Re: any more ideas for exotic future A100 modules?
2006-05-11 by Adam-V
Hi guys, How about some sort of wave rectifier that offers half and full wave rectification of an audio signal. It would only require one input and four outputs positive half, negative half, full wave positive and full wave negative. Apologies if this is achievable with existing modules, I'm still not up with everything that is currently available. Cheers, Adam-V
2006-05-12 by Dieter Doepfer
With a small modification the A-174 could be used for that (signal leading to the meter wired to an output socket) as it contains a half and full wave rectifier according to the position of the switch. Even the Max/Min module A-172 is working a bit like that (with one input simply connected to GND) and could be combined with the inverter module A-175. But the full wave rectifier is missing in the A-172. Best wishes Dieter Doepfer
> -----Ursprüngliche Nachricht----- > Von: Doepfer_a100@yahoogroups.com > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Adam-V > Gesendet: Freitag, 12. Mai 2006 00:55 > An: Doepfer_a100@yahoogroups.com > Betreff: [Doepfer_a100] Re: any more ideas for exotic future A100 > modules? > > > Hi guys, > > How about some sort of wave rectifier that offers half and full wave > rectification of an audio signal. It would only require one input and > four outputs positive half, negative half, full wave positive and > full wave negative. > > Apologies if this is achievable with existing modules, I'm still not > up with everything that is currently available. > > Cheers, > Adam-V
2006-05-14 by Adam-V
Thanks Dieter. I expect that was meant to be A-197 (Analog Meter) not A-174 (Joystick)! I see that the A-197 is marked as "running out". Is there any likelihood of them selling out in the next few months? If so, are there likely to be any more produced once the current stocks run out? Cheers, Adam --- In Doepfer_a100@yahoogroups.com, "Dieter Doepfer" <hardware@...> wrote: > > With a small modification the A-174 could be used for that (signal leading > to the meter wired to an output socket) as it contains a half and full wave > rectifier according to the position of the switch. > > Even the Max/Min module A-172 is working a bit like that (with one input > simply connected to GND) and could be combined with the inverter module > A-175. But the full wave rectifier is missing in the A-172. >
2006-05-15 by Dieter Doepfer
Adam, right, it's the A-197. The A-197 is running out as the sales are very poor (only a few modules per month) and we are still selling modules from the first series manufactured early in 2004. Consequently it does not make sense to manufacture a new series if the modules in stock are sold out. The only solution for such poor selling modules would be smaller series (e.g. 25 or 50 only) but this would increase the price by about 20-30% as the production charges depend highly upon the production quantity (especially because of the pc boards, the front panels and the assembly installations). So I'd recommend to order an A-197 a.s.a.p. if you are interested as I assume that they will be sold out about fall 2006. Another solution is to find one of the customers who received a free A-197 board early this year (sorry - we have no boards left) and to built the desired rectifier module. Maybe some customers ordered free boards without using them really. You could try to find them in this Yahoo group as the information concering the free pcbs was published in this group only. Maybe Analogue Haven (USA) has some left. Best wishes Dieter Doepfer
> -----Ursprüngliche Nachricht----- > Von: Doepfer_a100@yahoogroups.com > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Adam-V > Gesendet: Sonntag, 14. Mai 2006 05:56 > An: Doepfer_a100@yahoogroups.com > Betreff: [Doepfer_a100] Re: any more ideas for exotic future A100 > modules? > > > Thanks Dieter. > > I expect that was meant to be A-197 (Analog Meter) not A-174 > (Joystick)! I see that the A-197 is marked as "running out". Is > there any likelihood of them selling out in the next few months? If > so, are there likely to be any more produced once the current stocks > run out? > > Cheers, > Adam > --- In Doepfer_a100@yahoogroups.com, "Dieter Doepfer" <hardware@...> > wrote: > > > > With a small modification the A-174 could be used for that (signal > leading > > to the meter wired to an output socket) as it contains a half and > full wave > > rectifier according to the position of the switch. > > > > Even the Max/Min module A-172 is working a bit like that (with one > input > > simply connected to GND) and could be combined with the inverter > module > > A-175. But the full wave rectifier is missing in the A-172. > > > > > > > > > > > Yahoo! Groups Links > > > > > > >
2006-05-15 by Adam-V
