Hi Dennis,
I believe you're talking about creating instrument sounds with the BBD -
which is quite interesting, by the way, but I'm after processing actual
instruments.
Can you perhaps share with us how you emulate those sounds with Doepfer
modules?
Korhan
On 4/16/08, dennis henderson <dennismichaelhenderson@yahoo.com> wrote:
> hi, i dont know if this is what you are asking or not but; i have made
> all of those types of sounds plus organ, and trumpet using a bbd module,
> multiband eq and some other doepfer modules. so i guess, im saying, yes it
> is possible.
> Korhan Erel <listekutusu@gmail.com <listekutusu%40gmail.com>> wrote: I am
> after processing actual instruments (clarinet, tenor sax,
> electric guitar, melodica).
> On Sun, Apr 13, 2008 at 4:54 PM, partlydrone <partlydrone@yahoo.com<partlydrone%40yahoo.com>>
> wrote:
> > yeah be fine for that
> > i too own no actual audio oscillators, i use my quad lfo if i need a
> > static tone, occasionally a resonating filter, i've got an a112, and
> > other vintage synths, but although i often think about it i've never
> > actually bunged one through my modular.
> > --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>,
> "Korhan Erel" <listekutusu@...>
> > wrote:
> > > Hi,
> > > I am not after a analog synth that I can play using a keyboard, so
> > this is
> > > probably not an issue for me.... or is it? I am trying to construct
> > a system
> > > with which I can produce abstract sounds and process instruments at
> > the same
> > > time.
> > > Best,
> > > Korhan
> > > On 4/13/08, partlydrone <partlydrone@...> wrote:
> > > > i think the CV inputs on the dalek modulator are linear, not log, so
> > > > won't respond in the way you'd expect with keyboard/midicv although
> > > > alright static or with an analogue sequencer (kind of). i'd have
> > > > bought one if they'd responded normally.
> > > > --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com><Doepfer_a100%
> 40yahoogroups.com>,
> > > > "Korhan Erel" <listekutusu@>
> > > > wrote:
> > > > > Hi everyone,
> > > > > I'm trying hard to finalize my shopping list for modules and want
> to
> > > > > clarify something. The BBD module has been on the list right
> > from the
> > > > > start. However, I am having doubts about it lately. I know that I
> > > > > don't need phasing, flanging and chorus in my sound. I am also
> > not in
> > > > > desperate need of an analog delay (I have an Electroharmonix
> Deluxe
> > > > > Memoryman). What else can the BBD do? I know that feeding it
> > > > > out-of-range clock rates makes interesting sounds, but is it
> > > > > interesting enough to buy the module?
> > > > > I will probably go for Livewire's Dalek Generator, because it
> > includes
> > > > > two oscillators (which can modulate each other) and a ring
> modulator
> > > > > in one module. I know that the oscillators have only one CV
> > input each
> > > > > and are limited to pulse and sine waveforms, but size is an
> > important
> > > > > factor in my case. What do you guys think?
> > > > > I also plan to go for the MFB Dual LFO, because it includes two CV
> > > > > controlled LFOs in one small module, where the LFOs can modulate
> > each
> > > > > other when no CV is supplied. (I know this module is not out yet.)
> > > > > The rest of the list consists of the following Doepfer modules:
> > > > > A-118 Noise/Random
> > > > > A-137 Distortion/Waveshaper
> > > > > A-148 Dual S&H/T&H
> > > > > A-151 Quad Sequential Switch
> > > > > A-164 Manual Gate
> > > > > A-175 Dual Inverter
> > > > > A-188-1 BBD (1024)
> > > > > A-196 PLL
> > > > > I may leave the Manual Gate out or leave it and add a Joystick
> > module
> > > > > in. I'd like to ask your comments on all this.
> > > > > For those who may not remember my current modules listed in
> previous
> > > > > emails, here they are:
> > > > > A-116 Waveform Processor
> > > > > A-119 Ext Input/Env Follower
> > > > > A-124 Wasp Filter
> > > > > A-132-1 Dual linear VCA
> > > > > A-143-3 Quad LFO
> > > > > A-172 Max-Min Selector
> > > > > Thanks,
> > > > > Korhan
> > > [Non-text portions of this message have been removed]
> between 0000-00-00 and 9999-99-99
