HP Z3100 Vivera Grey in R1800
2008-12-09 by pr_roark
Looks cool. See Lab readings and scan at http://www.paulroark.com/BW-Info/HP-Grey-EEM.jpg (The 1800 always bands a little with only one channel firing.) A 100% carbon variable tone glossy and matte inkset just might be possible for our Epson printers. Paul www.PaulRoark.com
2008-12-09 by Ernst Dinkla
pr_roark wrote: > Looks cool. > > See Lab readings and scan at > http://www.paulroark.com/BW-Info/HP-Grey-EEM.jpg > > (The 1800 always bands a little with only one channel firing.) > > A 100% carbon variable tone glossy and matte inkset just might be > possible for our Epson printers. > > Paul > www.PaulRoark.com > > The HP sample looks neutral on my screen :-) -- Met vriendelijke groeten,Ernst | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
2008-12-09 by Peter Oksen
Dear Paul, Really interesting. Please tell more. Peter
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of pr_roark Sent: 9. december 2008 08:58 To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] HP Z3100 Vivera Grey in R1800 Looks cool. See Lab readings and scan at http://www.paulroark.com/BW-Info/HP-Grey-EEM.jpg (The 1800 always bands a little with only one channel firing.) A 100% carbon variable tone glossy and matte inkset just might be possible for our Epson printers. Paul www.PaulRoark.com [Non-text portions of this message have been removed]
2008-12-10 by pr_roark
Peter, > > See [Vivera Grey] Lab readings and scan at > > http://www.paulroark.com/BW-Info/HP-Grey-EEM.jpg > > ... > > A 100% carbon variable tone glossy and matte inkset just > > might be possible for our Epson printers. > Really interesting. Please tell more. A really large and very good elephant has entered our B&W arena, and from what I've seen so far, I'd say it -- HP -- has lived up to its reputation for outstating R&D. I'm definitely not opposed to using HP ink if it works in the printers I'm interested in and does a great job. So, I'm going to be looking at what, if anything, HP has brought to the party that we who like to do our own thing can use. My initial reaction is that they probably have the very best cool grey inks at this point. As such, the logical starting place for me would be to simply substitute it for the cool channel of UT14, with MIS warm carbon in the warm channel and glop in the Y position. I'll do some rudimentary compatibility testing first, but the only way to really know what will happen is set up a system and see how it runs. So, I'll probably do just that. In general, I'll stick with off the shelf inks for now. While the viscosity of the HP ink is on the low side for the Epson printers, it's not the lowest I've tested and used. So, I think it's probably within range. For the 1400 UT14-HP all I need is the grey and PK. The 1.5 pl drop gives me smooth enough prints without the LLK (Light Grey). The K2 and K3 printers would want to add that lighter ink, however. I do think the ink needs to be fade tested. I don't doubt Wilhelm's outstanding testing of it at all, and I'll go ahead and start setting up a system before the results of the fade testing are in. Howver, a comparison to what I can do with cheap MIS inks would be of value. They are very good inks also. One has to ask how HP gets carbon cool. The answer is, I believe, that it's all about how the edge of the carbon is treated. My (late) brother (PhD in chemistry with a carbon specialization) indicated that what is going on at the edge of carbon particles is an entire specialty of its own. It's some real complex stuff. While I don't ever expect to understand it all, what I do know also is that most of our fading is oxidation from the edge inward. So, if the edge is where the coolness comes from, then oxygen might get at it and shift its colors even if the image stays within the Wilhelm tolerances for many centuries. So, the my fader is going to be dusted off. For those who want to do only matte printing, it may be that there would be less likelihood for clogging if a matte warm ink was used in the warm channel, as opposed to the MIS UT14 glossy compatible inks. Here, with the HP cool channel, a C6 approach with Epson UC MK looks interesting. Since we may not need to worry as much about getting a print neutral, the extra warmth of the dilute UC MK might be an advantage. What is also an advantage is that it appears to be sterically stabilized as opposed to electrostatically stabilized. Steric stabilization is not nearly as fussy, and it shows in my centrifuge tests. I think it's great if we, in fact, have more B&W ink sources now. Paul www.PaulRoark.com
