hello ernst,
as long as you use the a149/1 in dieters patch, there
will be no voltage output below the "lower" offset,
because the a149/1 outputs only positive voltages.
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, *--*
<heinrich.himmelwasser@g...> wrote:
> Hello Dieter,
> The patches you describe here are both close to the unit I tried to
decribe
> (thanks for that!!).
> However the lower voltage as an offset is a misunderstanding.
> For as far as I remember it was so with the TMG at sonology that if
you put
> the lower and upper voltages
> on the same level that it would only output that voltage. In both
your
> patches it also generates output below..
> Maybe I'm wrong.. But I will defianately start investigating.
> And also I would still be interested in a modulel ike this, saves a
lot of
> patchcords and modules I can use in the rest of the patch. ;-)
> Anyway I will get back on this later this week after I have
contacted my
> sources at Sonology.
> Friendly greetings,
> Ernst
> On 9/21/05, Dieter Doepfer <hardware@d...> wrote:
> > From my understanding this can realized with an A-149-1, VCA
(e.g. A-132)
> > and mixer (e.g. A-138a). The clock is the A-149-1 clock, lower CV
goes to
> > one A-138a input (kind of mixer offset), the A-149-1 output is
processes
> > by
> > a VCA with VCA CV as upper CV, the VCA output goes to another
mixer input.
> > The mixer output is the Tendency mask generator output. The A-149-
1 could
> > also be replaced by an random module A-118 and a S&H A-148. In
this case
> > the
> > clock goes to the A-148 clock input.
> > I don't think that it justifies a new module even though it would
be no
> > problem for us.
> > Best wishes
> > Dieter Doepfer
