troutfly24
Sent: Saturday, October 17, 2009 1:02 AM
Subject: [Digital BW] Re: Resetting Auto Reset Chips
I have had problems w/this also on the 1400, and what worked for me is to
unplug the printer for 1 full minute, not just a few seconds, then plug it
back in, to reset the chips. I also had to remove and replace the carts when
that didn't work...it is a trial/error because it's diff. each time... but
it does work eventually. Bottom line is you have to do 'both', which makes
no sense, so you are dealing w/tricking some bad coding, in just the right
sequence that you find to work when the moon is at the right angle, and the
tide is just the right height; but at least it is do-able...keep trying, and
it will reset. (w/this printer all the hassle is worth it).
> I have the Eb6 inkset with auto reset chips in my 1400. When the ink level
gets down under 10% and I need to reset the chip do I just turn the printer
off and then on or do I have to remove and re-seat the cart? MIS says to
re-seat the cart but I thought I read here that turning off and on works
too. If I re-seat won't I have to prime the cart again?
> Thanks,
> Tom Husband