2008-12-10 by Ernst Dinkla
Paul, I wonder what the Dmax of Vivera MK could be with the 1.5 picoliter droplet of the R1800 compared to the 6 picoliter on the MK head of the Z3100 Z2100 and possibly the B9180 though the last may have smaller droplets from the same head model, no 1.5 at all though. When the use of quad inks in the Z3100 was discussed on the LL forum I mentioned some (2) matte media presets that have that MK,PK,MG, LG and the rest of the matte media presets is done with MK,MG,LG. I'm now printing newspaper stock for a dummy newspaper and the plain paper media preset for it uses MK,PK,MG and no LG. Ink limitation 20 compared to up to 60 for the best quality matte paper coatings. Given the print quality, paper "gray" and the fast bleeding of the newspaper stock a good choice to drop the LG from the preset. -- Met vriendelijke groeten, Ernst | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
Ernst, > I wonder what the Dmax of Vivera MK could be with the 1.5 > picoliter droplet of the R1800 compared to the 6 picoliter > on the MK head of the Z3100 ... What kind of dmax do you get with the Z3100? Frankly, I was initially planning on just buying a PK cart and keeping Eboni as the MK in a 1400 "UT14-HP" setup. I'd love to get a higher dmax, and if there is evidence HP has made a breakthrough there also, I might be tempted. >... some (2) matte media presets ... > that MK,PK,MG, LG and the rest of the matte media presets is > done with MK,MG,LG. While there has been some noise about what a great dmax the 3-MK approach gets on the 1800, the truth is that it's usually the same as what I can get on the 1400 with a rip and a single K. Arches HP is the major exception I've dealt with. Paul www.PaulRoark.com
pr_roark wrote: > Ernst, > >> I wonder what the Dmax of Vivera MK could be with the 1.5 >> picoliter droplet of the R1800 compared to the 6 picoliter >> on the MK head of the Z3100 ... > > What kind of dmax do you get with the Z3100? Black and White mode of the Z3100 driver. On Photorag measured on the QTR 4x21 step target (two extra sheets of Photorag underneath it) an average D 1.772 - L 13.77 On EEM same method D 1.595 - L 18.10 I must have some data from a Colorfoto test of several papers and the big three A3 printer models with the Dmax if I recall it correctly. B9180 included Will dig for it. Most likely measured on ICC controlled color mode which may not be optimal for black Dmax. -- Met vriendelijke groeten, Ernst | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
2008-12-11 by Ernst Dinkla
Ernst Dinkla wrote: > > Black and White mode of the Z3100 driver. > On Photorag measured on the QTR 4x21 step target (two extra > sheets of Photorag underneath it) an average D 1.772 - L 13.77 > On EEM same method D 1.595 - L 18.10 Measured the black of several Z3100 calibration targets lying around here that were made over the past months and for Photorag they all stay above D 1.7. Another matte coating, Albrecht D\ufffdrer equivalent if not the same, was at D 1.75. EEM samples D 1.62 and the same for a dual side coated 190 grams from Magic/Intelicoat. -- Met vriendelijke groeten, Ernst | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
2008-12-11 by pr_roark
I think Eboni can hold it's own, on average, against the HP dmax figures. Right now Eboni is looking like it'll stay my 100% MK. The first centrifuge test results of a C6-base-diluted (1:2) HP Z3100 grey are consistent with it being stable. If anything the top of the test tube darkened (the pigs floated upward). This is consistent with the higher water content and lower specific gravity of the HP ink. Specific gravity is easy to adjust -- glycerol is heavy, glycol medium, water light. My first Iflord Gold Silk HP Grey test print has loads of bronzing, and it's a bit cold for me. HP pigs need a warm carbon toner -- that's easy. LLK &/or LK from UC 7600 or MIS are possible, as is dilute UC MK for matte, and probably others. Note that Epson gloss optimizer uses lots of glycerol. So does the C6 base. We may not make the flowers, but arranging them looks promising. Paul www.PaulRoark.com --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla <edinkla@...> wrote:
