GLOP idea
GLOP idea
2008-11-06 by Richard Smallfield
I'm sure someone has thought of this before, but here goes:
Currently I love the look of FB lustre prints - but - there's bronzing and gloss differential (esp with my original ultrachromes). To kill that, I've been spraying - but am phasing this out because of the toxicity, even if that means no more lustre papers.
So: here's my idea: why not buy cartridge of GLOP from MIS and put it in the K position - then, after doing the print, print again a black 'image' of the same dimensions, over the top of the print - the printer thinks it's printing black, but actually it's GLOP.
You could do a batch of prints and then run them all through the printer and get rid of the gloss differential and bronzing.
If one has an inkset that doesn't have a GLOP position, this sounds feasible to me - at least, in a 13" printer that won't waste a lot of ink with the cartridge swap.
Richard
www.richardsmallfield.com
   "Opportunities multiply as they are seized."
   --Sun Tzu
Re: [Digital BW] GLOP idea
2008-11-06 by Michael King
Yes this is an option. The challange is alignment.
You can't get a perfect alignment with an overprint. So you have to either
accept some misregistration or print glop borderless over the whole sheet
(messy) or print a glop border round the print.
I've tried the GLOP approach and the spray approach. I'm actually sticking
with spray because I only do a light spray on Fibre Silk to reduce the GD
and I target it at the white areas of the print.
Mike
2008/11/6 Richard Smallfield <r.smallfield@...>
>   Hi,
> Richard
> --Sun Tzu
2008-11-06 by Ernst Dinkla
Richard Smallfield wrote:
> Hi,
> Richard
And the least likely channel you want to use for an
overspray varnish is a black channel.
Met vriendelijke groeten, Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
Hi Ernst,
would you use the yellow channel then?
To make sure you only print yellow and no other colours I presume you make a CMYK image with only the Y in it.
thanks for that,
Richard
   "Basically, I no longer work for anything but the
   sensation I have while working."
   --Albert Giacometti (sculptor)
Re: GLOP idea
2008-11-06 by pr_roark
Richard,
Carl, Tyler and I, probably among others, were experimenting with this
approach when we were all excited about the new generation of glossy
papers.  I have some information posted in the 1800 write up, noted in
my last post.  See http://www.paulroark.com/BW-Info/3MK-Glossy.pdf
I stopped experimenting with the approach due to several problems,
clogs and fouled exit rollers among them.  MIS experimented with the
idea years ago and also stopped -- not sure what their issues were.
The results can be impressive if you can control such things as pizza
wheel marks and the problems with the printer.
Re: GLOP idea
2008-11-06 by djon43
Richard...to simulate photo-silkscreen, I found multiple passes on the
same paper to have maybe 1/8" registration variation (back when my
2200 was still new :-)
...  you could do what you have in mind with a photoshop-created
"black"/glop rectangle in a glop-only pass. However, based only on my
machine I'd expect a 1/8" registration issue...irrelevant if you cover
the edge of the glop with a matte...
...also, someone once suggested keeping a second 2100/2200 as a
glop-only printer (maybe a 1270/80 would serve?) :-)
...also, the glop examples I've seen have sometimes had subtle pizza
wheel issues, but the fix for that's evidently easy.
John
... the printer thinks it's printing black, but actually it's GLOP.
2008-11-06 by brouwerkent
Regarding the glop, here is my solution.  I have the Glop in the
yellow channel.  Using QTR, I made a reverse curve for that channel so
that the highlights get the maximum amount of glop...and the shadows
get no Glop.
Seems to work just fine.  Gloss differential is still there but much
reduced.  I am using Ilford Gold Fibre.
Since so little ink is used for the highlights, I suspect I could
increase the limit of the Glop to completely eliminate the Gloss
Differential.  I simply have not gone to the limit of over using the
Glop...as I did not want to over ink and end up with a mucky mess.
Since the Glop is clear, no way to know for sure what the ink limit
is.  I just set it by looking at my lighter ink limits.
Phil
> Hi Ernst,
> thanks for that,
> Richard
Yellow, Light Cyan. This has been discussed before,
suggestions like using a dedicated machine for the gloss,
possibly using more channels. Not to mention a warm and cool
varnish.
|             ( unvollendet )            |
Re: GLOP idea
2008-11-06 by the_des_bois
Why not spray GLOP? Using the special spray guns L... ? Or airbrush or
just hair salon spray bottle?
