dangerous module combinations on the buss...
2008-06-26 by James Husted
I have an ever-growing and ever-re-arranging set of 3 portable cases. In one I have a A-190 and plan on adding some Bus-access A-185-1/2 modules and A-164-1 manual gate modules to it and to the other cases. I know there is a problem and potential danger with having the A-185s, A-164-1, and the A-190 in the same cabinet (if the busses are connected) without removing internal jumpers on A-190. What other modules should I have the same concerns about? Also will the A-190 drive multiple VCO's like the A-185s will? I may have damaged my 190 already by temporarily having it on the same buss as my new A-164-1 module (I have to start reading the manuals before turning them on!). The A-190 seems not to send gates to the A-141 on the same buss but I have to pull some modules to get a better look inside. Basically I'm sort of lazy and it would be nice to get a list of modules that send or receive CV and Gates to and from the buss that could possibly damage each other. I'm trying to avoid having to look through all the PDF manuals. -James
