Doepfer A106-5 filter CV2 question
2015-02-05 by raulpena1974@yahoo.com
Hello. I am doing a series on the A106-5. I read that the CV2 is a polarized input so around 12 o' clock the cv input is at zero, at +5 it is at fully positive input, and at -5 it is an inverted version of the cv input.
As long as I understand this correctly, at zero I should have no cv but when I input an envelope it does affect the cutoff a slight amount.
Can anyone confirm this behavior or explain if I am misunderstanding something?
Thanks for any help.
Raul
2015-02-05 by Neil Kagan
If it's like the A-133, I find the 'zero' point to be very small. Same with the Polarizing mixer. Neil Sent from my iPhone
> On 5 Feb 2015, at 03:14, raulpena1974@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: > > Hello. I am doing a series on the A106-5. I read that the CV2 is a polarized input so around 12 o' clock the cv input is at zero, at +5 it is at fully positive input, and at -5 it is an inverted version of the cv input. > > As long as I understand this correctly, at zero I should have no cv but when I input an envelope it does affect the cutoff a slight amount. > > Can anyone confirm this behavior or explain if I am misunderstanding something? > > > > Thanks for any help. > > > > Raul > >
2015-02-05 by Martin Fay
Dieter, is the A-133 implemented with "back-to-back" VCAs? If so a handy improvement for a future A-133-2 would be a switch to select negative/both/positive (or just both/positive only would be very nearly as useful). Also a sum output, or normal the upper output to the lower output would be nice. And normal +5V to the inputs so that the units can be used as offsets. Martin Sent from my iPhone On 5 Feb 2015, at 07:54, "Neil Kagan blinkenlicht@yahoo.com [Doepfer_a100]" <Doepfer_a100@yahoogroups.com> wrote:
> If it's like the A-133, I find the 'zero' point to be very small. > Same with the Polarizing mixer. > > Neil > > Sent from my iPhone > > On 5 Feb 2015, at 03:14, raulpena1974@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com > > wrote: > >> >> Hello. I am doing a series on the A106-5. I read that the CV2 is a >> polarized input so around 12 o' clock the cv input is at zero, at >> +5 it is at fully positive input, and at -5 it is an inverted >> version of the cv input. >> >> As long as I understand this correctly, at zero I should have no cv >> but when I input an envelope it does affect the cutoff a slight >> amount. >> >> Can anyone confirm this behavior or explain if I am >> misunderstanding something? >> >> >> >> Thanks for any help. >> >> >> >> Raul >> > >
Yes!! Brilliant idea :) Sent from my iPhone
> On 5 Feb 2015, at 10:01, Martin Fay martin@martinfay.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: > > Dieter, is the A-133 implemented with "back-to-back" VCAs? If so a handy improvement for a future A-133-2 would be a switch to select negative/both/positive (or just both/positive only would be very nearly as useful). > > Also a sum output, or normal the upper output to the lower output would be nice. > > And normal +5V to the inputs so that the units can be used as offsets. > > Martin > > Sent from my iPhone > >> On 5 Feb 2015, at 07:54, "Neil Kagan blinkenlicht@yahoo.com [Doepfer_a100]" <Doepfer_a100@yahoogroups.com> wrote: >> >> >> If it's like the A-133, I find the 'zero' point to be very small. Same with the Polarizing mixer. >> >> Neil >> >> Sent from my iPhone >> >>> On 5 Feb 2015, at 03:14, raulpena1974@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote: >>> >>> >>> Hello. I am doing a series on the A106-5. I read that the CV2 is a polarized input so around 12 o' clock the cv input is at zero, at +5 it is at fully positive input, and at -5 it is an inverted version of the cv input. >>> >>> As long as I understand this correctly, at zero I should have no cv but when I input an envelope it does affect the cutoff a slight amount. >>> >>> Can anyone confirm this behavior or explain if I am misunderstanding something? >>> >>> >>> >>> Thanks for any help. >>> >>> >>> >>> Raul >>> > >
2015-02-05 by achtung_999
On 5 Feb 2015, at 10:01, Martin Fay martin@martinfay.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:Dieter, is the A-133 implemented with "back-to-back" VCAs? If so a handy improvement for a future A-133-2 would be a switch to select negative/both/positive (or just both/positive only would be very nearly as useful).Also a sum output, or normal the upper output to the lower output would be nice.And normal +5V to the inputs so that the units can be used as offsets.Martin
On 5 Feb 2015, at 07:54, "Neil Kagan blinkenlicht@yahoo.com [Doepfer_a100]" <Doepfer_a100@yahoogroups.com> wrote:If it's like the A-133, I find the 'zero' point to be very small. Same with the Polarizing mixer.Neil
On 5 Feb 2015, at 03:14, raulpena1974@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:Hello. I am doing a series on the A106-5. I read that the CV2 is a polarized input so around 12 o' clock the cv input is at zero, at +5 it is at fully positive input, and at -5 it is an inverted version of the cv input.
Raul
2015-02-05 by yahoo@doepfer.de
> I am always wondering why no center detent pots were used on the polarizers in Doepfer modules. > I know this is more expensive... but still... > > Ernst It has to do with technical problems. Our manufacturer is not able to manufacture a potentiometer with center detent AND mounting bracket at the same time. In some modules potentiometers with center detents are used (e.g. A-188-2, A-138e) but these pots do not have mounting brackets. Consequently such potentiometers can be used only if the brackets are not necessary for the mechanical stability. For the vertical type (as used in Dark Energy/Time and soem modules) another combo is not possible: center detent and thread. That's why the filter type pot of the Dark Energy II is the only wobbly control because of the missing thread. It's strange but unfortunately we have to accept these issues even if I don't really understand it. But it seems to be not that easy as we were asking other manufacturers too. No other company was able so far to offer a pot with center detent AND bracket. Best wishes Dieter Doepfer
> Dieter, is the A-133 implemented with "back-to-back" VCAs? If so a handy improvement for a future A-133-2 would be a > switch to select negative/both/positive (or just both/positive only would be very nearly as useful). > > > Also a sum output, or normal the upper output to the lower output would be nice. > > > And normal +5V to the inputs so that the units can be used as offsets. > > > Martin Each sub-unit has only one VCA with amplification range 0-2 available. The polarizing function is simply realized by adding the inverted signal to the VCA output, i.e. output = -input + v*input with v = 0-2 (VCA). As we are about to redesign the A-133 with modern VCAs (2164). I will see which of the additional features will be included. We also think about other function combos instead of dual modules (e.g. combo modules instead of dual ring modulator A-114, dual S&H A-148, dual VC polarizer A-133, dual VC switch A-131 and so on ...). For some of these modules the dual function is not always meaningful and other combos may make more sense. But before we begin this we have to finish the announced new modules. Best wishes Dieter Doepfer
> Ernst
Best wishes
Dieter Doepfer
Yahoo Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/Doepfer_a100/
<*> Your email settings:
Individual Email | Traditional
<*> To change settings online go to:
http://groups.yahoo.com/group/Doepfer_a100/join
(Yahoo! ID required)
<*> To change settings via email:
Doepfer_a100-digest@yahoogroups.com
Doepfer_a100-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
Doepfer_a100-unsubscribe@yahoogroups.com
<*> Your use of Yahoo Groups is subject to:
https://info.yahoo.com/legal/us/yahoo/utos/terms/