> > Ernst Dinkla wrote: > > > > > Black and White mode of the Z3100 driver. > > On Photorag measured on the QTR 4x21 step target (two extra > > sheets of Photorag underneath it) an average D 1.772 - L 13.77 > > On EEM same method D 1.595 - L 18.10 > > > Measured the black of several Z3100 calibration targets > lying around here that were made over the past months and > for Photorag they all stay above D 1.7. Another matte > coating, Albrecht Dürer equivalent if not the same, was at D > 1.75. EEM samples D 1.62 and the same for a dual side coated > 190 grams from Magic/Intelicoat. > > > -- > Met vriendelijke groeten, Ernst > > > | Dinkla Grafische Techniek | > | www.pigment-print.com | > | ( unvollendet ) | >
2008-12-22 by pr_roark
This evidence is probably way too shaky to make any decisions on, but I see enough to raise a yellow flag with respect to the HP grey ink. First, the bottle that I had some in shows the same magenta stain on the sides that I'd expect with a blended carbon-color pigment ink. I've never seen this type of stain on a container that had 100% carbon ink in it. Second, in a very rough, quicky fade test the HP grey ink sample is the only one that is showing measurable warming so far. All I'm suggesting at this point is that the HP grey ink needs serious comparative fade testing against our current dedicated B&W approaches, and it may be way to early to throw out our current B&W approaches. HP may not be 10 feet tall after all. Paul www.PaulRoark.com
I have HP Vivera (Z3100) grey ink (about like a cool LK) in an 1800 and can print test strips for people who might be interested in conducting formal or informal comparative fade tests. Contact me off list. Paul www.PaulRoark.com
2009-01-02 by pr_roark
To update my quick and dirty comparative fade test of Vivera grey v. Eb6, MIS LK, and 3D-LKn, they are all so stable that I can't see any reason to worry about any of them. This was just a draw-down, which is not smooth enough and uniform enough to draw much information from. I assume at this point the HP greys are so stable that I may continue to see what they might be useful for. The ability to make an open source, neutral gloss and matte inkset that is cheap has a certain amount of appeal. Paul www.PaulRoark.com
2009-01-04 by met.graphix
Interesting stuff. BTW Any more evidence of magenta stains with the Vivera Gray? Dario
2009-01-04 by pr_roark
Dario wrote: > > Interesting stuff. BTW Any more evidence of magenta stains with the > Vivera Gray? The bottle some HP grey was is has a magenta stain on it just like the blended or "shaded", neutralized carbon inks I've mixed. So, that remains evidence of some type of coloring. However, the quick and dirty fade test is too close -- too little change -- to draw any conclusions. The initial movements of HP grey, Eboni-6 (18%), MIS LK, and MIS 3D LKN are very small. None of the samples showed a Lab L change. All arguably got slightly cooler, but with the MIS 3D LKn actually showing the least change. But, I know it has colors in it that are not as stable as carbon and it should be warming. It is, relative to the others, but for some reason the others -- 2 or which I've been told are "100% carbon" are actually getting cooler. One possibility is that the edge effect stabilizing substances are warm and burning off, but on the 3D this effect is being offset by the colors also fading. It's just too close to say what is going on in terms of fading or color shifts. Paul www.PaulRoark.com
2009-01-24 by pr_roark