Thanks Dieter, I might have to take my chances and see what's available in late August; I'm currently saving every cent for a trip to the UK, Europe and Japan in July/August so I can't really afford to buy any new modules at the moment. If they have run out by then I guess I'll just have to go into DIY mode and build my own rectifier module. Cheers, Adam-V --- In Doepfer_a100@yahoogroups.com, "Dieter Doepfer" <hardware@...> wrote: > > Adam, > > right, it's the A-197. The A-197 is running out as the sales are very poor > (only a few modules per month) and we are still selling modules from the > first series manufactured early in 2004. Consequently it does not make sense > to manufacture a new series if the modules in stock are sold out. The only > solution for such poor selling modules would be smaller series (e.g. 25 or > 50 only) but this would increase the price by about 20-30% as the production > charges depend highly upon the production quantity (especially because of > the pc boards, the front panels and the assembly installations). > > So I'd recommend to order an A-197 a.s.a.p. if you are interested as I > assume that they will be sold out about fall 2006. Another solution is to > find one of the customers who received a free A-197 board early this year > (sorry - we have no boards left) and to built the desired rectifier module. > Maybe some customers ordered free boards without using them really. You > could try to find them in this Yahoo group as the information concering the > free pcbs was published in this group only. Maybe Analogue Haven (USA) has
> some left. > > Best wishes > Dieter Doepfer >
2006-10-26 by jalmari3
So, if I plug same source inverted and non-inverted into A-172, I get positive and negative full wave rectifier then? Would this work precisely with audio signals too? A newbie question: How do I connect to GND? Best regards Jari Jokinen --- In Doepfer_a100@yahoogroups.com, "Dieter Doepfer" <hardware@...> wrote: > Even the Max/Min module A-172 is working a bit like that (with one input > simply connected to GND) and could be combined with the inverter module > A-175. But the full wave rectifier is missing in the A-172. > > Best wishes > Dieter Doepfer > > > -----Ursprüngliche Nachricht----- > > Von: Doepfer_a100@yahoogroups.com > > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Adam-V > > Gesendet: Freitag, 12. Mai 2006 00:55 > > An: Doepfer_a100@yahoogroups.com > > Betreff: [Doepfer_a100] Re: any more ideas for exotic future A100 > > modules? > > > > > > Hi guys, > > > > How about some sort of wave rectifier that offers half and full wave > > rectification of an audio signal. It would only require one input and > > four outputs positive half, negative half, full wave positive and > > full wave negative. > > > > Apologies if this is achievable with existing modules, I'm still not
> > up with everything that is currently available. > > > > Cheers, > > Adam-V
2006-10-26 by hardware@doepfer.de
> So, if I plug same source inverted and non-inverted into A-172, I get > positive and negative full wave rectifier then? Yes. > Would this work precisely with audio signals too? It will work even with audio signals but there are diodes in the A-172 that cause a small offset voltage (the so-called forward voltage of each diode). If you replace all diodes by Schottky types the offset will be a bit smaller but not zero. If you need a precision rectifier: there is one in the envelope follower circuit of the A-119 (no diode offset). If you remove the capacitor (C6) that is used to smooth the envelope output you obtain a precision fullwave rectifier. If you add a switch that turns C6 on/off you could switch between envelope and rectifier. > A newbie question: How do I connect to GND? The simplest methode: plug a cable "half" into an unused socket. This will connect the tip of the cable to GND. Best wishes Dieter Doepfer
> So, if I plug same source inverted and non-inverted into A-172, I get > positive and negative full wave rectifier then? Would this work > precisely with audio signals too? While I tried to find our how this works and sounds I recorded a small audio example that shows how the A-172 can be used for audio applications as a dynamically controllable rectifier. Pay attention that no filters or VCAs are used for the example. An mp3 link and a short description of the patch can be found on the A-172 info page http://www.doepfer.de/A172.htm Best wishes Dieter Doepfer
2006-10-26 by Adam-V
I'm currently just finishing development of my own wave rectifier module that offers Positive Half, Positive Full, Negative Half and Negative Full wave rectification along with an offset control (Internal and CV) to make for some really funky assymetrical rectified signals. I'm at work at the moment but I'll post some oscillocope screen shots from my prototype over the weekend. I'm still trying to decide whether or not to go to the trouble of manufacturing a small batch of these to offer up for sale or just slap one or two together for my own use and offer the design up for other DIYers to build themselves. Cheers Adam-V --- In Doepfer_a100@yahoogroups.com, "jalmari3" <jari.jokinen@...> wrote:
> > So, if I plug same source inverted and non-inverted into A-172, I get > positive and negative full wave rectifier then? Would this work > precisely with audio signals too? > > A newbie question: How do I connect to GND? > > Best regards > Jari Jokinen
2006-10-27 by hardware@doepfer.de
> I'm currently just finishing development of my own wave rectifier > module that offers Positive Half, Positive Full, Negative Half and > Negative Full wave rectification along with an offset control > (Internal and CV) to make for some really funky assymetrical rectified > signals. Have you ever tried the A-136 Distortion / Waveshaper ? It has probably all these features available. The incoming signal is divided into 3 sections: - positive share of the signal with adjustable clipping level and positive/negative amplification of this component - negative share of the signal with adjustable clipping level and positive/negative amplification of this component - original signal with positive/negative amplification Precision rectifiers are used for the pos/neg shares in the A-136 (not only simple diodes). According to the control settings of the A-136 controls all suggested rectifier functions and anything in between are possible. I know that the A-136 is a bit underestimated, probably because it's not very easy to understand. Only the offset controls are missing. For this external modules (e.g. A-129-3 or A-138c) can be used. DIY's could add 2 or 3 potentiometers and sockets with switching contacts for the offset functions. If someone is interested I will email him the schematics of the A-136 (not a big secret for an electronic technician). Best wishes Dieter Doepfer
