a-110 lin fm mod and sync question -
2007-05-05 by davevosh@aol.com
hello to all - i recently traded for an a-110 vco (thanks, david, great trade !) to add to my system with the specific intention of adding the linear fm mod to it. this has been completed and works quite well - *if you have any d.i.y. interest, look at this mod* - it is totally simple (and i simplified my set-up a bit more by skipping the ac / dc coupling switch,i went with ac only) - 1 jack, 1 pot and 1 cap.. since the pot value wasn`t specified, i used a 50k as all the other pots in the module were 50k and it seems to work fine. this one is a winner ! :^) i`ve always liked the a-110, i consider it the "volks - vco" as it is adequate for most of my vco needs while remaining affordable and the lin fm mod gives it even more bang-per-buck ! i didn`t add the soft sync option as i don`t use sync that much but i may go back and retrofit it - i did have a question about it though - it shows a jack and pot but what is the pot for - ? i didn`t think it would be needed for a sync input - ? some sort of range control - ? thanks ! best, dave ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed]