I ran a centrifuge test on few alternative bases for diluting the HP PK. I included the un-altered HP Grey in the test for a control or standard against which to measure the results. The most surprising result of the test is that the HP Grey settled significantly more than my dilutions of the PK. (24 times the change of the buffered new base I'm working on.) This probably because HP has to stay with a lower viscosity ink for the thermal heads. It suggests to me that Epson may still have a bit of an advantage on this front. (Does the HP Z3200 have a way to agitate its carts continuously?) Other results of interest were that the buffered base was more stable than an otherwise identical un-buffered version of the base, consistent with the dogma that electrostatic stabilization is pH sensitive. On the other hand, the sample diluted with the old, un-buffered Carbon-6 base was also very stable, perhaps due to it's slightly higher viscosity and specific gravity. It had a higher glycerol content that any of the other samples. Paul www.PaulRoark.com
2009-01-24 by Ernst Dinkla
pr_roark wrote: > (Does the HP Z3200 have a way to agitate its carts continuously?) The carts are 130 ml on the Z3100/Z3200 and within each is a membrane pump that pumps the ink out from beneath the ink content, the same pump also stirs that ink content above it, more when it can not pump ink away to the head and less when the ink can flow away to the head. There will be a valve in each ink channel that opens on demand like there are on the air pressurised models of Epson. I knew about the cart pump but wasn't sure about its ink stirring so I just cut the top of an empty cart, rinsed the ink out and put clear water in. Actuating the pump a plume of black ink (left in the pump chamber) came from the bottom, less with a syringe needle in the outlet, more without the needle. The Z models go in sleep mode when idle but will awake several times a day to check nozzles etc and it is likely that the pumps are actuated then. Whether thermal heads need lower viscosity inks has to be seen. The HP Latex printer introduced on the Drupa 2008 had thermoheads to my surprise. HP has a pi\ufffdzohead design of its own but decided to use a thermal head. -- Met vriendelijke groeten, Ernst | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
Ernst Dinkla <edinkla@...> wrote: > The carts are 130 ml on the Z3100/Z3200 I was able to pull 140 grams of ink from the Z3100 PK cart. At $67, it's more than I like to pay for ink, but a 30% dilution for "LK" the HP ink cost is right down where it ought to be, and at another 30% dilution for LLK, it's less than any commercially available ink. > ... pump also stirs that ink content above it, ... I thought HP would not let a settling problem go unsolved. >... The Z models go in > sleep mode when idle but will awake several times a day to > check nozzles etc and it is likely that the pumps are > actuated then. I suspect checking the nozzles is actually secondary to stirring the ink, but they probably don't want to advertise that issue. > ... HP has a piëzohead design of its own > but decided to use a thermal head. > They can, apparently, use semiconductor fabrication technology for the thermal heads, which is a huge cost advantage. For the HP-based B&W inkset I'm considering, it looks like I'll end up with 2 dilution bases. The target glycol & glycerol mix is the Epson MK 15% for each. To get there, however, I'll use more in a first 1:1 mix with the HP PK. After that the same 15%-15% base can be use for the other dilutions, working from the 1:1 mix. Contrary to my comment above, I'm not targeting the LK-LLK standards at all (where the traditional 30% dilution is very close with HP PK). I'm working initially to a simple 4-dilution spread: 50%, 20%, 10%, and 5%. That leaves 2 spots for K (Eboni or any PK) and a warm carbon toner in the Y position (probably MIS or UC K2 LLK for glossy or an "LLK" equivalent diluted UC MK for matte, which is my interest). I do need a warm toner to overcome the HP PK's too-cold tone for my tastes. The buffering with TEA and citric acid seems to work. I dilute both to 10% solutions first. Then a 10 TEA to 1 Citric acid ratio seems to hit the target pH. 1% Edwal LFN wetting agent, in addition to the Photo Flo percentage used in the C6 mix, seems to give the final enough surfactant that it's printing smoothly in the 1400 -- on both matte and glossy papers. I'll publish the complete formula later, but so far so good. It pains me a bit to move away from a 100% carbon approach, but I think the settling problems with the Eboni/Carbon-6 are major problems for large format users. (No problems with the desktop printers.) Frankly, the move to an HP based inkset allows me to use un- brightened paper, which I vastly prefer. So, while I won't be able to hit the 100% carbon target with this approach, the overall HP + non-OBA paper will actually be more stable over my lifetime due to the lack of those OBAs, which are by far the main source of tonal instability with either a 100% carbon or HP grey approach. Paul www.PaulRoark.com
