Doepfer
A-190 and reset proceedure
2008-06-07 by David Bulog
I went do a full reset of the A-190 by powerup while holding buttons
1-4 on power up
When I powered the unit on the lights on the A-190 came on momentarily
and then no power.
Has anyone had a similar issue
BTW -How do I check if fuse is vlown
thanks David
Re: A-190 and reset proceedure
2008-06-07 by wolfgthiel
Hi David
Was the A-190 working before you did the reset?
Have you checked if all three voltages are ok? -12V/+12V/+5V.
I don't think there is a fuse in the A-190 modul (just had a look at my
one)and I'm not familiar with the Doepfer power supply. In general you
could take the fuse out and replace it with a new one of the same
rating, or if you familiar with a multimeter take the fuse out and
check continuity of the fuse with an ohm meter.
Good luck.
Wolfgang
> 1-4 on power up
momentarily
> and then no power.
> thanks David
2008-06-08 by wolfgthiel
Hi David
The easierst point to test is the bus board (you might have to take a
few modules out for good access). The 16 pol plugs are label with the
voltages (check between GND and +5V/-12V/+12V).
Please do this only if you familiar with this type of work as
otherwise you might destroy the power supply or your moduls.
Wolfgang
> Hi Wolfgang
> Can you please tell me how to test three voltages are ok? -
12V/+12V/+5V
> on A-100P
> thanks David
> On 8/06/2008, at 10:22 AM, wolfgthiel wrote:
> > Hi David
at
> > my
general you
> > Good luck.
> > Wolfgang
buttons
> > > 1-4 on power up
> > momentarily
> > > and then no power.
> > > thanks David
Re: [Doepfer_a100] Re: A-190 and reset proceedure
2008-06-08 by David Bulog
Hi Wolfgang
Can you please tell me how to test three voltages are ok? -12V/+12V/+5V
on A-100P
thanks David
> Hi David
> my
> Good luck.
> Wolfgang
> > 1-4 on power up
> momentarily
> > and then no power.
> > thanks David
