Subject: [Doepfer_a100] Re: Korg MS20 to control doepfer synths?
Date: Saturday, July 12, 2008, 4:26 PM
Elby Designs is working on a nice eurorack hz/volt to volt/oct and the
other way around convertor so you can interface your ms-20 and other
hz/volt gear with your doepfer system anyway you want:
http://elby- designs.com/ panther/ed102- octave-volts- hertz/ed102- panel.pdf
give them an email, I think they are ready to get it going, they jsut
need a little push :)
I have an ms-20 too so really hoping they finish it soon.
C.
--- In Doepfer_a100@ yahoogroups. com, "Monroe Eskew" <monroe.eskew@ ...>
wrote:
> I think it works in theory. It might be hard to get the tracking
> exactly to scale though.
> I was just browsing the Doepfer site and found this planned module
> that is supposed to have a Hz/V to Oct/V converter function. Looks
> like a barrel of fun.
> http://www.doepfer. de/A100_ADDA. htm
> On 7/11/08, partlydrone <partlydrone@ ...> wrote:
> > > > Also, I think if you put a small fixed voltage into the "audio in"
> > in an
> > > > exponential VCA and then use the linear Hz/V CV to modify the
> > amplitude, and
> > > > set the CV attenuation right, then you will get the desired V/Oct
> > response.
> > ooh do you think? an osc with linear fm in wouldnt help, because it's
> > not just osc control i'm after, i'm hoping to get vaguely keyboard
> > scaled control on my frequency shifter and my a112 pitch shifting /
> > sampler.
> > if people reckon the hz/v keyboard controlling an exp vca solution is
> > the one then i'll do it.
> > there's a korg ms-02 log amp schematic about but i just can't face
> > building something to do this, i think i'd give up and go with an
ugly
> > v/oct controller.
> > --- In Doepfer_a100@ yahoogroups. com, "Monroe Eskew" <monroe.eskew@ >
> > wrote:
> > > or rather, large fixed V
> > > On Fri, Jul 11, 2008 at 7:27 PM, Monroe Eskew <monroe.eskew@ >
"audio in"
> > in an
> > amplitude, and
> > response.
> > > > On Fri, Jul 11, 2008 at 7:06 PM, Monroe Eskew <monroe.eskew@ >
> > > > wrote:
> > > >> The A111 has linear FM.
> > > >> On Fri, Jul 11, 2008 at 5:17 PM, partlydrone <partlydrone@ >
> > > >> wrote:
> > > >>> I have a lot of Hz/V gear - massive old paia modular and
ms20 etc.
> > > >>> Is it a really stupid idea to try and use my ms20 to control my
> > > >>> doepfer? I don't have a conventional keyboard to control it at
> > all at
> > > >>> the mo, but it would be nice. Is there a doepfer module
that does
> > > >>> antilog conversion or whatever? Is it one of those ideas
that is
> > > >>> theoretically possible but would actually be a massive pain in
> > the bum
> > > >>> in practice, causing heartache, frustration, and
cat-kicking? Anyone
> > > >>> tried it?
> > > >>> Would be great, because ms20 and my beautiful bespoke doepfer
> > box are
> > > >>> the only kit i use these days really, and it would be
> > ubercompact and
> > > >>> beautiful to look at as a pair.
> > > [Non-text portions of this message have been removed]