2009-01-24 by Tony Sleep
On 24/01/2009 pr_roark wrote: > The most surprising > result of the test is that the HP Grey settled significantly more > than my dilutions of the PK. HP claim their electrostatic encapsulation of pigment maintains dispersion and prevents settling. This may be overwhelmed by a centrifuge, giving a result that does not reflect real life. -- Regards Tony Sleep http://tonysleep.co.uk
Tony Sleep <TonySleep@...> wrote: > On 24/01/2009 pr_roark wrote: ... > > The most surprising result of the test is that the HP > > Grey settled significantly more than my dilutions of the HP PK. > HP claim their electrostatic encapsulation of pigment > maintains dispersion and prevents settling. All inkjet pigments have some form of stabilization coating, even if just an un-attached surfactant. These stop flocculation/agglomeration, but the carbon-based pigments are still heavier than water or the base/medium that is likely used. Brownian motion will help and may be enough to keep the very smallest particles from settling, but from what I can tell, all of our pigmented inks have particles that will ultimately settle or separate if not agitated. The higher the viscosity of the medium or dilutant, the slower they settle. Specific gravity of the medium is also a factor. However, the bottom line is that even with an outstanding stabilization coating, our pigments are still subject to settlement or stratification (particularly multi-pigment mixes) in the medium if left still for long enough. So, while I think HP has an excellent stabilization system, I doubt that by itself is enough. My tests indicate their grey ink likely settles with time. It appears, however, that HP has taken steps to deal with that issue. I certainly would not worry about it if you have or are considering buying an HP printer. > This may be overwhelmed by a centrifuge, giving a > result that does not reflect real life. My real world sample comparisons are not that many, but to the extent I've been able to compare long term settlement in bottles to the results of the centrifuge, they do correlate rather well. The centrifuge is basically just subjecting the samples to 6000 G's and thus accelerating whatever gravity would do. If anything, I suspect it under estimates problems because the longer time in a bottle would allow more flocculation/agglomeration if it were going to occur, and the centrifuge has some vibration which probably tends to mix the samples a bit. Keep in mind that when I say the HP grey pigs settled much more than some of the latest dilutions I'd mixed, I'm still looking at only about a 5% change over what is probably equivalent to 4 months of being still in a bottle. This is not a major problem. But I'm looking at less that a 0.2% change in some of the HP dilutions I'm testing. With this new tool and the best input pigments, I hope to make some mixes that are very stable even in wide format printers -- which has been a problem in the past. We should not have to agitate our carts regularly. Paul www.PaulRoark.com
pr_roark wrote: > Ernst Dinkla <edinkla@...> wrote: > > >> The carts are 130 ml on the Z3100/Z3200 > > I was able to pull 140 grams of ink from the Z3100 PK cart. At $67, > it's more than I like to pay for ink, but a 30% dilution for "LK" the > HP ink cost is right down where it ought to be, and at another 30% > dilution for LLK, it's less than any commercially available ink. Correct, they are in fact overfilled and when declared empty you can be sure that you got the 130 ml. That wasn't so in the past with other manufacturers. The Twin packs = 260 ml are at 0.30 Eurocents (0.40 Dollarcent) a ml without VAT. -- Met vriendelijke groeten,Ernst | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
2009-01-25 by sinar001
The HP Z-series of printers has a built-in ink agitation system. The base of the cart has a soft "rubber bung" that is periodically agitated by the printer. This serves to help keep the pigments in suspension. Also, since the printer has a built-in Spectro, it prompts you to "recalibrate" your media periodically. This is not to be confused with making a new profile. (which the printer also can do) With these two capabilities with in the printer and the "relatively small" ink carts (130 ml), I have yet to notice any deviance in printing results in the 9 months I have used the printer. Of course Ernst has been using his for over 2 years now. It is my understanding that thermal inks have a slightly less viscious consistency compared with piezo inks. Hopefully in mixing with a piezo base during dilution, and the inherently more "forgiving" nature of the piezo print head, printing characteristics of the diluted inks should be satisfactory. But of course use of a base different from HP's might explain why Paul is seeing some settling of his dilutions. HP ink has quite a "unique" odor, due to the co-solvents and glycols they employ. John Nollendorfs --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark" <pr_roark@...> wrote:
> > Tony Sleep <TonySleep@> wrote: > > > On 24/01/2009 pr_roark wrote: ... > > > The most surprising result of the test is that the HP > > > Grey settled significantly more than my dilutions of the HP PK. > > > HP claim their electrostatic encapsulation of pigment > > maintains dispersion and prevents settling. > > All inkjet pigments have some form of stabilization coating, even if > just an un-attached surfactant. These stop > flocculation/agglomeration, but the carbon-based pigments are still > heavier than water or the base/medium that is likely used. Brownian > motion will help and may be enough to keep the very smallest > particles from settling, but from what I can tell, all of our > pigmented inks have particles that will ultimately settle or separate > if not agitated. The higher the viscosity of the medium or dilutant, > the slower they settle. Specific gravity of the medium is also a > factor. However, the bottom line is that even with an outstanding > stabilization coating, our pigments are still subject to settlement > or stratification (particularly multi-pigment mixes) in the medium if > left still for long enough. > > So, while I think HP has an excellent stabilization system, I doubt > that by itself is enough. My tests indicate their grey ink likely > settles with time. It appears, however, that HP has taken steps to > deal with that issue. I certainly would not worry about it if you > have or are considering buying an HP printer.
2009-01-25 by pr_roark
>... use of a base different from HP's might explain why Paul > is seeing some settling of his dilutions. The results are the opposite. The dilutions with the higher viscosity base settle significantly less than the HP OEM grey ink (which is not bad either). > HP ink has quite a "unique" odor, due to the co-solvents and > glycols they employ. It smells like latex paint to me. Paul www.PaulRoark.com
2009-01-25 by Ernst Dinkla
pr_roark wrote: >> HP ink has quite a "unique" odor, due to the co-solvents and >> glycols they employ. > > It smells like latex paint to me. The HP Latex pages describe the cosolvents (next to water) of that outdoor ink type as being very similar to the ones used in the "normal" aqueous inks. They solve the issue of burning in of ink in the thermal heads as well which allows far more ink to be squirted in time by a nozzle than used to be possible in the past. Up to 32 liters now. Latex is a term used for a wide variety of (co)polymers so it doesn't tell much of what is used in the printers but there could be more than the cosolvents that are shared between the printer models. http://www.signweb.com/index.php/channel/2/id/2879 http://www.hp.com/hpinfo/newsroom/press_kits/2008/predrupa/wp_HPLatexInks.pdf there must be an MSDS for the Latex inks. I have some samples of the Latex prints on vinyl, paper etc. The 120 picoliter droplet doesn't deliver the same detail we are used to but it is excellent for the sign market the printers are intended for. I wonder however whether a varnish-gloss enhancer could be based on the same technology and used on the prints we make. The transparency may be lower though but the surface will be a lot tougher. -- Met vriendelijke groeten, Ernst | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
