Modules needed
2014-12-27 by Neil Kagan
Hi to all, and Merry Christmas :) Is anyone here wanting to sell the Doepfer trigger delay and / or trigger modifier? Thanks, Neil Sent from my iPhone
2014-12-27 by David Kellett
Does the A165 work as a Eurorack to "S" trig converter? I was wondering about triggering a Korg SQ10 sequencer. David www.movingisliving.co.uk Sent from my iPhone
> On 27 Dec 2014, at 15:15, Neil Kagan blinkenlicht@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: > > Hi to all, and Merry Christmas :) > > Is anyone here wanting to sell the Doepfer trigger delay and / or trigger modifier? > > Thanks, > > Neil > > Sent from my iPhone > >
Unsure, the other inverters work with the MS-20 I have. I'm needing it as a few patches I've seen use it's double function. Also it can work as a 2 x clock multiplier! Sent from my iPhone
> On 27 Dec 2014, at 16:04, David Kellett davidkellettwoulf@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: > > Does the A165 work as a Eurorack to "S" trig converter? I was wondering about triggering a Korg SQ10 sequencer. > > David > > www.movingisliving.co.uk > > Sent from my iPhone > >> On 27 Dec 2014, at 15:15, Neil Kagan blinkenlicht@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: >> >> >> Hi to all, and Merry Christmas :) >> >> Is anyone here wanting to sell the Doepfer trigger delay and / or trigger modifier? >> >> Thanks, >> >> Neil >> >> Sent from my iPhone >> > >
The two times clock multiplier would be good with a variable pulse width source - to create a bit of "swing" David www.movingisliving.co.uk Sent from my iPhone
> On 27 Dec 2014, at 17:14, Neil Kagan blinkenlicht@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: > > Unsure, the other inverters work with the MS-20 I have. I'm needing it as a few patches I've seen use it's double function. Also it can work as a 2 x clock multiplier! > > Sent from my iPhone > >> On 27 Dec 2014, at 16:04, David Kellett davidkellettwoulf@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: >> >> >> Does the A165 work as a Eurorack to "S" trig converter? I was wondering about triggering a Korg SQ10 sequencer. >> >> David >> >> www.movingisliving.co.uk >> >> Sent from my iPhone >> >>> On 27 Dec 2014, at 15:15, Neil Kagan blinkenlicht@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: >>> >>> >>> Hi to all, and Merry Christmas :) >>> >>> Is anyone here wanting to sell the Doepfer trigger delay and / or trigger modifier? >>> >>> Thanks, >>> >>> Neil >>> >>> Sent from my iPhone >>> > >
Oh that’s a nice idea; I’m planning on using it for ‘ratcheting’ sequences! (until the new module is out anyway..)
> On 27 Dec 2014, at 17:33, David Kellett davidkellettwoulf@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: > > > The two times clock multiplier would be good with a variable pulse width source - to create a bit of "swing" > > David > > www.movingisliving.co.uk <http://www.movingisliving.co.uk/> > > Sent from my iPhone > > On 27 Dec 2014, at 17:14, Neil Kagan blinkenlicht@yahoo.com <mailto:blinkenlicht@yahoo.com> [Doepfer_a100] <Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100@yahoogroups.com>> wrote: > >> >> >> Unsure, the other inverters work with the MS-20 I have. I'm needing it as a few patches I've seen use it's double function. Also it can work as a 2 x clock multiplier! >> >> Sent from my iPhone >> >> On 27 Dec 2014, at 16:04, David Kellett davidkellettwoulf@yahoo.com <mailto:davidkellettwoulf@yahoo.com> [Doepfer_a100] <Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100@yahoogroups.com>> wrote: >> >>> >>> >>> Does the A165 work as a Eurorack to "S" trig converter? I was wondering about triggering a Korg SQ10 sequencer. >>> >>> David >>> >>> www.movingisliving.co.uk <http://www.movingisliving.co.uk/> >>> >>> Sent from my iPhone >>> >>> On 27 Dec 2014, at 15:15, Neil Kagan blinkenlicht@yahoo.com <mailto:blinkenlicht@yahoo.com> [Doepfer_a100] <Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100@yahoogroups.com>> wrote: >>> >>>> >>>> Hi to all, and Merry Christmas :) >>>> >>>> Is anyone here wanting to sell the Doepfer trigger delay and / or trigger modifier? >>>> >>>> Thanks, >>>> >>>> Neil >>>> >>>> Sent from my iPhone >>>> >>> >> > >
2015-01-07 by yahoo@doepfer.de
> Does the A165 work as a Eurorack to "S" trig converter? I was wondering about triggering a Korg SQ10 sequencer. > > > David > > www.movingisliving.co.uk The possible use of the A-165 as S trigger converter depends upon the direction: If you have an S-Trigger signal that has to be converted into a voltage trigger a pull-up resistor has to be added. The procedure is described on the A-100 DIY page on our website. If a voltage trigger has to be converted into a "real" S trigger (i.e. pure switching to GND) another modification is necessary: one has to remove R2 and use the collector output of Q1 as S trigger output. But in many cases not a "real" S trigger is required but only the inverted signal. In this case simply use the inverted output of the module. I'd try out if this works before you start the modification. Best wishes Dieter Doepfer
2015-01-07 by David Kellett
Thanks Dieter. I shall try it out and see if my SQ10 likes it :-) David www.movingisliving.co.uk Sent from my iPhone
On 7 Jan 2015, at 10:31, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: >> Does the A165 work as a Eurorack to "S" trig converter? I was wondering about triggering a Korg SQ10 sequencer. >> >> >> David >> >> www.movingisliving.co.uk > > The possible use of the A-165 as S trigger converter depends upon the direction: > > If you have an S-Trigger signal that has to be converted into a voltage trigger a pull-up resistor has to be added. The procedure is > described on the A-100 DIY page on our website. > > If a voltage trigger has to be converted into a "real" S trigger (i.e. pure switching to GND) another modification is necessary: one > has to remove R2 and use the collector output of Q1 as S trigger output. But in many cases not a "real" S trigger is required but > only the inverted signal. In this case simply use the inverted output of the module. I'd try out if this works before you start the > modification. > > Best wishes > Dieter Doepfer > > > > > > > ------------------------------------ > > ------------------------------------ > > > ------------------------------------ > > Yahoo Groups Links > > >
