Doepfer
A-180
A-180
2009-11-15 by Computer Controlled
I've noticed recently that the A-180 Multiple really cuts the voltage
signal down quite substantially. I just got an MFB Dual ADSR and noticed
that when i mult the Gate Output of my SH-101 by 3x, it drops the gate
voltage down to where the MFB won't trigger anymore. Basically, i had it
set up where the gate out went into the A-180, then the first 2 outs
went to the two Gate Ins on the MFB and the 3rd out went to my A-140 EG.
If i pulled the cable out that went to the A-140, the MFB would fire,
but not with it inserted. However, it works if i use my 303, which has a
hotter Gate signal. I checked the gate out voltages coming of the 101
direct, then at each output of the A-180. I got the following:
Direct Out from 101: 11.56v
Into the A-180 w/no other cables inserted: same as above
with 2 cables inserted: 7v
with 3 cables inserted: 5.5v
This is quite a bit of voltage drop if you ask me. Is there anyway to
mod the A-180 so it doesn't eat up all my voltages?
-Larry
Re: [Doepfer_a100] A-180
2009-11-15 by Monroe Eskew
It's strange because in theory the voltage should not drop since these are
parallel circuits-- only the current should change.
On Sun, Nov 15, 2009 at 2:16 PM, Computer Controlled <acidted@gmail.com>wrote:
> -Larry
That's why there are Buffered Multiples, passive ones drop the voltage
levels. So they need to be buffered to keep them at original levels.
I just didn't think that the level would drop by so much!
>> -Larry
Re: A-180
2009-11-15 by Synthomaniac
Hi Guys
There seems to be some confusion about what's going on with loading, volts, current etc.  The good news is that Ohm's Law isn't about to be disproved anytime soon. Volts and current are linked in Ohm's law by resistance, in this case the output resistance of the SH101 - this is about 22k and it connects to +15V in the SH101 gate out circuit.
The MFB EG acts as a load and two in parallel act as a greater load, i.e. more current will flow.  If for argument's sake the MFB has an input resistance of 10k then two EGs in parallel would then give a load of 5k. I'll ignore the A140 since that that has a very high input resistance (mine are around 5M to 7M).
The arithmetic for this example is that 15V is loaded by 22k out plus a 5k load = 27k. This acts as a potential divider thus 15/27 x 5 = 2.8V. Not very big! So the more current out the more the voltage drop across the output resistance and hence a smaller gate voltage. So yes it needs a buffer to isolate the SH101 output's high output resistance; I use an A185-1. If you just had A140s then these have such a high resistance that it shouldn't make any difference.
Hope that helps clear up the mystery.
I'd be inteested if anyone can tell me what the MFB EG input resistance actually is.
Cheers
Tony
--- In Doepfer_a100@yahoogroups.com, Monroe Eskew <monroe.eskew@...> wrote:
> Pardon if this is a dumb question, but are you sure you're measuring voltage
> and not power?  Is Ohm's law really that blatantly false?  I've noticed VCOs
> don't respond to voltage only; they are influenced by the amperage as well.
> > are
> > > On Sun, Nov 15, 2009 at 2:16 PM, Computer Controlled <acidted@...<acidted%40gmail.com>
> > >> -Larry
> > > Yahoo! Groups Links
On Sun, Nov 15, 2009 at 2:43 PM, Computer Controlled <acidted@gmail.com>wrote:
> are
> > On Sun, Nov 15, 2009 at 2:16 PM, Computer Controlled <acidted@gmail.com<acidted%40gmail.com>
> >> -Larry
> > Yahoo! Groups Links
Re: [Doepfer_a100] Re: A-180
2009-11-16 by Monroe Eskew
Ah, sorry, I didn't really read the details.  Sounds like he should be able
to fix it by soldering high value resistors to the inputs of the MFB EG... I
think.
On Sun, Nov 15, 2009 at 3:49 PM, Synthomaniac <tony.steventon@talk21.com>wrote:
> Hi Guys
> any difference.
> actually is.
> Cheers
> Tony
> --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>,
> voltage
> VCOs
> well.
> these
> > > are
> voltage
> noticed
> gate
> had it
> EG.
