Doepfer
Re: doepfer negative pr
2002-06-12 by ringmod45
--- In Doepfer_a100@y..., grove@z... wrote:
hi rachel, i posted the doepfer forum posts to show the indifference
doepfer shows to its customers. i did this because a few people don't
believe it exists, well it does. it should not called off topic when
it clearly needs to addressed. i have seen nothing from doepfer on
their forum  to prove me otherwise. on top of that they need to
polish their PR skills and interact a little better with this group.
sorry to drag you into this like that, but it was also ment to help
your cause as well as ours. like what's up with you having v 3.4 and
no mention on their site that it exists. i have v 3.0 and would like
to know what the software revisions were. this is what i mean by lack
of customer support among other things.
cheers,
RM
> I just wanted to add here, I am the "rachel" who posted the message
that
> ringmod quoted.  I wasn't expecting him to, but I do not mind.
> I think I should add here:
> I have only an A100 Mini system, but I am planning a much larger
set of
> -modules.  I bought the MAQ 16/3 primarily because it is considered
a
> part of the A100 (although it's a subset) by Doepfer.  I intend to
build
> a system that will use the MAQ as the primary controller.  In this
instance.
> I do not consider discussion of the MAQ off topic!  I consider the
MAQ as
> much a part of the A100 system as the rest of it.
> There is another yahoogroups list for the MAQ just started that I
subscribed to
> yesterday, but I appear to be the only subscriber, other than the
admin.
> The web based forum for the doepfer products is a bit of a stinker -
 I hate
> web based forums at the best of times, hence I usually use email.
> Anywhere that is discussing the MAQ 16/3 is of use to me, since it
is
> such an inscrutable and poorly documented piece of (expensive)
equipment.
> I am quite perturbed by Doepfer (the company) ignoring my posts to
them
> regarding what I consider a definite bug in the firmware, wrt to
Clock sending
> on External synch.  If ringmod's postings here annoy people, I am
sorry,
> but I tend to agree about this one, since stirring the possum a bit
> is often the only way to get some answers.....
> Anyway, I shall leave it at that for now.....
> rachel
> This message was sent using Endymion MailMan.
> http://www.endymion.com/products/mailman/
re: doepfer negative pr
2002-06-12 by grove@zeta.org.au
> Message: 1
>    Date: Tue, 11 Jun 2002 14:21:59 -0000
>    From: "ringmod45" <ringmod45@yahoo.com>
> Subject: doepfer negative pr
> hi everyone, i am reposting this here as an example of what happens
> when you don't do any upgrading to your products or have customer
> support. someone has decided not to buy a doepfer product. WHY?
>  read on, here a few posts from the doepfer forum. now you why i am
> so adamant about what it does the doepfer image and its products.
> rachel
> Unregistered User
> (6/5/02 11:02:32 am)
> Reply  Solution!!!
>  Ok, I solved it.
> The MTP II does filter MIDI Clock - you have to filter
> "Realtime" messages from the Doepfer to stop it sending
> a recursive clock.
> I still think that the MAQ 16/3 should have an option
> to select whether you want to send Clock out or not.
> Usually when you setup a box to be synched externally
> you do not want it to send clocks out.
> There should only be one master!
I just wanted to add here, I am the "rachel" who posted the message that
I have only an A100 Mini system, but I am planning a much larger set of
-modules.  I bought the MAQ 16/3 primarily because it is considered a
part of the A100 (although it's a subset) by Doepfer.  I intend to build
a system that will use the MAQ as the primary controller.  In this instance.
I do not consider discussion of the MAQ off topic!  I consider the MAQ as
There is another yahoogroups list for the MAQ just started that I subscribed to
yesterday, but I appear to be the only subscriber, other than the admin.
The web based forum for the doepfer products is a bit of a stinker - I hate
Anywhere that is discussing the MAQ 16/3 is of use to me, since it is
such an inscrutable and poorly documented piece of (expensive) equipment.
I am quite perturbed by Doepfer (the company) ignoring my posts to them
regarding what I consider a definite bug in the firmware, wrt to Clock sending
on External synch.  If ringmod's postings here annoy people, I am sorry,
rachel
