Doepfer
Tuning references for A156 quantizer
2016-08-17 by jaccoville@yahoo.com
Hello Dieter,
I have an issue with the A156.
Besides the small notes on your website about tuning the A156 is there a more specific thing to measure?
Between the steps of 0.0833333 V there is a small window of quantizing.
When the voltage goes up and down there it switches differently.
I ask this because I used the P4 with a reference voltage of 1.00 , 2.00 , 3.00 and 4,00V.
Afterwards I used P1 and P2 to adjust but then I lost it a bit.
Within voltage steps everything seems ok but now I"ll have to put the 0,083333 steps one by one and see if the output follows right?
Where are the points where the quantizer switches?
What is the factorysetting for that, when going voltage up and when down.
Hope that I made a clear explaination.
Best regards.
Jacco Ville
The Netherlands
AW: [Doepfer_a100] Tuning references for A156 quantizer
2016-08-18 by yahoo@doepfer.de
> Hello Dieter,
> Best regards.
> Jacco Ville
> The Netherlands
I'd recommend to adjust the CV outputs with a wide spread (e.g. 0/5V). The
difference has to be as close as possible to 5.00V (e.g. +0.016 and +5.016V
or -0.03 and +4.97V), the absolute values are not important. The CV values
in between are defined by the precision (linearity) of the used DAC and
cannot be adjusted.
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] Tuning references for A156 quantizer
2016-08-18 by Jacco Ville
Hello Dieter,
Thank you for your reply.
Everything is clear.
I managed to get two of my A156's within nice specs (read: same behaviour)
I have two others to check but now I know how to adjust them really fine.
Thank you again.
Jacco
Verstuurd vanaf mijn iPhone SE Lunatik
Op 18 aug. 2016 om 09:44 heeft yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
>> Hello Dieter,
>> Best regards.
>> Jacco Ville
>> The Netherlands
> cannot be adjusted.
> Best wishes
> Dieter Doepfer
> Yahoo Groups Links
.... By the way ;-)
I found out the attenuator function of P1 and P2
Very handy to set the threshold of the quantizer behaviour.
I noticed that with critical voltages from my A155's with a knob fully cw the voltage of 0.970V in 1V modus was not enough to get a full scale from C to C.
Now I made the threshold of the A156 a few mV  earlier to deal with
this problem.
Cheers
Jacco Ville
The Netherlands
>> Hello Dieter,
>> Best regards.
>> Jacco Ville
>> The Netherlands
> cannot be adjusted.
> Best wishes
> Dieter Doepfer
> Yahoo Groups Links
AW: AW: [Doepfer_a100] Tuning references for A156 quantizer
> .... By the way ;-)
> this problem.
> Cheers
> Jacco Ville
> The Netherlands
That's a solution. But the correct way would be to adjust the A-155 so that
it outputs 1.0V in 1V mode. For this a trimming potentiometer (P9') is
available on the upper A-155 potentiometer board.
Best wishes
Dieter Doepfer
Re: AW: AW: [Doepfer_a100] Tuning references for A156 quantizer
....And I certainly will do that.
Learning learning....
Funny thing, I am more collecting and adjusting my Doepfer setup (or Dieter room as my wife is calling it) then making sounds.
But I think it is the best way to know the working of every part of this system.
Cheers
Jacco Ville
> Op 18 aug. 2016 om 12:19 heeft yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> > .... By the way ;-)
> > this problem.
> > Cheers
> > Jacco Ville
> > The Netherlands
> Best wishes
> Dieter Doepfer
Re: [Doepfer_a100] Tuning references for A156 quantizer
2016-08-19 by Nicholas Keller
I hadn't thought to check the 156 for adjustment. I've been struggling with tuning for some time now and almost always have a 156 in the patch. Thanks for bringing this to my attention. I'll check the scale of my 155 while I'm at it!
On Thursday, August 18, 2016, Jacco Ville jaccoville@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
Cheers
Jacco Ville
> .... By the way ;-)
> this problem.
> Cheers
> Jacco Ville
> The Netherlands
Best wishes
Dieter Doepfer
2016-08-19 by Jacco Ville
I noticed some different behaviour of my A156's when testing my setup.
With a tuner on an A110 tuning from the A155 from C to C (seq knob fully ccw and cw) some came to C or B and when switching between 1V 2V and 4V it was not consistent.
So.... Time to make voltages visible.
Yesterday I finished fine tuning my four A156's and five A155's.
Once you know the drill it's not difficult, all it takes is some time and a precision voltage and measurement.
I used the A185-2 as a voltage source
and a Jones O'Tool Plus oscilloscope with a dual screen for voltage measurement in mV.
One input as source, the other from the A156.
As Dieter said, watch the offset.
Switch your precision adder between 0V and 4V.
I noticed there was a different quantizing sometimes (after regulating the P4 first!) when switching between 1V and 4V.
Then it made one step (note) to far (up). Then the P1 (cv1) or P2(cv2) comes in handy to regulate the threshold of the quantizer.
It acts as an attenuator, you can set quantizer steps earlier or later.
I made a list with calculated steps from 0,0833 to 1.000V and so it's easy to check where the threshold is for every step.
I used the attenuator from the 185-2 to walk through those steps and regulated that quantizing takes place at about 0,015V before the next step (note voltage) which leaves enough room for "minus offset" sequencer voltages.
Cheers
Good luck
Jacco Ville
> Op 19 aug. 2016 om 16:59 heeft Nicholas Keller maq163x2@gmail.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
>> Cheers
>> Jacco Ville
>>> > .... By the way ;-)
>>> > this problem.
