A-199 Spring Reverb Problem
2009-01-19 by aesoteric@talk21.com
Hey all, My Doepfer A-199 spring module has suddenly started distorting. I've only had it two weeks, and I just got a lovely Accutronics 4 spring tray for it that sounds amazing. Then today, it sounded different, like the reverb signal was going through a fuzz pedal - so I backed the level off, and it kept happening, so I hooked up the original Belton tray, and the problem persisted. The dry signal going to it is fine, and turning the mix control fully left gives a normal dry signal. All I could think was that I had tugged the RCA cable inside the case and something had come loose - but everything looks fine. Does anyone have any suggestions? I'm gutted, I finally get the spring sound of my dreams, and now its gone again... :help: Any help gratefully received. I'll post this on the Doefper forum too, just in case. Cheers, TJ [Non-text portions of this message have been removed]