Denis
Re: [Digital BW] Re: GLOP idea
2008-11-06 by Pacific New Media
Any spray gun(s) can be suggested to try this?
- Philip
> Denis
Re: GLOP idea
2008-11-06 by Tyler Boley
yes that's right, still playing with it on all kinds of papers. Those
K7 samples I sent out last spring all had a GO only second pass.
Registration is no problem if you are doing a solid tone. Just make
your GO shape larger than the image is, having left yourself plenty of
white margin initially... you may have problems printing on a sheet
with existing image depending on printer model.
Have not yet used it for anything I can offer in production, but a few
special projects have worked nicely with it.
Tyler
http://www.custom-digital.com/
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
<pr_roark@...> wrote:
> Richard,
> Paul
> www.PaulRoark.com
2008-11-06 by James W Veenstra
I think this is basically what my z3100ps GP does with its 12th head
of "gloss enhancer".  J Vee
On Nov 6, 2008, at 6:52 AM, Richard Smallfield wrote:
> Hi,
> Richard
> --Sun Tzu
Basically yes but with a difference. I own a Z3100 too. The
difference is that the Z3100 will lay down the gloss
enhancer right with the other inks, like the Epson
R800/1800. In the case discussed the gloss enhancer is laid
down in a second print run after the image is printed. In
theory one could lay down more gloss enhancer that way as
the printed image could dry in between. In practice the
Z3100 already lays down enough gloss enhancer. On top of
that the Z3200 adds control of the amount of gloss enhancer
applied. The other advantage of the Z3100/Z3200 in applying
the gloss enhancer is the direct register when using the
Economy Mode, only the image gets gloss enhancer, not the
margins around. That is a lot more difficult with two print
runs.
|             ( unvollendet )            |
no, that's not what I was doing. A spot channel was used for GO in the
intial pass with the image, totally controllable in all parts of the
scale. Unfortunately in the papers that I like, that is not enough,
nor is it with the Z. Probably due to all going down wet together.
Hence the second pass, which completed the look. The complexities of
this kind of printing became a bit overwhelming, and all kinds of
obscure details, completely different for each paper, became major issues.
Spraying seems far more effective from what I have seen from Mark
Savoia and John Dean, but I can not do that in a commercial (though
minute) environment.
Using a printer as an overprint system though, is very conventient.
I wouldn't mind having an old 7000 or 9000 around just for that kind
of thing.
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
> runs.
> |             ( unvollendet )            |
2008-11-06 by john dean
Well he's got a point Ernst, the Z does lay down gloss enhancer
superbly for the rc papers, especially their Pro Satin that is totally
worked out. However, it is NOT always enough for the fiber gloss
media. Personally I've experienced great resuts with most of these
papers on the Z for color but more often than not with the fiber gloss
media and black and white, there is NOT enough go laid down, resulting
in very objectionable (to me) gloss differiental.( yea you wouldn't
see it behind glass). This varies significantly with various media.
Such as Harmon fiber gloss not being usable even with color, Innova
some gloss differential with color and bad with black and white,
Ilford Gallerie Gold great with color very bad with black and white
:-(, Crane Silver Rag very good with both color and black and white.
All look good with one strong coat of Premier Art spray, but who needs
that headache for large things.
I just bought the Hahnemuhle Photorag Baryta to try this weekend,
which I hear is a very good fit for everything on the Z, as well as
the new Baryta that HP has designed for their inks that may or may not
be the same paper...?  These might be the answer, along with Crane
Silver Rag.
But, it would indeed be nice if one could run a second pass of the go
inorder to work effectively with all this media. OR, as you say the
Z3200 allows, control of the amount used per media apart from the
other channels. Or Studio Print for 12 inks.
Is there any way that could be controlled on the 3100 apart from a
second run?
John
> runs.
> |             ( unvollendet )            |
2008-11-06 by Jim Goshorn
> Silver Rag.
Even though I do not have a Z, I would be very interested in hearing
your impressions of the Photo Rag Baryta paper.
Jim
I'll let you know on Monday on this list about my luck with the
Photorag Baryta. HP already has media presets and a profile for their
new Baryta so I'll start there first. I think that is going to be the
answer for us and I like what I see of the texture.