> fire,
> has a
> 101
> to
> > > >> -Larry
> > > > Yahoo! Groups Links
Re: A-180
2009-11-16 by Synthomaniac
Hi Monroe,
Sorry to be the bearer of bad news, but soldering resistors to the inputs whilst reducing load current will only act as a further potential divider causing an even worse situation because it adds to the output resistance of the SH101.  The only way forward is to have an active buffer (e.g. A185-1 or Dieter may be able to suggest other alternatives). Most Doepfer modules have a low output resistance, normally 1k or lower which as you can see is significantly lower than the SH101.
I must still stress that I don't actually know what the input resistance of the MFB EGs is and that neither has a fault. My gut feel is that the MFBs should be higher than the 10k that I suggested in my example. It would be useful if all manufacturers produce a spec sheet stating input and output resistances and voltage levels etc. It would help in determining compatability between different manufacturer's modules. I'll ping off a question to MFB to find out.
Cheers
Tony
> think.
> On Sun, Nov 15, 2009 at 3:49 PM, Synthomaniac <tony.steventon@...>wrote:
> > Hi Guys
> > any difference.
> > actually is.
> > Cheers
> > Tony
> > voltage
> > VCOs
> > well.
> > these
> > > > are
> > voltage
> > noticed
> > gate
> > had it
> > EG.
> > fire,
> > has a
> > 101
> > to
> > > > >> -Larry
> > > > > Yahoo! Groups Links
2009-11-16 by Florian Anwander
Hi Larry
You may try to change the values of the buffering stage in the SH-101.
It is TR9 with R47 and R49 (close to the top left corner of the CPU).
You may reduce R47 to 4k7 and R49 to 22k.
Florian
AW: [Doepfer_a100] A-180
2009-11-16 by yahoo@doepfer.de
> -Larry
Some basic information about this issue:
The A-180 is a passive module - nothing but 2x4 connected jack sockets. It
works as if one would simply connect the jack plugs manually of if one would
use an Y-cable. Consequently the reason for the behaviour described is
actually not the A-180 but the inputs and outputs of the modules. Ideally
the output of each module should be able to drive any load without any
losses (technically spoken: zero ohm output impedance or resistance). And
ideally the input of each module should not cause any load (technically
spoken: infinite ohm output impedance or resistance). But in reality the
situation is different: each output has a limited driving capability (e.g. 1
k output resistance) and each input causes a load (e.g. 100k for most VCO CV
inputs). As a rule of thumb the relation between input and output resistance
causes the voltage loss: if a 1k output drives a  100k input one has about
1/100 of voltage drop. Not much for a gate voltage but already too much for
a VCO control input(that's why special buffers like A-185-1/2 are
recommended for VCO control). If more than one input is connected to an
output (e.g. by means of an A-180) the resulting load becomes smaller: as a
rule of thumb the load is divided by two if both inputs have the same load.
Otherwise it's a bit more difficult to calculate. For example: the A-140 has
a 10k load at it's input. If two A-140 inputs are connected together the
resulting load is 5k. If the resistance of the output that drives the two
A-140 is also in the 5k range the output voltage is divided by two. If it
was 12V without load it becomes ~ 6V with two A-140.
In the A-100 we payed attention that (with some exceptions) each source is
able to drive a customary number of units (e.g. 3-4 A-140 from a gate
source). The output resistance of A-100 modules is typ. 1k and the input
resistance 10k or more (e.g. 100k for VCO control inputs). Consequently
within the A-100 no problems with gate signals should occur. For voltages
that drive VCOs buffer modules (A-185-1/2) are recommended. These have a
much lower output impedance. If an external voltage source is used the
situation may be different. One needs to know the output impedance to
calculate the expected voltage drop. To be on the safe side a buffer module
can be used (even for gate signals).
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] A-180
2009-11-16 by Bakis Sirros
yes, that's why when i use the A100 with other modular devices i, very often, use buffer modules even for gates clocking various other sequencers, etc...
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
--- On Mon, 11/16/09, yahoo@doepfer.de <yahoo@doepfer.de> wrote:
Subject: AW: [Doepfer_a100] A-180
Date: Monday, November 16, 2009, 11:58 AM
> -Larry
Best wishes
Dieter Doepfer