2009-01-28 by pr_roark
Updating my experiments with dilute HP PK, the bottom line is that it's working fine so far. I've tried a number of different bases -- buffered and complex as well as the simple C6 base (see http://www.paulroark.com/BW-Info/Ink- Mixing.pdf ). Frankly, I'm not sure the more complex ones are worth the effort, although 1% Edwal LFN wetting agent will be needed for 1.5 picoliter printers. The C6 base is working best for the 50% dilution, in part, because on, for example, Crane Silver Rag even the 50% dilution prints with a dmax of 2.19. So, while a true PK will do better, it's not going to be worth my time or money to bother with one. Currently I have the HP-C6 in a 220. The Y position is MIS LLK, and the K position is Eboni. The 4 dilutions of HP PK are 50%, 20%, 10%, and 5%. It prints with either the Epson driver or QTR, on matte or glossy paper. The tone with the Epson driver and no curves is relatively neutral, with the MIS LLK offsetting the too-cool (for me) HP PK native tone. So far so good. Paul www.PaulRoark.com
2009-01-31 by pr_roark
I've put the information relating to my dilute HP Vivera PK inkset, which I call "HP-C6" at http://www.paulroark.com/BW-Info/Ink-Mixing.pdf So far so good. Paul www.PaulRoark.com
2009-02-01 by Gary Wagner
Paul, I read your paper. Could the entire dilution be made with HP Vivera PK? Is the issue the cost of HP ink being 4 times the price of Eboni or is there some other issue with doing this? What type of dmax are you getting on Matt paper with your formula? Thanks, Gary Wagner
Sent: Saturday, January 31, 2009 11:06 AM
Subject: [Digital BW] HP Z3100 Vivera PK Inkset ("HP-C6")
So far so good.
[Non-text portions of this message have been removed]2009-02-01 by pr_roark
"Gary Wagner" <gcwagner@...> wrote: > Could the entire dilution be made with HP Vivera PK? I'm not sure what you mean here. In http://www.paulroark.com/BW-Info/Ink-Mixing.pdf I describe one possible inkset that uses 4 dilutions of the HP PK, with Eboni being the MK and an MIS LK being used as a warm carbon toner. One could use just the HP PK dilutions if cool shadows are preferred. Or, as suggested in the PDF, one could set up parallel LK-LLK density dilutions for a warm/cool channel system. > Is the issue the cost of HP ink being 4 times the price > of Eboni or is there some other issue with doing this? Cost is one big factor. However, the thermal head printers like HP's use a lower viscosity ink than the Epson printers. So, one thing I'm doing with the C6 base is raising the viscosity to the Epson range. This also holds the pigments in suspension better. HP apparently has a system of mixing its pigments in the carts rather continuously, which is a feature most of at least the older Epson wide format printers lack, and will not need with this dilution system. While the HP pigments do not settle at a rate that I think is a serious problem, they don't appear to settle hardly at all with the heavier, thicker C6 base. Additionally, the C6 dilution base has been very clog free. I believe this is due to the high glycerol content and lack of any binder. I suspect the diluted HP pigments will clog less than the stock ones. Again, most of us do not have a printer that stays on and runs nozzle checks automatically every so often. > What type of dmax are you getting on Matt paper with your formula? It's standard Eboni MK, so nothing changes there. Based on some dmax figures Ernst provided, I think Eboni is still very competitive. With the new Premier Art Generations Alise line of papers, by the way, mid 1.70's are very realistic. On HPR 1.70 - 1.72 is normal. "EEM" - UPPM hits 1.68- 1.7. Lots of papers are in the mid- 160's. I generally will not use a matte paper that is below 1.6. I try to make the best inkset I can for my own uses, given the materials that are available to me. Cost and quality are both major factors. Additionally, I really dislike clogged or otherwise high- maintenance printers -- and mine sit idle a lot. The HP-C6 looks like a very promising alternative for the neutral B&W prints I prefer. But, it also has not sat in an idle printer for a month. So, it'll be a while before I know for sure whether I want to load it into my 7500. Paul www.PaulRoark.com