In a side note, why one strong coat of the Premier Art spray works far
better than three light coats to eliminate this gloss differential on
these papers is strange. But that does apper to be the case. I"ve done
many both ways. However, we did not get into this business to return
to the nasty world of expensive toxic chemicals.
John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Jim Goshorn
> > Silver Rag.
> Jim
> Silver Rag.
> second run?
Alright, I do not have as much experience with the Fiber
papers and didn't think of them when I wrote that. Collected
several samples that I still have to try. The one that I
tested and like is the Sihl baryta which is closer to matte
than satin and the GE is just right to lift it to semi-satin
in the image. Tested some Innova in the past but rejected
the qualities then on other specs, Innova has new qualities
right now. The rest of my GE experience is with RC papers
and there it is good.
If the Z3200 allows as much control on the GE amount as the
Wasatch SoftRip allows with the Z3100 then I think part of
your problems may be solved but not all. There must be a
limit where the paper doesn't allow too much ink medium as
bleeding will happen. A suitable paper or a double run is
then the answer.
I don't think the two baryta's are the same. Couldn't get a
sample at the HP booth but there was a texture difference if
I recall it correctly and there's weight difference, 290
versus 325 grams, the HP has a buffered fiber but no mention
of cotton content. One would expect the HP version to be
compatible to the Z3100 printers and the printed samples on
the HP booth didn't show gloss differential, I checked that.
Apart from the trick in Economy Mode with an edited profile
to get the RGB 255 covered with GE (or with a print filter
curve in Qimage) there is no way to influence the GE amount
with the Z3100 right now. The RIP does as mentioned but you
wouldn't want that one for the color it produces. Using
another media preset with more ink and limiting the ink
(100-80%) in a custom media preset made of it will probably
reduce the GE as well but I have not tried that. There's
already a 46 to 32 % ink limit present in the various OEM
gloss media presets and I do not know what you have used
already and whether the 14% difference would do the job.
|             ( unvollendet )            |
Re: GLOP idea
2008-11-07 by the_des_bois
Spray gun:
Many use HVLP Spray Guns.
Like this one: http://www.rockler.com/product.cfm?page=10469&cookietest=1
I guess you'd need some sort of compressor.
I've never tried anything in terms of spray guns. One could also look
at airbrush systems also. Compressor needed again.
Denis
Re: GLOP idea
2008-11-07 by john dean
The Wagner is an HVLP, very affordable, that I use and doesn't require
a separate compressor. You can put just about anything in it. It would
certainly work for go and solvent or acrylic coatings. But this is not
the kind of headache most of us see as a permanent answer. It's bad
enough having to do it with canvas all the time.
john
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "the_des_bois"
<thedesbois@...> wrote:
> Spray gun:
> Like this one:
> Denis
Re: GLOP idea
2008-11-07 by Tyler Boley
Hi Ernst, in my experience you are right on several points. These
materials are still in their infancy and there is little consistant
behavior. I would guess that HP as been successful on some fronts by
addressing each of their materials and setups as a complete system,
involved in the development and setup for each, making it work. But,
as soon as us difficult artists decide we like some other materials
and pop that into the mix, it may underperform.
I just completed some successful tests with an inkset with GO for the
IGFS which looked great, then out of curiousity ran a sheet through of
Innova Ultrasmooth. The ink+GO literally ran off the paper. The Ilford
could take higher densities of light inks and required high amounts of
GO in the highlights, all of which it could take. The Innova could not
take it, so severe limiting of light inks and starting from scratch on
the GO channel would be required, it doesn't need as much in the
highlights..
As you note, that's a lot of fluid that needs to be balanced AND
perform well photographically. Then every paper is different.
This is why, in another thread, I said gloss papers weren't as sharp
as our best matte coatings- only because we can't get high
concentrations of light inks on the paper to pass on close dot
description of the info in the file, without bleed or mottle. Wider
spaced dots, therefore darker inks higher in the scale, are necessary
with the photo materials I've tested. Again, this may not be an issue
visually for many people, setups, or source material..
So while I think the HP has been very successful at addressing some of
this, particularly with their own materials, in general the photo
materials are still very particular and hard to work with. I'm sure
things will improve. It amazes me how different things are in terms of
materials we thought were commonplace some years back, that don't even
exist any more.
Tyler
> > Silver Rag.
> > second run?
> then the answer.
> |             ( unvollendet )            |
