your problem is your paper setting.
Did you check which paper setting is recommended for Photo Rag by
Hahnemühle?
I would use the same paper setting for ABW set to normal.
Also for a great result you need to use QTR Create ICC - Google it.
Mike
2008/9/5 Igor Wesdorp <iwesdorp@...>
>   Hello everyone.
> My settings were:
> PS CS:
> Epson:
> Epson ABW:
> - Tone: Dark.
> Thank you,
> Igor
Re: Can one make a decent print on Photo Rag with the 3800?
2008-09-06 by Clayton Jones
Hello Igor,
Please try the settings outlined in article #9 at the link below.
It's for a 2400 but should work with the 3800.
Clayton
I-Trak 2.1   http://www.cjcom.net/itrak.htm
2008-09-06 by Igor Wesdorp
Mike,
Hahnemühle? I would use the same paper setting for ABW set to normal.
Hahnemühle* recommends "Velvet File Art" as paper setting for all its
fine art
papers. So this is what I used, and wether I print with Tone/Dark,
Normal or Light, the blacks remain crappy, with no or hardly visible
separation between the 2 darkest steps in the wedge.
http://www.hahnemuehle.com/media/downloads/62/Print_Instruction_Epson.pdf
> Also for a great result you need to use QTR Create ICC .
Yes, they say it's good. However, I was hoping to get good results
without having to engage in using a RIP and/or making ICC (which I've
never done before and will cost me a lot of time to figure out).  I
also thought that since K3 is a widely used inkset and Photo Rag a
popular paper, the right settings to use this combination had long
been found by others. But maybe I can't be done, making good B&W
prints with the 3800 on Photo Rag without using a RIP.
Igor
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Michael King"
> Hahnemühle?
> Mike
> >   Hello everyone.
> > My settings were:
> > PS CS:
> > Epson:
> > Epson ABW:
> > - Tone: Dark.
> > Thank you,
> > Igor
Re: [Digital BW] Re: Can one make a decent print on Photo Rag with the 3800?
2008-09-06 by Michael King
Ok so that recommendation is crap VFA is far too heavy ink load for HPR
which is why you have the shadows problem.
The 4800 recommendation is the following - try using that - I find it works
fine on 4800 and I am sure it will be good for 3800.
Watercolor Paper - Radiant White, 1440 dpi, Matte Black, Perceptual
Without a profile set to ABW to "dark". This is approximately correct for a
gamma 2.2 image.
If you take the trouble to build a profile use normal setting. Its trivial
to build a profile as you have a spectro and you can still use ABW with it.
Mike
2008/9/6 Igor Wesdorp <iwesdorp@...>
>   Mike,
> fine art
> Igor
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com<DigitalBlackandWhiteThePrint%40yahoogroups.com>,
> "Michael King"
> > Hahnemühle?
> > Mike
> > > Hello everyone.
> > > My settings were:
> > > PS CS:
> > > Epson:
> > > Epson ABW:
> > > - Tone: Dark.
> > > Thank you,
> > > Igor
Mike,
Thanks for your reply. About your advice:
1) Does 1440 dpi (instead of 2880) also affects the tone? I thought it
only related to sharpness.
(Btw, I upgraded to driver v 6.5, which has a somewhat different
interface. The options for Dpi are "Superphoto 2880x1440 dpi" or
"Superfine 1440x720 dpi")
2) About Intent/Perceptual: following the advice on the site of Eric
Chan, I
switched off the Color Management in PS. In PS CS, which is what I
use, that can be done by, in the Print Preview, choosing "Printer
color management" in the Print space/Profile menu. But if I do so, the
Intent is grayed out, so I can not set it to "Perceptual".
So what should I do? Leave the Print preview settings as described? of
choose some profile(which one?)and set Intent to "Perceptual"?
3) > Its trivial to build a profile.
By trivial, you mean easy? (sorry, english is not my native language)
Igor
it works
correct for a
> gamma 2.2 image.
trivial
with it.
> Mike
> >   Mike,
> > fine art
> > Igor
> > --- In
> > "Michael King"
> > > Hahnemühle?
> > > Mike
> > > 2008/9/5 Igor Wesdorp <iwesdorp@>
> > > > Hello everyone.
Rag with
were
parts
> > > > My settings were:
> > > > PS CS:
> > > > Epson:
> > > > Epson ABW:
> > > > - Tone: Dark.
good, but I
B&W on
print on
> > > > Thank you,
> > > > Igor
2880 uses more ink - tone changes with printer settings.
Try both.
> Chan, I
If you are not using a QTR create icc profile then don't worry about
"perceptual" etc. just do as Eric says.
Yes easy. Just print 51 step profile included in QTR package.
Read with spectro and then drop resulting file on QTR create ICC program
icon.
Done....
> Thanks,
> Igor
> "Michael King"
> it works
> correct for a
> > gamma 2.2 image.
> trivial
> with it.
> > Mike
> > > Mike,
> > > fine art
> > > Igor
> > > --- In
> > > "Michael King"
> > > > Hahnemühle?
> > > > Mike
> > > > > Hello everyone.
> Rag with
> were
> parts
> > > > > My settings were:
> > > > > PS CS:
> > > > > Epson:
> > > > > Epson ABW:
> > > > > - Tone: Dark.
> good, but I
> B&W on
> print on
> > > > > Thank you,
> > > > > Igor
2008-09-06 by John Vitollo
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Michael King" <drmrking@...> wrote:
Good info...also...
Try exploring other media settings to open shadows...
Don't know if the 3800 has a media setting for "Ultra Smooth", but try that.
I did a test some time ago to find the "best" media setting for William Turner paper on my Epson 4800.