2006-10-28 by travesty14850
I love the A-136...a great module. > > > I'm currently just finishing development of my own wave rectifier > > module that offers Positive Half, Positive Full, Negative Half and > > Negative Full wave rectification along with an offset control > > (Internal and CV) to make for some really funky assymetrical rectified > > signals. > > Have you ever tried the A-136 Distortion / Waveshaper ? > > It has probably all these features available. The incoming signal is divided > into 3 sections: > > - positive share of the signal with adjustable clipping level and > positive/negative amplification of this component > - negative share of the signal with adjustable clipping level and > positive/negative amplification of this component > - original signal with positive/negative amplification > > Precision rectifiers are used for the pos/neg shares in the A-136 (not only > simple diodes). According to the control settings of the A-136 controls all > suggested rectifier functions and anything in between are possible. I know > that the A-136 is a bit underestimated, probably because it's not very easy > to understand. > Only the offset controls are missing. For this external modules (e.g. > A-129-3 or A-138c) can be used. DIY's could add 2 or 3 potentiometers and > sockets with switching contacts for the offset functions. If someone is > interested I will email him the schematics of the A-136 (not a big secret
> for an electronic technician). > > Best wishes > Dieter Doepfer >
2006-10-28 by jalmari3
Unless A-136 Distortion / Waveshaper can do the trick well, as suggested by Mr. Doepfer, you can count me in. Best regards Jari jokinen --- In Doepfer_a100@yahoogroups.com, "Adam-V" <adam-v@...> wrote: > I'm still trying to decide whether or not to go to the trouble of > manufacturing a small batch of these to offer up for sale
2006-10-29 by jalmari3
Could someone test, how accurately A-136 does the half and full wave rectifying at audio rate? On paper it looks capable, although some precision knob twisting seems to be needed... +L and -L (level controls) should be at zero. A (amplification control for original signal) at 5 (twelve o'clock). +A (amplification control for positive signal component above the positive clipping level) at 3.5 or 6.5 depending the desired type of rectifying. -A (amplification control for negative signal component below the negative clipping level) at 3.5 or 6.5 depending the desired type of rectifying. Best regards Jari Jokinen
2006-10-29 by Adam-V
As promised, I have uploaded some oscilloscope screen shots from my breadboarded. They are located in the Wave Rectifier folder of the files section. The input signal in the shots is a 1.5kHz 10Vp-p sine wave. The offset control in the gven examples was set such that rectification occurs around approx +2.5V rather than 0V. There is also a quick mock-up front panel showing what controls and connections I propose to put on the module if and when I decide to manufacture it. This was a cut and paste job from module images on the doepfer website and is meant as an indicator only since it would be very wrong for me to produce a module that looks exactly like a doepfer one. Dieter, I would be interested in the schematics of the A-136 merely to check out the modifications you suggested. Jari,I will put through my A-136 through it's paces if I get time later this week (unless somebody else beats me to it). Cheers, Adam-V.
2006-10-29 by travesty14850
It certainly does appear that you are rectifying the crap out of those waves!
> > As promised, I have uploaded some oscilloscope screen shots from my > breadboarded. They are located in the Wave Rectifier folder of the > files section. The input signal in the shots is a 1.5kHz 10Vp-p sine > wave. The offset control in the gven examples was set such that > rectification occurs around approx +2.5V rather than 0V. > > There is also a quick mock-up front panel showing what controls and > connections I propose to put on the module if and when I decide to > manufacture it. This was a cut and paste job from module images on the > doepfer website and is meant as an indicator only since it would be > very wrong for me to produce a module that looks exactly like a > doepfer one. > > Dieter, I would be interested in the schematics of the A-136 merely to > check out the modifications you suggested. > > Jari,I will put through my A-136 through it's paces if I get time > later this week (unless somebody else beats me to it). > > Cheers, > Adam-V. >
I most certainly am! --- In Doepfer_a100@yahoogroups.com, "travesty14850" <travesty14850@...> wrote:
> > It certainly does appear that you are rectifying the crap out of those > waves! >
2006-11-02 by hardware@doepfer.de
> Dieter, I would be interested in the schematics of the A-136 merely to > check out the modifications you suggested. > > Cheers, > Adam-V. Please contact me directly to get the schematics. Best wishes Dieter Doepfer
