HP Vivera pigments
HP Vivera pigments
2008-12-04 by pr_roark
I put some links to HP Material Data Safety Sheets and other
information, as well as some of my notes on these inks at
http://www.paulroark.com/BW-Info/HP-Vivera-Notes.pdf
Needless to say, HP appears to have done a terrific job here.
Re: HP Vivera pigments
2008-12-04 by scott_now_coming
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
> Paul
> www.PaulRoark.com
VERY interesting.... HP's using triethanolamine. The main chemical of
my favorite film developer, which was a pyro developer. Here's a link
if your curious:
http://www.photoformulary.com/DesktopModules/StoreProductDetails.aspx?
productID=85&tabid=9&tabindex=2&categoryid=31&selection=0&langId=0
Scott
Re: [Digital BW] HP Vivera pigments
2008-12-04 by Ernst Dinkla
> Paul
> www.PaulRoark.com
Paul,
the link in the article:
http://www.paulroark.com/BWInfo/Pigment-Stabilization.pdf
seems to be disconnected.
Wonder if the article you refer to is:
http://www.paulroark.com/BW-Info/R1800-Lightfastness.pdf
Steric, isn't that related to fatty acids: butyrates
(butteracid in my Dutch conscience) ?
This one a  basic ingedient of ABS "the stronger styrene
plastic".
Styrenes that all yellow in time.
Didn't expect a styrene component in the pigment
encapsulation, acrylic, PVA, are all more clear and stay
more clear. My first silkscreen waterbased ink (dispersion)
made by Unico was based on an acrylic/styrene mix but I
thought at that time that the styrene was added to reduce
the ingredient costs. It probably is more related to the
behaviour as a pigment particle in the dispersion than to
their color quality.
Checking it on a wider brain,
I see the butyrate is used in mixes of acrylic and styrene
for the encapsulation, BASF people,
http://pubs.acs.org/doi/abs/10.1021/la015734j
Nothing on Electrosteric in Wikipedia but this one gives the
more general overview:
http://www.patentstorm.us/patents/5639296/description.html
On more water in the Vivera ink, there will be more water
vaporised in the thermohead than it is in a pi\ufffdzohead, at
least the technology suggests that. What lands on the paper
may be of equal rheology compared to the Epson inks. Some
ingredients will have to do with the different jet
technology and the head's materials they come in contact with.
Some thoughts on using Vivera inks that lingered in my head
longer than today:
The use of Vivera inks (or V7 mixes made of them :-) in
pi\ufffdzohead designs must be possible while the other way
around Epson inks in HP heads is less likely to work
consistently. The higher water content may be an obstacle
given their use in a pi\ufffdzohead. You gave the MSDS sheets for
all monochromes but the gloss enhancer which could be a part
of a V7 mix. Big carts of the monochrome inks (but the GE
cart) are available for the Z6100, 750 ML the price drops to
approximately 20-25 Eurocents a ML without VAT. The twin
pack 130 ML carts (260 ML) of GE will be something like 30
Eurocents a ML.
There's a reason for using pi\ufffdzoheads as the alternative
quad drivers (QTR for example) for HP models do not exist. A
pity as the head technology in the B9180 is really good and
the heads are user replaceable. Anyway that B9180 already
makes a very nice matte B&W print with the Vivera pigment
inks it uses. The same heads I have in my Z3100 and not one
replaced in 20 months and no clog problem either. Maybe QTR
will one day cover the HP models as well.
Met vriendelijke groeten, Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
Ernst,
It seems to be working for me now.
I don't know.  It seems to be used in the stabilization literature to
refer to a method of stabilization that basically uses long polymer
surfactants to suround the particles and keep them apart.
I do think yellowing of these stabilization components is an issue.
I assume they are essentially clear at first, but UV typically seems
to break bonds and often the result is some yellowness.
> ... acrylic, PVA, are all more clear and stay
> more clear...
I'll check these out later today.
Have you seen anything with respect to the pH of the Vivera inks?  (I
don't have a meter and litmus paper in ink is probably not going to
work.)
> Some
Yes, very much so I suspect.  Have you compared or seen anything
relating to the viscosity of the HP inks to Epson's?
> piëzohead designs must be possible ...
I see we're thinking alike.  I've ordered some grey to check out.
> given their use in a piëzohead.
I'll check viscosity first.  It it is close, we'll see how the grey
prints in an Epson.
> of a V7 mix.
The Gloss Enhander is at
http://www.hp.com/hpinfo/globalcitizenship/environment/productdata/pdf
/ij_c9447a_us_eng_v1.pdf
The full list of MSDSs is at
http://www.hp.com/hpinfo/globalcitizenship/environment/productdata/ijm
sdsuseng.html?jumpid=reg_R1002_USEN
The gloss enhancer is slightly different than the inks.  There are
some polymer salts in it that might make it not work as a dilution
base, but I'm sure I don't know.  It would probably be a lot faster
for me to try "give it a spin" and see what happens.
> There's a reason for using piëzoheads as the alternative
> quad drivers (QTR for example) for HP models do not exist. ..
Also, there are a lot of old Epsons out there that people might be
able to turn into very good carbon printers.  I've got the K and 2%
ends fairly nailed for my matte 100% carbon tastes, but for the older
large format printers the middle densities are presenting some
problems.  If the HP greys look good, they might be a solution.
We'll see.
Did you also notice the very low amount of carbon in the HP ink?
They claim their pigments are simply darker.  I know that is one area
where advances were on the horizon.  In any case, the small amount of
carbon makes me curious about the longevity.  I know the Wilhelm
ratings are excellent, but that could be in due to HP's ability to do
greater grey substitution in color and none at all in B&W.  I also
expect that coating technology will ultimately advance to the point
where the coatings are oxygen barriers.  What I'll do is run a test
of the a diluted Eboni against an equal density of the HP grey and
see how they compare.
2008-12-04 by john dean
Might be able to? I've had three old Epsons, including a killer mono
10K with them running with Piezography and QTR and Studio Print for
years. I'm going add a 9600 after the holidays for special mixes. You
buy these inks in bottle form and use funnel fill carts and they are
amazing and even in Epson printers they don't clog at all. As much as
I like the Vivera inks, for matte papers the K7 is way more beautiful
and subtle tonalities, and available in many hues now. I don't see
anything that touches it.
john
> We'll see.
2008-12-04 by Tyler Boley
an emphatic ditto. Last spring Paul sent me a print using one of his
K6 setups that was in the same realm. Otherwise for matte, everything
else is playing catch-up.
Tyler
http://www.custom-digital.com/
> john
> > We'll see.
Paul,
The Vivera B&W ratings are excellent, nothing touches it. I
know the argument that the long black generation and no
composite greys suit the Wilhelm and Image Engineering tests
but on the other hand I have not seen evidence in other test
results yet that the remaining color mixes degrade faster
than the primary colors. What has been mentioned here and
linked to were older dye ink results that went wrong in
composite greys and secondary mixes. Discussed here  not so
long ago in relation to catalytic fading. Anyway if the ink
chemistry and the way to lay them down makes it harder to
fade the B&W prints without sacrificing image quality then
HP did a good job. If better test methods show that the
secondary mixes in color printing still show more fading
than the primaries then there's work to be done, but it may
still be better than Epson's ratings. Canon could have done
or already does the same as HP but the tests score lower
than HP.
|             ( unvollendet )            |