Epson's black usually comes in hard and fast, less so with the newest printers, and I wanted to find the media setting that has
smoothest black ramp from 100% to 90%.
I printed a ten patch gray ramp from 100% to 90% with five media settings.
My Excel results are below for William Turner on the Epson 4800:
http://homepage.mac.com/johnvito/WilliamTurnerMediaSettings.png
From 100% to 90% only two media settings show fairly smooth linear density loss, albeit stepped at times -Ultra Smooth and
WaterColor media settings. While the other three actually have spiked increases in density - called reversals - on some patches.
For example Epson's Enhanced media setting has the same density at the following patches: 100%, 99% and 97%. The 98% patch
has a lower density than 97% patch and another reversal at 94%.
My chart does show VFA media setting is crap...as Mike put it!
My media setting choice for William Turner was UltraSmooth as it has the most smoothest linear path. If I was building a custom
paper profile, the profile would have less heavy lifting to do once the "best media type" is found.
Thanks, Mike.
I tried the Watercolor Paper - Radiant White setting, but for some
reason it won't print: once every minute or so the printer makes  a
noice as if the print head moves, but nothing happens, nothing is
printed. It seemed to go on forever, and I could only stop it by
pressing the power button on the printer, thereby switching it of.
Very strange. This happened to me a couple of times and from 2 PC's:
one with driver v5.51 (came on CDRom), and one with driver v6.5 (from
the Epson site).
I'll seriously consider QTR. Although I have a densitometer (X-rite),
not a spectrophotometer. But I guess that will do the job as well.
I g o r
> Try both.
> > Chan, I
> icon.
> Done....
> > Thanks,
> > Igor
> > --- In
> > "Michael King"
for HPR
> > it works
> > correct for a
> > > gamma 2.2 image.
> > trivial
> > with it.
> > > Mike
> > > 2008/9/6 Igor Wesdorp <iwesdorp@>
> > > > Mike,
Rag by
normal.
all its
> > > > fine art
visible
(which I've
> > > > Igor
> > > > --- In
> > > > "Michael King"
Rag by
> > > > > Hahnemühle?
Google it.
> > > > > Mike
> > > > > > Hello everyone.
> > Rag with
> > were
> > parts
> > > > > > My settings were:
> > > > > > PS CS:
> > > > > > Epson:
> > > > > > Epson ABW:
> > > > > > - Tone: Dark.
> > good, but I
> > B&W on
> > print on
> > > > > > Thank you,
> > > > > > Igor
2008-09-06 by Ernst Dinkla
> Try both.
The 3800 is the first Epson model that has the same paper
specific ICC profile for different print resolutions. Unlike
the 17" models and wider formats before it where every
resolution has its own ICC profile. My guess is that it uses
some firmware curve control to make the ink laid down equal
between selected resolutions. There's more changed in
dithering patterns too between the 4x00 and the 3800 models.
http://people.csail.mit.edu/ericchan/dp/Epson3800/faq.html
Met vriendelijke groeten,  Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
John,
You were right, the Ultra smooth fine art paper setting did indeed
give me one of the best results thusfar (next to Clayton Jones'
workflow), so it works for printing on Photo Rag too.
Your story about Epson's black was very reassuring to me: I see now
that I'm not the only one who encountered this problem. I had some
'reversals' too, like you.
What really puzzles me is that printing with K3 on PhotoRag apparently
still hasn't been figured out properly. Is there nobody out here who
has the recipe and/or profile for a good result? (I tried the profile
Eric Chan made, but it didn't work for me. Maybe I did something wrong).
I´ll have to work on it. But I have not decided yet if I will be using
adjustment curve layers to tweak the photo prior to printing. Or maybe
I should use QTR to create ICC profiles. They say QTR is good and not
too difficult.
Igor
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Vitollo"
for HPR
it works
> Good info...also...
try that.
settings.
> Also check the Dark tone setting
I did, but thanks anyway.
Vriendelijke groeten* to you, too, Ernst.
* Dutch for: kind regards
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
<edinkla@...> wrote:
> Also check the Dark tone setting instead of the default
> darker Tone setting. Chan refers to that on the same webpage.
> No 3800 here but just interested.
> |             ( unvollendet )            |
2008-09-06 by the_des_bois
Can I use this thread to ask a question I have never found a specific
answer to?
It relates to the media settings, discussed here in part.
Is there an article or a book that would describe what the Epson media
settings really do? I know they influence ink load in some way,
probably dither pattern... but this is all guessing and testing for
me. I know they (except for the 3800) related to specific profiles.
But how do they relate?
Many questions I have, few answers I have found. I am sure many people
are in the same darkness as I am...
Thanks for any reading suggestions or direct help!
Denis
for HPR
it works
2008-09-06 by Cdtobie
Media settings relate to ink loading and balancing. Possibly to
dithering in some instances. They relate to specific ICC profiles only
in that the profiles are built to work using the "same-name" media
setting. Usually ( but not always) this media setting is also optimal
for building your own custom profiles.
C. D. Tobie
WW Product Technology Mngr.
Digital Imaging & Home Theater
DataColor.com
CDTobie@...
On Sep 6, 2008, at 5:17 PM, "the_des_bois" <thedesbois@...>
> answer to?
> Denis
> for HPR
> it works
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages
> to keep them short.
> flames. Hostile, aggressive or argumentative users may be removed
> from the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See “Group Topic, Rules and Guidelines” in the
>  Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNE
> R” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT
> BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONS
> EQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGE
> S FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSE
> S (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), R
> ESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, T
> HE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF Y
> OUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MA
> TTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
