Doepfer
Mod-demod - Not quite getting this one?
2009-10-10 by propane23
Let me see if i've got this right:
Osc A to Ring mod 1 X input
Osc B to Ring mod 1 Y input
Ring mod 1 output to Ring mod 2 X input
Osc B inverted to Ring mod 2 Y input
I've had a few goes and i can't tell any difference between 'mod demod' and just plain two ring mods in series, the following audio has a VCS in the patch to switch the Ring mod 2 Y input between inverted and non-inverted on each new note on.
http://homepage.ntlworld.com/marieshrewsbury/ModDemod%20101009.wav
It sounds just the same? First part is using an LFO in the audio range, then i swap patch cables to use a VCO instead, but there is no change on alternate notes.
Re: [Doepfer_a100] Mod-demod - Not quite getting this one?
2009-10-10 by achtung_999
Fast answer without listening to the sound yet..In theory you should have
the upper sum harmonic with the X input as output from the Mod Demod..
So if your sound is a low sine chances are that the difference harmonic is
too low to hear..
Leaving thereby only the sum harmonic and the leakage from the X input...
> each new note on.
> alternate notes.
2009-10-10 by Shrewsbury Marie
Hang on, so the X input of Ring mod 2 is the output? And the output of Ring mod 1 is patched to the normal output of Ring mod 2, like Ring mod 2 is patched in reverse?
--- On Sat, 10/10/09, achtung_999 <heinrich.himmelwasser@gmail.com> wrote:
From: achtung_999 <heinrich.himmelwasser@gmail.com>
Subject: Re: [Doepfer_a100] Mod-demod - Not quite getting this one?
Date: Saturday, October 10, 2009, 3:37 PM
too low to hear..
> each new note on.
> http://homepage. ntlworld. com/marieshrewsb ury/ModDemod% 20101009. wav
> alternate notes.
no, you patched correctly. I was speaking about the theoretical output
results when inputing sines.
> patched in reverse?
> you should have
> too low to hear..
>> and
>> on
>> each new note on.
>> alternate notes.
Any UK/EUers selling a G6 or G3 frame anytime soon?
2009-12-30 by Shrewsbury Marie
Hi guys,
Probably going to be looking out for some new modules soon but i need more rack space.
Not worth getting into US shipping and customs issues, but if anyone in the UK or EU plans parting with a G6 or possibly a G3 in the near future, give me a shout.
Re: [Doepfer_a100] Any UK/EUers selling a G6 or G3 frame anytime soon?
2009-12-30 by Os
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180450067353
os.
2009/12/30 Shrewsbury Marie <propane23@yahoo.com>
> Hi guys,
> rack space.
> me a shout.
os@collective.co.uk
http://twitter.com/expertsleepers
http://www.darkroomtheband.net/
http://www.expert-sleepers.co.uk/
2010-03-07 by infrequent
Did you ever find a g6?  I am thinking of selling one of mine.  I am in
Bristol, btw.
rgds
Pierre
On Wed, Dec 30, 2009 at 12:19 PM, Shrewsbury Marie <propane23@yahoo.com>wrote:
> Hi guys,
> rack space.
> me a shout.
2010-03-07 by Shrewsbury Marie
Hiya,
Not yet. I'm in Leeds. So only a good idea if you're up for shipping?
--- On Sun, 3/7/10, infrequent <infrequent.listener@gmail.com> wrote:
Subject: Re: [Doepfer_a100] Any UK/EUers selling a G6 or G3 frame anytime  soon?
Date: Sunday, March 7, 2010, 11:18 AM
Bristol, btw.
rgds
Pierre
On Wed, Dec 30, 2009 at 12:19 PM, Shrewsbury Marie <propane23@yahoo. com>wrote:
> Hi guys,
> rack space.
> me a shout.
I don't have any boxes big enough at the moment for shipping.  However, it's
possible to dismantle it so I might be able to get it into a smaller box.
Are you any good at putting things together?  Also, I might be able to get a
box from Emis next weekend.  In which case no problem either way.  The
general selling rate is 70% of new on the list.  That ok with you?  It would
be a g6 with the second generation PSU and it's only a couple of years old.
rgds
Pierre