>>> > Cheers
>>> > Jacco Ville
>>> > The Netherlands
>>> Best wishes
>>> Dieter Doepfer
..... Please take note that my approach of regulating is not the only way and so is my explaination ;-)
Hope you got the idea
> Op 19 aug. 2016 om 18:22 heeft Jacco Ville jaccoville@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Cheers
> Good luck
> Jacco Ville
>>> Cheers
>>> Jacco Ville
>>>> > .... By the way ;-)
>>>> > this problem.
>>>> > Cheers
>>>> > Jacco Ville
>>>> > The Netherlands
>>>> Best wishes
>>>> Dieter Doepfer
2016-08-21 by Nicholas Keller
Dieter and Jacco,
I inspected my three A-156 modules and A-155 this morning.
The A-155's Row 1 Pre Out was monitored using the DCV setting on hand-held DMM. Step 1 was held to output the maximum value, fully CW. With range set to 1V, I adjusted P9 until 1.000V on DMM. However, switching to 2V and 4V, the scale was still not wide enough. I chose to tune 4V to 4.000V which left 2V at 2.003V and 1V at 1.002 or so. A calibrated quantizer would correct this if necessary.
My method to test the A-156s was to use an A-176 CV Source to send 0.000V and +5.000V signals to an A-150 Dual VCS. The A-150 was toggled manually using a manual gate. The output of the A-150 was verified using the DMM and sent to the CV Input of the A-156. The output of the A-156 upper or lower unit was now monitored by the DMM. Results varied.
Most units produced 0.000-0.0010V with the 0V at input and 4.972-4.983V with the 5V at input. Adjusting P4 only resulted in reaching 5.000V in one unit and that was at the maximum rotation of the trimmer. Most units only were adjustable to around 4.985V, and some of those started with a 0.002-0.010 offset. I attempted to adjust P1 but saw no change at the output. I must not understand the procedure.
Do either of you see a flaw in my test procedure? Can I install a different size trimmer for P4 or a 1% resistor in place of R21 and improve the performance?
Perhaps this should be moved to another thread, but one of the upper units has been unresponsive for ages and this calibration quest has prompted me to address it. The output is stuck at around 1.169 or 1.194V, it was different after turning power off and on. I thought perhaps it would be an issue with the CV In or Out socket itself, but prior to today wasn't sure of the offset or held voltage. Could the problem be Q1 or BU3? Is a voltage held indefinitely in the PIC or is it reset after power off?
Thanks for your help!
Nick
On Friday, August 19, 2016, Jacco Ville jaccoville@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
Cheers
Good luck
Jacco Ville
Cheers
Jacco Ville
> .... By the way ;-)
> this problem.
> Cheers
> Jacco Ville
> The Netherlands
Best wishes
Dieter Doepfer
RE: [Doepfer_a100] Tuning references for A156 quantizer
2016-08-21 by Jacco Ville
*OK
*Maybe an aging problem? Can’t tell you.
*The trimmers P1 and P2 don’t change the output, only to determine the threshold of  the quantizer.
The outputs of the DAC are fixed at 0.08333 steps (1.000V divided by 12, 1 octave has 12 notes) but you can adjust wether the quantization takes place from which point. Just before or spot on the quantization step for example.
*I am not able to give you an answer on this.
*Sent it in for repair, but I’m shure Dieter may give a better suggestion
Cheers and good luck
Jacco Ville
Verzonden vanuit Mail voor Windows 10
Van: Nicholas Keller maq163x2@gmail.com [Doepfer_a100]
Jacco,
Thanks for your response. Only after writing that message did I actively search for the calibration document on the Doepfer page. I followed its instructions of using the Quint setting on the A-156 and the sweepable output from the A-176, removing the A-150 from the signal path. I've managed to fix the P4 setting so I get octave jumps to within 0.01V over 5 octaves while sweeping the A-176 CV1 coarse control. I'm still working on this. But I don't think replacing the trimmer is necessary, merely proper research and following of instructions. However, I don't understand why jumping from 0 to 5V through the A-150 would cause me to be unable to adjust P4 to the correct inverval.
On Sunday, August 21, 2016, Jacco Ville jaccoville@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
*OK
Jacco Ville
I believed I was making progress, but noticed something while probing to troubleshoot the faulty upper unit. When I connect the A-176 to the A-156, there is a voltage drop. Disconnected, the A-176 output measures 05.00V, but when I connect to the CV1 or CV2 Input of either of the two A-156s I have out of the case, the voltage at the tip of the socket drops to 04.88V. Earlier, I was comparing to the multipled socket on the A-176. I only have one DMM, so was not able to test "simultaneously" as suggested in the instructions, but I think I was getting the same result by testing the quantizer output and multipled socket while adjusting P1 and P2. But I don't like the drop. If I send 1V from a sequencer, keyboard, or other source, I expect a 1V change entering the quantizer, not a reduced value. I assume I am still not understanding the process fully.
Nick
On Sunday, August 21, 2016, Nicholas Keller <maq163x2@gmail.com> wrote:
Jacco,
*OK
Jacco Ville
2016-08-22 by Nicholas Keller
Thanks Karl, I'll check this out tomorrow
On Sunday, August 21, 2016, karelvanbezooijen@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
Here is my thread about this module from about a year and a half ago: https://groups.yahoo.com/neo/groups/Doepfer_a100/conversations/messages/26234 maybe it's useful but I must admit I didn't get it right as it should be. And I still haven't bought a second one ;-).
Best regards, Karel.
KarEl,
Sorry for misspelling your name, I was tired, it autocorrected, and I didn't notice. Thank you for linking to the other thread but I have yet to even check the transpose input. I will keep this added resistor mod in mind when I do.
Nick
On Sunday, August 21, 2016, karelvanbezooijen@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com>; wrote:
